Old 10-19-2009, 07:01 PM   #181
Lewis
Our off road vehicle
Lewis's Avatar
Drives: 2009 Yaris 3dr
wow, mailed it that fast to Scott huh...
Next chapter is always interesting..... ;)
yes Kioshi we have certainly gave Scott some challenges!
Lewis is offline   Reply With Quote
Old 10-19-2009, 07:32 PM   #182
*MAD DOG*
*MAD DOG*'s Avatar
So glad it arrived. Now it's all up to Scott to weave some magic :)
Old 10-19-2009, 10:15 PM   #183
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
I have a feeling since you have an 09 w/ ABS, your cluster will be an easy swap...lol
I looked at Mad Dog's hi res pics in the previous page and you too have the ABS icon and stuff.....so no problem with that ;)
I love it when I end up w/ complications in life..
Old 10-19-2009, 10:51 PM   #184
Lewis mentioned an interesting dilemma with it; The connectors are on opposite sides, so the cables won't reach.
Old 10-19-2009, 11:02 PM   #185
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
Thats something I didn't catch in the photos from Mad Dog. The only thing I can think of for that at the moment would be do find a salvaged Yaris and cut the wires off that, unless the same gauge wires can be spliced and soldered onto the ones on the connector.
Old 10-19-2009, 11:05 PM   #186
I'll fire it up on the bench first and then to run it in Crashy, I'll have to splice an extra foot onto each wire.
Old 10-20-2009, 06:41 AM   #187
Lewis
Lewis's Avatar
yes Scott -the humor of this situation can help offset the extra work involved for you regarding the cables.
imagine if everything is inverted like the cables- for instance the speed would go down on the speedometer as you go faster etc.!
I know i bit off more than i can chew with the OZ cluster- luckily we have somebody here with very sharp teeth- Scott!
p.s. they say water goes down the drain anti-clockwise in OZ- perhaps that was a warning!
Old 10-20-2009, 06:51 AM   #188
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
Gotta love the people here.
Old 10-21-2009, 04:52 PM   #189
Update: I received the OZ cluster from Lewis today!
I immediately had to open the box and hook it up on Crashy. With the swapped connectors (since it is for a RHD Yaris) I just hooked up connector D1, which has power, CAN bus, fuel gauge, tach, speed, etc (the other just has the feeds for a bunch of the indicator lights).
It powered up fine and the fuel gauge showed proper level. So, I started the car and the tach worked correctly, but the speedometer stayed at zero. This cluster is off an ABS car, so that makes sense, as Crashy is non-ABS.
The issue though is that the cluster is indeed angled to... the passenger (at least on this side of the world). The VFD (vacuum fluorescent display) is reversed and is mounted in that chunk at the bottom and is pointed to the left. A concave mirror magnifies and inverts the VFD and angles the display to the USDM passenger.
Being an Engineer, I just had to take it apart to see how it was setup and to snap some pics. Here they are:
Powered up:
Close up of the VFD:
Close up of the clock/mileage VFD:
Concave mirror:
Old 10-21-2009, 04:57 PM   #190
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
So could you transplant the guts of the aussie cluster , into the USDM
unit , or is it not that easy
Old 10-21-2009, 05:02 PM   #191
The USDM one is just a flat plane. The Aussie one has the lens in the same place, but the guts and case are completely different to make the VFD work correctly. I was initially thinking that you could modify the bottom chunk and the back to point towards the left, but the upper portion has a molded tunnel that is angled from left to right. It would take some creative plastic work to make the display point left.
Old 10-21-2009, 06:24 PM   #192
*MAD DOG*
*MAD DOG*'s Avatar
Scott and Lewis,
Glad it works. Looks like some more work is required to make it useable for you though.
Scott,
I know you just got the unit, but is there any chance of a fix so the Km/L would work for us Aussies?
Old 10-21-2009, 06:31 PM   #193
*MAD DOG*
*MAD DOG*'s Avatar
I think this picture sums up this thread.
Old 10-21-2009, 11:00 PM   #194
kustom play
pink wheels are cool
kustom play's Avatar
Drives: 07 liftback
bummer it doesnt work
so how does it look from the driver side? not well or is it kinda tolerable?
well back to looking for a USDM S Cluster
http://www.4055design.com
Old 10-21-2009, 11:37 PM   #195
Without modification the speedometer/tach portion are really not viewable at all from the driver's side.
Old 10-22-2009, 12:40 AM   #196
kustom play
Drives: 07 liftback
so it looks like its a bust for LHD cars then :(
so looks like the only way to get a tachometer and speedo is the get the USDM tach/speedo combo then
Scott, Anyway to rig up a sedan cluster? How far off is the fit?
I always see those for sale and there super cheap!
Old 10-22-2009, 12:48 AM   #197
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
sedan cluster should be the same size as the liftback cluster, but the plugs to connect are different from the liftback......
Also.....is your car ABS enabled kustom? If not, you will run into problems like Lewis and I.... :P
Old 10-22-2009, 01:12 AM   #198
kustom play
Drives: 07 liftback
i dont think I have ABS
I think the 08+ USDM cluster works on both i think so i guess its the one way to go at the moment
DIY - Change your Gauge Cluster Color vodkalush DIY / Maintenance / Service 89 04-29-2019 09:41 AM
FS: Gauge Cluster from '09 LB- $150 MGargano Items for Sale by private party 14 10-05-2009 12:59 PM
Shifter knob/gauge cluster color DevilGirl Cosmetic Modifications (Exterior/Interior) 3 08-11-2009 10:18 PM
Sedan Instrument Cluster to LB Instrument Cluster Malaya1221 Cosmetic Modifications (Exterior/Interior) 2 12-02-2008 10:05 PM
CLUSTER LIGHTS WENT OUT Go4th DIY / Maintenance / Service 23 01-25-2007 11:37 AM
