#181 |
![]() ![]() ![]() ![]() Drives: 2009 Yaris Hatchback Join Date: Feb 2009
#182 |
The screw in the top left. If you look at the PCB a trace connects it to ground. When working with two probes I like to have one one something that it won't easily slip off of, like a screw head.
#183 |
#184 |
No dice... still no voltage
I guess I'll have to wait for those 3 ohm resistors
#185 |
Those points are where the connector is soldered to the PCB, so you shouldn't have seen anything different than we were seeing the other day. I thought you were asking because Santa came early.
#186 |
Unfortunately not...Santa's gotta come all the way from WI to NJ. Shouldn't be any later than Friday.
#187 |
![]() ![]() ![]() ![]() ![]() Drives: red bare bone yaris hb 3dr Join Date: May 2009
did you get the resistor yet? any update?
#188 |
#189 |
Which place did you order them from?
#190 |
#191 |
Dang! I should have just dropped some of the ones I have laying around in an envelope and dropped them in the mail. You would have had them in a day or two for the cost of a stamp.
#192 |
#193 |
Resistors are finally here! This project is officially back on track!
#194 |
"Stealth Runner"
nice man! keep us updated
#195 |
This is a 3 ohm, 1/2 watt resistor, right?
#196 |
Nothing so far. I plugged the 3 ohm (presumably) resistors into the airbag sensors, turned the key, and all lights are still lit. Also, still no voltage to the weight sensors. I disconnected the battery and will try again in a few minutes, but I'm thinking maybe the SRS system needs to be reset/cleared.
#197 |
more than a few -- I've heard Toyota techs wait 20 to make sure the SRS system resets (it has it's own battery, btw)
#198 |
Correct on the resistors. Garm is correct on the reserve power for the SRS ECU.
| Possible Group Buy.. Racing Seats, Intakes? | TinyGiant | Items for Sale by private party | 60 | 09-11-2009 02:40 PM |
| FS: Recaro Pole Position Racing Seats (black) -- socal | 03Z33 | Items for Sale by private party | 13 | 12-07-2008 05:08 PM |
| sparco seats and pedals (pics) | turboyaris | Cosmetic Modifications (Exterior/Interior) | 18 | 09-05-2007 02:43 AM |
| Sport / Racing seats worth the while? | mikeukrainetz | Cosmetic Modifications (Exterior/Interior) | 10 | 11-19-2006 01:17 PM |
| Yaris Liftback Seats | artyin | General Yaris / Vitz Discussion | 3 | 04-30-2006 04:07 PM |
