Old 11-09-2009, 09:51 PM   #1
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
I got another CEL :(
Installed the nitto midpipe about 4 months ago and got a CEL. Installed the o2 anti fouler and it got rid of it for about 3 months. Acouple days ago it turned back on Anyone else with the Nitto MP have this problem?
Old 11-09-2009, 11:13 PM   #2
severous01
get a o2 simulator. if you can't find one i can find you one on the camaro forums.
fill the hole, with a plug, use antiseize. and dont worry about the after cat sensor any more. now if you're talking for the pre-cat sensor...i dont know what to tell you other than to try a new sensor.
Old 11-10-2009, 11:22 AM   #3
hatchbackkid82
Drives: .
I have the Nitto Mid Pipe with the O2 Anti-Fouler, No CEL for me. I had a problem with the O2 sensor bung, but it was a simple re-weld job. I've had my mid pipe on since June. Do you know what code it's throwing?
Old 11-10-2009, 11:25 AM   #4
check the code.
Old 11-10-2009, 11:26 AM   #5
hatchbackkid82
Drives: .
+1 you probably didn't tighten your gas cap all the way, happened to me That will throw a CEL
check the code.
Old 11-11-2009, 07:03 AM   #6
PHXDEMON
PHXDEMON's Avatar
I think I may hear a slight exhaust leak. Is it possible for that to throw a code I didn't use any washers in between the fittings because there weren't any from the factory. Are you guys using crush washers on your fittings?
Old 11-11-2009, 07:06 AM   #7
PHXDEMON
PHXDEMON's Avatar
Oh man I feel like such a dumbass I just popped the door and the cap somehow wasn't even screwed on. Thank you kind sir for helping me pull my head out of my ass
Old 11-11-2009, 09:45 AM   #8
shoulda checked the code.
Old 11-11-2009, 11:06 PM   #9
PHXDEMON
PHXDEMON's Avatar
Have no way of checking it. No scangauge and the local checker guy is a douche that won't let customers use the code reader anymore Anyway I tightened up the gas cap and it is still on. Do I NEED to clear the code or should it go away after a little while
Old 11-12-2009, 10:46 AM   #10
hatchbackkid82
Drives: .
It even says it on the gas cap. I think the light should go off if you've re-tightened the gas cap and drive around a little bit. That's what happened to my friends IS250 and the light shut off. If not have someone check the code before you get reset just to make sure
Old 11-13-2009, 11:45 PM   #11
PHXDEMON
PHXDEMON's Avatar
Yep light went off a little bit after filling up my tank
Afe intake installed...CEL ??? vten Performance Modifications 7 06-05-2009 01:08 AM
going from 91 to 87 gave me CEL! FLAME ON enviri General Yaris / Vitz Discussion 28 05-24-2009 10:42 AM
CEL Issue via MAF Sensor, Thoughts? The Architect Performance Modifications 8 03-30-2009 12:50 AM
FS: Sedan Nitto Mid-Pipe w/ CEL Fix Split Items for Sale by private party 37 12-18-2008 01:11 PM
Non cat exhaust CEL? CASTREX Performance Modifications 15 01-28-2007 02:22 PM
