Old 11-22-2009, 03:04 PM   #1
Roscoe
Drives: Sporty
Location: " When we do right no one remembers, when we do wrong on one forgets. "
Who car's are fully synthetic?
Who runs Synthetic oil in the Engine, Transmission & Diferential.
If so what's your choice.
Roscoe is offline   Reply With Quote
Old 11-22-2009, 05:32 PM   #2
schleppy
I love momentum.
schleppy's Avatar
Drives: 2009 Yaris LB, Red
Penzoil Platinum 5w30 motor oil. AMSoil GL4 (MTG) fluid in the trans. So far so good.
Old 11-22-2009, 05:36 PM   #3
R2D2
Crazy Oil Sniffer
R2D2's Avatar
Drives: MM 09 Yaris 5 Dr LB "Click"
RLI BIOSYN 0W-20 in the engine and soon RLI BIOSYN ATF in the auto.
"The howl was the sound of God’s casting pot, the morphing of my cells into shape, the forming of oceans out of molten premordial plasma. And I could feel it. I could cry for it. I could cry with it."
-The Fitful One
R2D2 is offline   Reply With Quote
Old 11-22-2009, 06:05 PM   #4
POORSHA
POORSHA's Avatar
Drives: 2008 LB
amsoil engine amsoil tranny
POORSHA is offline   Reply With Quote
Old 11-22-2009, 06:11 PM   #5
Lazerdot
Lazerdot's Avatar
Drives: Blazing Blue 08 liftback
AMSOIL 10w-30 Racing oil, Amsoil SVG 75-90 transmission oil
Amsoil Dot 4 Brake fluid.
One Year One Oil-AMSOIL at www.Trulube.com TRD Exhaust, Springs and Struts. TRD SSK. NST Underdrive Crank Pulley. Amsoil Dominator 10w-30 Racing Oil, Amsoil DOT4 brake fluid, Amsoil Severe Gear 75w-90 transmission oil, Ultra Racing 23mm Sway Bar, Camber Bolts, R1 Drilled Slotted front Brakes and SS Brake cables from Micro-Image. Orange Konig Daylight 17s, Kumo MXs. Greg@TruLube.com
Lazerdot is offline   Reply With Quote
Old 11-22-2009, 07:05 PM   #6
bronsin
bronsin's Avatar
The dealer said my MT ECHO has synth (or semi synth) in the tranny from the factory...
Old 11-23-2009, 02:27 PM   #7
aca72
aca72's Avatar
Drives: '07 Yaris S Sedan M5
Engine with Pennzoil Platinum 5W-30.
Transmission with Royal Purple Max-Gear 75W-90.
No issues.
aca72 is offline   Reply With Quote
Old 11-23-2009, 02:31 PM   #8
woof
Drives: Yaris 3dr Hatch/Black
Running Amsoil in the MT and GTX full synthetic in the engine. At 50K my car started getting a consistant 38 mpg and sometimes 40 mpg on the highway!
Amsoil guys....how long do you go between engine oil changes? They make a 25K and 35K and I was thinking of 35K as a once a year change.
woof is offline   Reply With Quote
Old 11-23-2009, 03:59 PM   #9
Indianspringsaz
Drives: 07 Bitchin Blue HB
Amsoil changed out every 6 months or 10K miles.
Indianspringsaz is offline   Reply With Quote
Old 11-23-2009, 04:28 PM   #10
Lazerdot
Lazerdot's Avatar
According to the AMSOIL tech I talked to, about 86% of the driving in the USA falls into the "severe condition" definition. Not sure if that includes long haul Trucking or not. Most oil brands sell the product based on the maximum life available. Amsoil does the same, therefore you'll find 25000-35000 miles/1year miles advertised. Other oils advertise up to 15,000 miles/1 year. But, severe conditions require a greatly reduced oil change interval, in many cases right back to OEM intervals. Amsoil's interval decreases to 15,000 and 17,500miles respectively under severe conditions. I sell AMSOIL with the severe conditions in mind. Filtration needs to be kept up with anytime an extended drain interval is used. Many filters can be used up to the OEM oil change interval. AMSOIL has EAO filters that last up 25,000 miles in most applications, not the Yaris. The MANN filter that can be used in my Yaris is good for 7500 miles when using AMSOIL. AMSOIL no longer recommends it's EAO09 filter for the Yaris. Amsoil has restricted the EAO filter life to OEM on other Toyotas due to some unusual contaiminate amounts in these engines. No matter which brand, always change your filter whenever you change your oil.
So, if your going to use the 35,000 mile SSO AMSOIL, make sure your plan on filter changes at OEM intervals ( or 7500 with the MANN) regardles if you change your oil at that time. Determine what type of driving you do and whether the max interval really fits your driving conditions. Do an oil analysis as you near the 15000/17500 mile point if you plan on going for the max drain interval.
Check out the Auto-Light Truck lookup on Trulube.com for all your fluid and lubrication needs.
Maybe a bit of over info, but rather you have it.
Old 11-23-2009, 06:35 PM   #11
Indianspringsaz
MANN filters are very good quality, but not made for extended intervals. I run them on all my stuff except the Powerstroke. That gets the Racor.
07 Yaris HB
07 Road King
06 Superduty CC
05 Scion TC
01 30' Sleekcraft HP500EFI
Your Local Amsoil Dealer
Old 11-23-2009, 07:28 PM   #12
JBIZZ
Drives: 2007 Liftback white
Royal purple 5w-30 w/ K&N oil filter and Redline MT-90. I originally tried the Royal Purple Max-Gear 75W-90, but was grinding while downshifting, to slippery for synchros.
JBIZZ is offline   Reply With Quote
Poll: Which FULLy synthetic oil do you use? Yawesh General Yaris / Vitz Discussion 110 03-01-2010 12:39 AM
Synthetic Oil Questions. Twistoffate0817 General Yaris / Vitz Discussion 19 07-15-2009 09:54 PM
Mini v. sedan = injury. No duh. Is this news? jess General Yaris / Vitz Discussion 48 04-17-2009 07:46 AM
Say what you want, the Yaris still RULES smartazawhipz General Yaris / Vitz Discussion 15 04-17-2009 01:36 AM
Breaking in a new Yaris yaris_the_walrus DIY / Maintenance / Service 38 09-13-2007 12:02 AM
