Old 12-05-2009, 01:57 AM   #37
yaris2010RS
yaris2010RS's Avatar
i am completly down with making a yaris real fast, but most of the stock engine parts will not take the super HP, pray as much as you like, its not changing anytihng about the engine
Old 12-06-2009, 01:28 AM   #38
Brad D
Drives: 07 Yaris RS 3dr
its more about the tune i bet with most of the engine failures you guys are seeing. with a good tune i bet this motor could see over 200whp all day long.
Brad D is offline   Reply With Quote
Old 12-06-2009, 10:45 AM   #39
lilredrocket
Slowy getting there
lilredrocket's Avatar
Drives: 08 Liftback
I had some damage after driving 8-9 months at 8psi and 183 whp on the stock motor. Cylinder 4 was showing some loss of compression. It would have eventually failed.
Yaris2010RS you make it seem like it is going to ust blow up on you the second you punch the gass for the first time. How come Cali got 8-9 months over your stated block rating that you won't share exactly how you got. He also said that it would have failed eventually be in 8-9 months is a long enough time to have a seperate motor on the side being built up with upgraded internals.
Also if you think any extra mods you car doesn't need what are your plans with your car?... Are you going to keep it completely stock? Because the Yaris has everything to be a running vehical as is and will last a long time, so according to you any thing someone adds to or changes on their car is "rice". Why are you in a F/I thread if you think that a turbo on a Yaris is "rice"?
Old 12-06-2009, 01:02 PM   #40
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
I think what he was getting at, is that it is rice to spend all that $ to turbo a Yaris just to drive it to work and back. I can agree with that, we are talking about a economy car with a $12-15k price tag. Dropping Over $3k in the motor or more is kind of crazy just to get more pep out of it UNLESSS you actually plan to utilize that power for what it is meant for... to race.
The flipside is the aftermarket industry would be super weak if only racers bought performance parts.
The only person other than myself from what I have seen on this forum who utilizes the extra power seems to be Tamango.
Even hitting up the dragstrip every once and a while is ok. Spending $ to build a motor and turbo kit just to post up whp numbers IMO is not
$ well spent. If you want to get to 7-11 faster there are better ways
Ptuning.com
Blown_xa is offline   Reply With Quote
Old 12-06-2009, 02:12 PM   #41
Brad D
Every motor people think has a set limit untill someone pushes it.. Same thing happened with the KA-t.. people thought it would not hold past 300whp.. now guys have hit 500.. the 350Z people thought you would need a sleaved block to make any real power.. now people make 1000whp with a stock block with forged pistons and rods...
here is a civic with a non v-tech B18 that we pulled out of the junk yard.. build up a turbo kit and gave it a good tune, we ran the car and draged raced it for two years. one day we got gready and added more power.. the tunner said "today is the day its going to blow" and yep on the dyon we overpowered the cylinder wall.. but guess what the pistons were fine.. you could of reused them.... this was at 375ft.lbs.. that is the limit for that block stock.
here is a a vid, we got it down to 11.1 on a stock motor... never opened up
http://www.youtube.com/user/chummimc#p/u/28/1eonKVSNOtI
Old 12-06-2009, 05:11 PM   #42
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
Good thing everyone doesn't have your logic. You don't HAVE to just race. If you were, why even build up a yaris or xA to purely race. That'd be stupid.
Want to know the beautiful thing about the yaris? You can still be boosted and have a great DD that makes 35+ MPG to 7-11; atleast I can.
Tamango has a NA xA, but drives his hair stylist mobile nowadays. He's trying to sell or sold his xA.
Old 12-06-2009, 05:45 PM   #43
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
hmm so he removed his turbo set up? He had a whole thread on the Scion forum about his boosted set-up.
Im not talking about building a race car, but spending a lot of money to make power should have a purpose other than for daily driving. My car is a daily driver, been racing it HARD since 5000 miles on the odo, it now has 102,000 miles on it. And it gave me 34mpg on a recent trip. 200 miles using 6.05 gallons of gas.
Ptuning.com
Old 12-06-2009, 06:11 PM   #44
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
the Blitz set up you have will def provide good gas mileage because it uses the factory injectors, it runs lean under boost though but it was never a prob ( I use to have that set up) because the Blitz box was probably pulling back a good amount of timing. I got the same mileage tho even with it turned off because it only puts out 54whp lol do to the restriction of the roots blades.
I never seen a Blitz set-up put down more than 121whp though on our dyno. It wasnt until I introduced nitrous that I was semi satified. The whole belt issue and sheering crank pulley pins got annoying so I got rid of the supercharger set-up. Using the round end of a good 1/8th ince drill bit provided a good upgrade to combat shearing the crank pulley pin. I was the one who came up with that idea years ago.
Here's a link to Tamango's old thread http://www.scionlife.com/forums/showthread.php?t=118234 cool ideas by him. Im assuming we are talking about the same guy. Good to see people autocrossing and utilizing their upgrades, I just wish I'd see more of you guys do that. There are a couple of Yaris' around here that autocross but havent seen one on a road coarse yet. There was a Turbo Fit at the time attack in NJ this past summer, I was excited to see that cause I didnt feel alone for once lol.
Ptuning.com
Old 12-06-2009, 07:31 PM   #45
PETERPOOP
PETERPOOP's Avatar
Tamango took off his turbo kit awhile ago; thus why it's a NA xA.
My blitz kit made 140whp with 135 tq before i put on a custom overdrive crank pulley which added a couple more lbs of boost and made me at 136whp/140 tq. This was done in Hawaii weather on a dynojet. However, I am going to retune with the ultimate and tune accordingly for more power. I'm also installing a meth/water injection kit; and i have 1zz injectors and run 11-12 AFR at WOT. Nothing lean going on over here.
In your mind it should.
Old 12-06-2009, 07:54 PM   #46
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
there is nothing wrong with doing something just because you can.
Colin Chapman disciple
Old 12-06-2009, 08:04 PM   #47
i'm sorry, but a yaris with a turbo for everyday driving is riced out.
For YOU. Not for me. Your intolerance for other's projects is what's so lame.
my definition of riced out is un needed upgrades
oh I see. Like the upgrades on your RS model?
[unsubscribed]
Old 12-06-2009, 10:06 PM   #48
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
Originally Posted by yaris2010RS View Post
yes this is fourm is talking about making a yaris 12 seconds but without total engine mod it can not handle anymore then (i'll even stretch the limit) 200HP, it will blow up
you are just blowing smoke. why dont you take the time to read most of the previous posts on the engine builds that people have done with the STOCK block on here.
there is more than one member that has the stock block over 200 tuned.
and its nitrous, not nitro. lol
Old 12-06-2009, 10:07 PM   #49
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
good upgrades. The overdrive pulley is a cool idea im glad somebody made it!
WMI will give you good results.
And yeah, it is my opinion about the racing. But I can voice it right? Don't place me as the bad guy because I believe something. I just would like to see 1.5's beat up on Evos and such on the track. Performance parts are developed for a performance enviornment. But anyone can enjoy extra performance anywhere it's all good. It's much more enjoyable on the track tho as I discovered.
136whp on a dynojet sounds about right. A typical Dynojet reads about 12% higher than our dyno. So that's about 119.
Ptuning.com
Old 12-06-2009, 10:44 PM   #50
xen555
xen555's Avatar
Drives: 3 DOORS LB
Wasn't there a stock yaris w/ NOS in PR in the 14s or 13s?
the yaris in the 14s is the yaris with corolla's engine
xen555 is offline   Reply With Quote
Old 12-06-2009, 11:20 PM   #51
RacerFreakXXX
JDM Fred
Drives: 06 Mazda Miata
Send a message via AIM to RacerFreakXXX
I really think everyone has the wrong idea of a Yaris (and a lot of Japanese cars). I give Garm a lot of credit for what he did but, a Yaris with 120whp can out handle a lot of things on a track. The car is meant for windy roads not going fast down a straight. If that's your goal go buy a new 2010 Camaro v6 for 23k or a used v8 mustang and call it a day.
RacerFreakXXX is offline   Reply With Quote
Old 12-07-2009, 12:35 AM   #52
PETERPOOP
PETERPOOP's Avatar
Well we wouldn't really know unless i dynod the same day/same time on a dynojet, then your guy's dyno. However, I know what you are saying.
And most people on here who have dyno'd their blitz kit have not even reached 133whp. So you suggesting that 136whp and what i previously hit before the pulley (140whp) is common for the blitz, I don't think it is. Atleast from the evidence shown so far.
ps: I just got the meth kit installed and running.
I know about that yaris; however, i remember reading somewhere about a yaris using nitrous that was in the low 14s or maybe even 13s? There was definately one in the states that I believe was in the 14s with just nitrous. He ended up blowing his engine on the strip. He posted a video of it somewhere on this site. He didn't want to say how he had the nitrous set up...
Old 12-07-2009, 01:45 PM   #53
anonymous user
rarer than JDM -1 of 1!
anonymous user's Avatar
Drives: 07yaris
Hey, where did the O.P. go??
This looks like a pissing contest btw racers and ricers. My opinions are similar to those that race. I purchase all my cars with the intention of racing them. My yaris was mostly for the great fuel economy though, but i still have the itch. I am a firm believer that you could spend $4k to make a car fast, or $4k to make the driver fast. After that, the fast driver would have gotten more out of his investment that the one who put parts.
But we are sidestepping the point of this thread. Which is making a yaris "real fast...".
So my gatherings are that most of you like to build drag power, or atleast that's what the O.P. wanted.
I've set and broken enough goals at the 1320. You can't have both auto-x car and 1/4mi beast. So now i build and race solo cars (well we have no track since 2006).
It's not what you drive, or how much $$ you throw at the car. Mod the ballast on the front left first!
anonymous user is offline   Reply With Quote
Old 12-07-2009, 02:47 PM   #54
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
sweet. Post results. What kit did you get? nozzle size? I agree with the whp numbers, it is all relative unless everyone goes to the same dyno in the same enviornment.
Ptuning.com
I'm going to drive my Yaris until they make... bnther36 General Yaris / Vitz Discussion 2 11-10-2008 06:18 PM
Im trying to figure out a easy way to make my yaris fast... help! nsracing Performance Modifications 61 04-11-2007 08:33 PM
