Old 08-17-2009, 01:17 AM   #1
jekqmb
Local Sh*t Disturber
Drives: 2009 Yaris LB
Spring question?
Okay i think im going to give springs a shot on the yaris first...I like to go really low, but i decided i dont want coilovers..What spring lowers the car the most?
Thanks, Jake!
Old 08-17-2009, 01:32 AM   #2
Brian
Brian's Avatar
The DFs or Progress I think are the lowest
Old 08-17-2009, 01:35 AM   #3
lilredrocket
Slowy getting there
lilredrocket's Avatar
Drives: 08 Liftback
Yep they are and make the cars stance great!!
Old 08-17-2009, 01:37 AM   #4
jekqmb
Okay, i bought Rota SA Racing rims 15x6.5...I probably should have got a wider wheel, maybe 15x7.5 or so and stretched the tires, but i figure im going to need something that really tucks these wheels in.....
Old 08-17-2009, 02:47 AM   #5
Tanabe DF210 will be lowest. You can use camber bolts (front) and shims (rear) to get extra tuck if you have any rubbing issues.
what offset are your wheels?
Old 08-17-2009, 02:56 AM   #6
Really? I thought the Tein S.Tech's drop the LB 1.9" all the way around and the DF's were like 1.8" or something like that.
Old 08-17-2009, 10:42 PM   #7
jekqmb
40mm.....I called and they said these wheels would fit, will i have any issues with a 40mm offset? Im pretty sure i read the yaris is good with a 40-44mm offset or something like that? So what goes lower, Tein or the Tanabes?
Old 08-18-2009, 06:53 AM   #8
lilredrocket
Slowy getting there
Drives: 08 Liftback
My bad I keep forgeting about the tien's they are the lowest
Old 08-18-2009, 09:03 PM   #9
jekqmb
Okay thanks!
Old 08-18-2009, 09:29 PM   #10
Tamago
Tamago's Avatar
Drives: ZZW30
the DF's will sag much lower than the Teins.
progress tucks tire on an xD :D
Old 08-18-2009, 09:48 PM   #11
I believe they should work fine with either Teins or the Tanabes. Also keep in mind that the S.Tech's have a higher spring rate in the rear, making for better handling characteristic on a fwd car like our Yaris. The Tanabe's have firmer spring rates in the front.
Old 08-18-2009, 09:53 PM   #12
jekqmb
Awesome thanks for the info guys...Im ordering either one tommorow, i want to see how the car feels at stock height after i pick her up at noon tommorow to see how low i want to go and how stiff i want my springs and say fairwell to my Redline as the dick salesman drives it away......Thank goodness all i have to do is go grab the keys for the yaris and drive off
Old 08-18-2009, 09:58 PM   #13
Why are you getting rid of the Redline anyway?
Anywho, you'll want the springs stiffer and the ride lower, trust me. hahahaha, Just take the Yaris on the freeway and feel the crosswinds. hahaha. When taking corners hard with the stock suspension, it'll make you sing http://www.youtube.com/watch?v=f3JpQDeqxnI
Old 08-19-2009, 01:25 AM   #14
jekqmb
The redline has a bad MAF, bad fuel pump, Maybe a blown #4 ringland, bad clutch, diff pin is loose. Haha i just didnt want to fix it, plus its got lots O miles on it....Ran 3 different nitrous setups threw it. Its time to get something good on gas and im buying a 2.2 Eco Cavy in the spring to Turbo.
Old 08-19-2009, 04:09 AM   #15
Ah, I would have gotten a Yaris as well.
hahahaha, you should throw on a Toyota emblem on that Cavalier and make it JDM. hehehe.
Old 08-19-2009, 01:19 PM   #16
lilredrocket
Slowy getting there
Drives: 08 Liftback
If you really want to stablize your ride get a rear sway bar!!! I can think of like 4 options out there: TRD one expensive, Ultra racing 19 and 23, and Raptor Racing came out with one. Those will really help you out!!
Old 08-19-2009, 01:27 PM   #17
jekqmb
Hey i was look at the UR ones, which one would be the best? 19 or 23?
Old 08-19-2009, 01:33 PM   #18
mrbond
mrbond's Avatar
^23mm hands down. I tried both and the extra few millimeters makes a big difference. If you want to further add to rear stiffness and improve handling even more, spring for the Nitto rear lower tie brace at microimage. I love it.
- A Toyota Yaris
- A whut Yaris?
lowering spring specs for Yaris botchilah Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 03-22-2017 09:47 AM
Hyperco 5.5" single pigtail rear spring test kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 06-15-2009 11:11 AM
Track Suspension id3379 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 85 06-11-2009 06:59 PM
spring rates question botchilah Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 05-11-2009 01:33 PM
TANABE DF210 Spring Install [pics] Chris07LB DIY / Maintenance / Service 148 07-16-2007 10:26 PM
