#253 |
#254 |
![]() ![]() ![]() ![]() Drives: 2009 Yaris Hatchback Join Date: Feb 2009
#255 |
I've got the battery disconnected now since I tried the reset and ran into the same problems I had the first time. I can't get past the first step. The SRS light is supposed to come on solid after three seconds of removing the jumper, but mine lights up as soon as the jumper is removed. There's no delay.
#256 | |
#257 |
Here's another thing that keeps the simulator simple - The sensors all "speak" at the same time. Here's the front right and rear right sampled together:
Two Sensors.jpg |
#258 |
Beast
except for that one little piece in the middle? it splts up the 2nd to last.. i have no idea what im looking at =D
![]() One you've taken a yaris for a spin, there's no turning back. Its a Chao!!! |
#259 |
Reconnected the battery... still have codes 32, 55, & 56. I pushed the resistors in from the wire side as well. Is it possible to snip the yellow airbag connector and attach the wires directly with the resistor in between?
#260 |
Ok, I managed to get it back to just code 32 after fiddling with the SRS resistors.
#261 |
I just tried this and registered nothing with the meter set to VDC. When I moved it to 200k ohms, it registered 6.0 between the center pin/wire and ground.
#262 |
It really looks like your OC ECU is not responding. Take a close look at all of the wiring to and from it. Look for any sign of a damaged wire.
#263 |
I don't see any signs of damaged wiring or anything else out of the ordinary. I can't think of anything I might have done to damage it (dropping, etc) so I hate to think there's a problem with it. Should I start looking for a replacement?
#264 |
I found an OC ECU on eBay for $69.99, but I want to make sure that's the problem before I go ahead and order it. Or have we already made that conclusion?
#265 | |
#266 | |
Why don't you ship me your module and four sensors and I'll test all of the parts out? |
#267 |
#268 |
You rock! I was going to suggest that, but I didn't want to overstep my bounds or anything. You want the OC ECU, the four wires, and four sensors? Anything else?
#269 |
#270 |
| Possible Group Buy.. Racing Seats, Intakes? | TinyGiant | Items for Sale by private party | 60 | 09-11-2009 02:40 PM |
| FS: Recaro Pole Position Racing Seats (black) -- socal | 03Z33 | Items for Sale by private party | 13 | 12-07-2008 05:08 PM |
| sparco seats and pedals (pics) | turboyaris | Cosmetic Modifications (Exterior/Interior) | 18 | 09-05-2007 02:43 AM |
| Sport / Racing seats worth the while? | mikeukrainetz | Cosmetic Modifications (Exterior/Interior) | 10 | 11-19-2006 01:17 PM |
| Yaris Liftback Seats | artyin | General Yaris / Vitz Discussion | 3 | 04-30-2006 04:07 PM |
