Old 08-28-2009, 03:24 PM   #37
RacerFreakXXX
JDM Fred
Drives: 06 Mazda Miata
Send a message via AIM to RacerFreakXXX
so far this is what I am planning for a turbo build, and I still can't decide if it's worth it to build the internals and finding a turbo that has the exhaust facing the passenger side. Also this is just what, I've found that I am decided on. I'm going to price it down to the exact and go from there.
motor: $500-$1000
Crower Rods: $800
CP Pistons 1NZFE/ 75mm bore/ 9.0:1 compression ratio: $600
(almost impossible to find at stock bore, yay ebay)
or
HP Engine Kit: $1000
- Complete Gasket Set
-Performance MLS Head Gasket
-ROSS/Wiseco Forged Pistons
(75, 75.5, 76mm) and
(8.5, 9.0, 9.5, 10.0 comp ratio)
-Plasma Moly Rings
-TOGA HP Main Bearings
-TOGA HP Rod Bearings
-Thrust Washers
NST Lite Pulley Set(blue): $300
Perrin Fuel Rail: $200
Scion TC Injectors: $150 used
Exedy Stage 1 clutch(16800A): $300
Fidanza Aluminum Flywheel: $300
KAZZ LSD: $900
NST Short Shifter components: $300
Nitto Engine Torque Damper: $150
RacerFreakXXX is offline   Reply With Quote
Old 08-28-2009, 11:54 PM   #38
Tamago
Tamago's Avatar
Drives: ZZW30
good luck on the fuel rail. if you want 2AZFE injectors i'll sell my set for cheaper than 150
Old 08-29-2009, 01:00 AM   #39
RacerFreakXXX
JDM Fred
i'm just pricing things out right now, and going based on turbo aplication, because i want the downpipe on the passenger side so I don't have to deal with crazy intercooler and intake piping. If I have to get a custom manifold made then i will just wait till i have the money for another engine and build it up fully. Is there an issue with the fuel rail, i saw it fits on xb's and xa's?
Old 08-29-2009, 11:16 AM   #40
1nz
Drives: Vios
Im also in process on installing an NCP31 HKS 1NZ-FE Bodykit on my yaris got the turbokit, rmanage ultimate n greddy pressure sensor, still saving to get an injector RC, FIC or Bosch/ Walbro 255lph fuel pump, double head gasket and custom piping
Please visit us @:
greddyvios.blogspot.com
1nz is offline   Reply With Quote
Old 08-29-2009, 12:13 PM   #41
Tamago
Tamago's Avatar
Drives: ZZW30
dude, if you want the turbo inlet to be on the passenger side........... turn it around and reclock the inlet side.
oh and do a top mount intercooler.
Old 08-29-2009, 01:51 PM   #42
mrbond
mrbond's Avatar
^ yeah, just like the JDM NCP91. You'd probably need to either get a new hood, which would look awesome, or do some under-hood air rerouting.
- A Toyota Yaris
- A whut Yaris?
Old 08-29-2009, 04:57 PM   #43
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
or just cut a scoop goin down into the IC and fiberglass/paint and call it a day
Old 08-29-2009, 05:21 PM   #44
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
You can do that with any T25 turbo and with a regular revhard manifold...
No need for anything custom for what you have in mind...
Old 08-29-2009, 11:09 PM   #45
RacerFreakXXX
JDM Fred
Actually a top mount intercooler is what I had in mind. I was thinking about using the kaminari hood and mount the intercooler in front of the engine.
My main concern with switching the turbo around is it not fitting, you seem to have a lot of space behind the engine so I would just feel more comfortable knowing that it would surely fit.
Aren't revhard manifolds the same quality as ebay? where would you pick one up?
Also I think i'd rather get a Turbinetech manifold imo.
Old 08-30-2009, 12:22 AM   #46
lilredrocket
Slowy getting there
lilredrocket's Avatar
Drives: 08 Liftback
Look how close that is to the brake lines.
Old 08-30-2009, 07:10 AM   #47
changchewsoon
Drives: Vios Turbo
Send a message via MSN to changchewsoon Send a message via Yahoo to changchewsoon
I would suggest that you might want to get the pistons slightly over sized, say 75.5mm rather then standard size at 75mm.
Due to wear and tear the cylinder bore might be a little worn out and hence a slightly over sized pistons will ensure the rings fit in nicely.
Best if you could get your mech to properly measure the bores to determine how much larger you need to go if you want to be really sure.
It is always better to be safe than sorry later, just my 2 cents.
By the way, I got my CP pistons from Race Engineering together with the piston rings and side skirt coating for less than USD 600. The compression ratio is 9.0 and the piston design is flat top.
454 whp, 1.7 bar boost, pump gas, water/meth.
501 whp, 2.2 bar boost, pump gas + avgas, no water/meth.
www.viosturbo.com - World's first 500 WHP 1NZ-FE
changchewsoon is offline   Reply With Quote
Old 09-01-2009, 09:01 PM   #48
RacerFreakXXX
JDM Fred
now i've been comparing supercharger vs turbo cost and this is what i came up with is that for 2-3k i can get the hks turbo kit and for 3-4k i can get the blitz supercharger. My question is EMS, once again... I know I'm going to need a ems for the turbo but i see tons of people running the supercharger w/o. Now I can find a shop that will tune the yaris my question is if it's worth it to grab the hks kit, get some custom piping done with an intercooler and try and tune that or grab the supercharger and play it safe. I just have a gut feeling that a turbo would make my car go boom if something was slightly wrong with my setup and for the little extra the supercharger would be safe and easier to maintain in the long run. Am I just being paranoid and think I should go for the hks turbo? I'm not going to buy it till summer when I have a place to install the turbo.
Also I was comparing weight to power ratio against other cars and I found that with the supercharger you should technically be about as fast as a stock rsx type s or prelude and with the turbo you should be about as fast as a stock wrx( not the 09+ with 265bhp)
Old 09-02-2009, 12:22 AM   #49
1nz
Drives: Vios
it could actaully beat the rsx s, tested against one of those
Please visit us @:
Old 09-02-2009, 01:02 AM   #50
RacerFreakXXX
JDM Fred
supercharger or turbo
Old 09-02-2009, 03:06 AM   #51
get the TRD trans mount, you won't need the torque damper.
Old 09-02-2009, 09:08 AM   #52
Tamago
Tamago's Avatar
Drives: ZZW30
beating a dead horse here
top mount + meth injection + HKS kit (that comes with engine management)
skip the front mount
Old 09-04-2009, 11:49 PM   #53
RacerFreakXXX
JDM Fred
for intake and top mount intercooler i was thinking about running the intake tube up against the firewall and then use a wider diameter tube leading up to the intake and then putting a long thin intercooler more towards the front of the engine, over the intake manifold. Doing this would eliminate the issue of heat soak if you use a vented hood, such as c-one or kaminari. Also running an intake tube along the front of the engine would interfere with the radiator hosing. Opinions?
Old 09-04-2009, 11:50 PM   #54
Tamago
Tamago's Avatar
Drives: ZZW30
do it.
i wont hate you for copying my setup either ;) if you so choose
Turbo Project Yaris TS 1.8L CASTREX Yaris TS Talk 40 08-21-2009 11:24 AM
HKS turbo timer type 1 Tamago Performance Modifications 3 07-21-2009 12:59 PM
Turbo Kit - trade for stock parts! crankyelbow Items for Sale by private party 62 02-03-2009 01:30 PM
delayed turbo project... joey1320 Forced Induction Forum 8 09-27-2007 12:18 AM
Vitz Rs turbo vs U.S. Yaris add turbo? weaponrcamry Performance Modifications 18 08-09-2006 09:45 PM
