#55 |
![]() ![]() Drives: 05 Echo H/B Join Date: Jul 2009
#56 |
Who said Yaris was slow?
You were running higher than 50hp shot for sure...
If you did a 75hp shot you got balls! props for that! I'm helping a friend installing a NX wet kit on his Yaris on the next couple of weeks. But we will use 35hp nozzles for the street and 50hp nozzles for the track only... we will use some high octane fuel on the 50hp runs... just for extra safety... |
#57 |
I'll have times on Oct 31.
#58 |
1/8 mile times or the real deal???
What mods are you planning for the track?? Tire compound and size?? Suspension set up? come on we want more info!! You better get her low in the 12's.... |
#59 |
real deal 1/4 mile @ fontana.
http://www.autoclubspeedway.com/ You know all my engine mods, but I will be trying some drag slicks I got from Art IF they fit over my brakes. I'll get them out and measure them up tomorrow. Probably need spacers. My suspension is: Silk Road coilovers TRD motor mounts BeatRush trans mount UR rear underbrace Tanabe front strut brace UR 23mm rear sway bar (like that will matter, LOL)
#60 |
Slowy getting there
Make sure you turn up the dampening on you rear shocks all the way and put your rear tires at max PSI to try and keep weight transfer to a minimum. Have you been working on your launches?
#61 |
![]() ![]() ![]() ![]() ![]() Drives: 09 Yaris HB, 08 SR5 Tundra Join Date: Jan 2009
subscribed
#62 | |
You need to make them fit..!!! If not get others that fit... or get rid of the front BBK. Like you will need that on the track! Taking your car w/o a proper set torsion tires will be like not going at all. Is a most!! Is important to dial the right pressure for the drag slicks. I'm sure Art can give you a few pointers as he has experience with the box. Front: just high enough not to rub the tires. Stiffness Probably some where in the middle. Front suspension should allow for some travel but have good dampening to prevent bounce. Rear: as high as the silkroads allow and full stiff. Over inflated rear tires... Leave the rear under braces and sway bar at home!! Go to the local strip to practice some launches! Oh and please.... HD video!!!! |
#63 |
I don't have a BBK - all else duly noted, thanks!
#64 |
Modded Moderator
Come on guys, slips!
#65 |
![]() ![]() ![]() ![]() Drives: Yaris YR Join Date: Oct 2008
17.4sec 1/4 Mile. Thought a S/C Yaris would be quicker then that. Haha. Hopefully you do better next time you go with less wheel hop.
![]() Mods: 17x7 ANZ Tazer Wheels with 215/40/17 Marangoni Tyres | AFE Air Intake System | NST Short Shifter Kit | NST Shifter Cable Bushing Kit | NST 10% Underdrive Crank Pulley | Pedders Sports Springs | Custom 2inch Cat-Back Walker Muffler with 2.5inch Xforce Twin Stainless Steel Tip | RS Side Skirts | RS Euro Spoiler | YRX Front Lip Spoiler | TRD Style Front Grill | 12mm Rear Hub Spacers | Ultra Racing 23mm Rear Sway Bar |
#66 |
Hey Mike, did you lower your front tires' psi? I forgot to do that too, and I had a lot of wheel hop too. I need to repost my slips one of these days...but I have to find them first.
#67 |
Nice. Yeah, I ended up beating only two cars the night I went to the strip, a Ford Ranger and a Nova (driver "fell asleep" at the tree, I think)
![]() I was running 42 psi that night...horrible. hahahahaha. |
#68 |
![]() ![]() ![]() Drives: 07 liftback Join Date: Nov 2008
I ran a 16.36 after weight reduction, and a 16.56 fully loaded, including the spare tire. God, I can't believe someone remembers that, lol. That was almost 2 years ago ><
I'm glad to see people going sub 15 in these cars though, before I left for the army, that was all the talk!!! |
#69 | |
TRIM HUNTER
#70 | |
Modded Moderator
P.S. Thanks for posting your slips!! |
#71 |
TRIM HUNTER
TIMESLIP and with what bolt-ons?
#72 |
17s!? ahhh. Oahu needs a track
| OFFICIAL Yaris SEDAN thread | SimmZ | Photo-Video-Media Gallery | 1706 | 06-22-2025 05:33 AM |
| Official Scangauge II Thread - Share your Data, Discuss Settings ,Problems, Findings! | TRD_Yaris | General Yaris / Vitz Discussion | 183 | 02-01-2017 12:18 PM |
| Get your post counts here! *read 1st post for rules* | Astroman | Off-topic / Other Cars / Everything else Discussions | 3414 | 11-04-2012 09:03 AM |
| The Official "Bambo the Yarisworld Traveler" thread (V1) | nemesisz | Off-topic / Other Cars / Everything else Discussions | 3 | 11-08-2008 10:24 PM |
