Old 03-31-2009, 10:25 AM   #19
BailOut
Steals terrorist's lunch
BailOut's Avatar
*nod* We have all found the same thing. The bars are not entirely consistent, and the top half of the tank lasts longer (according to the gauge) than the bottom half does.
- Brian
Share the Road
Old 04-01-2009, 04:36 PM   #20
stripey
Pretty green Yaris Verso
stripey's Avatar
Drives: Toyota Yaris Verso
Originally Posted by daf62757 View Post
I wonder if the 09's are different. Mine goes from two bars to a blinking one bar.
My 00 Yaris Verso does that (UK spec) and I reckon to have 50 -60 miles. Once did 90, but have been caught out since trying to get near that and had to walk to the garage AND buy a spare can!
stripey is offline   Reply With Quote
Old 04-04-2009, 09:04 PM   #21
Kal-El
Kal-El's Avatar
Originally Posted by Luna V 2.0 View Post
My car is a bit odd. It goes from 2 bars to blinking. I'm not sure why it seems to skip the last bar.
I tend to tell myself I'll fill up when it gets to two bars, but I always wind up forgetting and then panic when it starts to blink. But I always fill up for less than 10 gallons so I know I still have quite a bit of gas left.
ALL Yaris's go from two bars to the last blinking bar (there's no solid last bar phase).
Old 04-04-2009, 09:06 PM   #22
Kal-El
Kal-El's Avatar
Heck, you people don't know how to live! Don't let your lives be driven by the blinking light, be like Kramer on Seinfeld and see how far you can go on a tank of gas!
Cheers! M2
Here ya go...
http://www.youtube.com/watch?v=TuEdU_lrtZk
Classic!
Old 04-04-2009, 09:52 PM   #23
MadMax
MadMax's Avatar
That's it! Now that's how you gotta drive!
Cheers! M2
Old 04-06-2009, 08:08 PM   #24
andaconda
andaconda's Avatar
Drives: '09 Yaris Sedan
I just filled up after 40 miles of the last bar fast blink. It was my first fill up. 510 miles and 11.009 gallons. $1.99.9 per gallon. 46mpg! not bad for my first tank of gas.
andaconda is offline   Reply With Quote
Old 07-15-2009, 12:19 AM   #25
SEVEN
Drives: 07' HB Black
I got 160 miles out of my last tank .... guess its the intake header and exhaust .. or I must have something severly messed up in my car
When life passes you by ... dowshift
SEVEN is offline   Reply With Quote
Old 07-15-2009, 12:29 AM   #26
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
The problem's usually with a loose nut behind the pedals.
Old 07-15-2009, 12:50 AM   #27
SEVEN
That used to be my problems, but I decided to quit speeding, so with this tank I havent been over 60 ... except that one moment where I did 80 but it was barely 2 minutes
Old 07-15-2009, 07:35 AM   #28
Yaris Hilton
Smile
Yeah, it's possible that changing the intake and exhaust could mess up your ECU calibration. I'd expect to see a Check Engine Light, though. Hot rod mods tend to inspire the rodder modder to use them, and zooming off from stops and hitting the brakes for the next one will suck the tank dry.
Old 07-16-2009, 08:27 PM   #29
gammaray
gammaray's Avatar
Drives: 09 3D Liftback
Oddly enough, wanted to find out as well, and I did today. As soon as the last bar started flashing I drove approx 1 mile and filled up. Took 9.959 Gallons. So for myself at 1.1 gal left I could go about 37 miles to empty. I have a bit of a heavy foot, but still get 34 mpg, with rarely any highway and running A/C. All good as far as Im concerned coming from prior performance oriented vehicles. Of course this is my deduction for my driving style. Love this vehicle.
gammaray is offline   Reply With Quote
Old 07-26-2009, 11:10 AM   #30
yarisitis
yarisitis's Avatar
Drives: 2008 Yaris LB
I've gotten 76 miles on my first bar, 37-57 miles on the middle bars, and 80 miles on the last bar.
Not very consistent.
yarisitis is offline   Reply With Quote
Old 07-26-2009, 11:33 AM   #31
watersoilair
Drives: 08-2DR-MT-LB-Red
I pulled into a gas station almost immediately after last bar started flashing. I filled up and it turned out there was 4.5 litres left in the tank. At a rate of 6.5litres/100km (city) and 5.5litres/100km (highway) thats just 70 km in the city and 81 km on the highway. I haven't pressed my luck so far - but I did travel ~55km on the highway @110km/kr with one bar left. Based on what I've read above...maybe I did try my luck.
Who knows. With up-to-date oil changes, clean air filters and good air pressure in the tires you should get great gas mileage.
watersoilair is offline   Reply With Quote
Old 07-26-2009, 11:35 AM   #32
Keith Tinari
Scrubble with a poke.
Keith Tinari's Avatar
Drives: 2009 Yaris LB
Mine acts the same way, I thought that it started after I out the rims on though. When I was still running the facotry wheels and tires I could get about 100 miles out of the first bar.
"If you cannot find truth right where you are, where else do you expect to find it?" Dogen
Keith Tinari is offline   Reply With Quote
Old 07-26-2009, 09:57 PM   #33
dg4rez
Gas Saver
Drives: Toyota Yaris Hatchback
Send a message via AIM to dg4rez
you will blow your pump out if you put to much stress on it, letting your fuel get so low. Personally, I think its smarter to fill up before then last bar. As its like 300 bucks for the part + install.
dg4rez is offline   Reply With Quote
Old 07-26-2009, 10:27 PM   #34
MadMax
MadMax's Avatar
So I've been driving for over 30 years, have owned several cars for almost ten years each, I have always allowed the gas to run low, and I have never repaired a fuel pump yet. Nor do I know of anyone who has had to do so that does the same. So please excuse me if I don't take your comments as fact!
Old 07-27-2009, 07:06 AM   #35
YarisOwnersDad
Is now a Corolla S Owner
Drives: 2010 Corolla S
You probably didn't listen when your mom told you to change your underwear every day in case you were in an accident, told you not to play with sharp sticks because you would poke your eye out, and told you to stop making faces because your face could freeze like that. Well, Mister, when you find yourself in the hospital with one eye, a frozen face, and wearing dirty underwear, remember that your mom tried to warn you .
YarisOwnersDad is offline   Reply With Quote
Old 07-27-2009, 09:31 AM   #36
highwaypass
Captain Slow
Drives: '08 1.5 hatchback
last blinking bar of mine = 50km
There's only 1 brand,2 drive,3 words,4 you: TO-YO-TA
highwaypass is offline   Reply With Quote
DIY - rear sway bar [pics] cali yaris DIY / Maintenance / Service 199 07-28-2022 05:25 AM
DIY: Strut Tower Brace Bar redyaris DIY / Maintenance / Service 18 03-16-2014 06:52 PM
Rear Sway Bar Instructions - Additional Pics SeaYa Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 02-26-2009 01:05 PM
solid torsion bar bushings... the best rear anti roll upgrade turboyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 12-05-2008 11:37 PM
c one motorsport performance bars badhabitz Performance Modifications 17 08-23-2006 10:31 PM
