Old 12-15-2009, 06:14 PM   #19
daf62757
Nothing beats a Toyota!
daf62757's Avatar
Drives: 2013 Yaris 5 dr liftback
Yeah, IMO it's foolish to grow food and ferment it to fuel. I've really got no problem with the alcohol in the fuel itself. Most of the purported problems have been exaggerated. I believe our Yarises would be fine if there were 25% ethanol in the gas as they run in Brazil, but we need to develop better sources than corn for biofuels. It's far too inefficient, and has run up food prices.
Sugar cane and sugar beets are far more superior to corn. The corn farmers just have a better strangle hold on our corrupt government.
Big Dave
Indianapolis, IN
Synthetic Oil....its in my car.....for at least 10,000 miles!
daf62757 is offline   Reply With Quote
Old 12-23-2009, 10:14 PM   #20
mdesjarlais
yarisnoob
Drives: 2009 yaris hatch
you guys ever think that the long term fuel trim is boosted up a point or two due to the extra amounts of oxygen being sucked in by the dense winter air? i would hope you get worse mileage, otherwise that bad boy is runnin' lean! also factor in the defroster running almost daily. I get horrible mileage with mine compared to what i should be getting. I also have a slightly heavy foot...
mdesjarlais is offline   Reply With Quote
Old 12-29-2009, 01:50 AM   #21
Hershey
got to figure in taking longer to reach operating temperature during cold than those warmer days . Thus using more gas with higher idle .
Old 12-30-2009, 05:19 PM   #22
TheSilkySmooth
TheSilkySmooth's Avatar
I was just going to make a thread on this! My last fuel mileage calc with rotella diesel 10w-30 motor oil in the sump was 33.6mpg. Then I just changed over to 3 qts M1 AFE 0w-30 and the rest M1 5w-20. The car now has a real noisy cold start and run for 15mins. I just refilled the tank a 1/2 hour ago and I got 32.4! I dont like this synthetic oil! I was getting 38mpg last winter running PYB 5w-30 dino. I wonder, too, if the exhaust is getting plugged? There is a TSB on this for the 3 door for the exhaust plugging and a free replacemnt exhaust system if you have fumes (sulphur odour) in the car.
Old 12-30-2009, 09:22 PM   #23
vten
i don't know if it's the gas or else , but my yaris mpg is pretty bad during the winter time ....26mpg
I believe partly because of the remote start engine that running around 10 minutes each time , twice a day ....and Im still using the same tires setup + full header back exhaust ....
oh well Im driving less than 10 miles everyday to work anyway
Old 12-30-2009, 09:53 PM   #24
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
It's the remote start. I hate to let a car idle to warm up, though I've done it to defrost windows. All the fuel that's burned at idle is wasted, it increases noxious exhaust emissions, and that's when the engine really builds up sludgy glop in the oil from condensed moisture and partly burned fuel. In the old days it'd often cause cars to trail blue smoke from gummy oil making the piston rings stick in their grooves. Still might, but newer oils suspend sludge better. Much better to drive away and let the engine warm up more quickly.
Old 12-30-2009, 10:30 PM   #25
Black Yaris
der Zeck
Black Yaris's Avatar
i am very surprised no one has pointed out the fact
stock tires:
Circumference: 74.58 in 1894.3 mm
Revs per Mile: 876.1
your oversized tires:
Circumference: 77.31 in 1963.6 mm
Revs per Mile: 845.1
so that means every 100 miles your car thinks you drive, you actually drive 96.5miles
so you are getting worse mileage than you think
Old 12-30-2009, 11:14 PM   #26
MadMax
MadMax's Avatar
Yo! YarisHilton, what happened to your beard?!?
And Black Yaris, I have checked my speedo against my GPS, and it is accurate. I wondered about this when I initially got the car because I have 17" wheels on it; but either the dealership calibrated the speedo or the larger tires reduced the speedo error (which happened on my Jeep when I went from 29" tires to 31" ones.
And since I've had my Yaris for over a year old, that could not be a factor in the decreased mileage.
Cheers! M2
Old 12-30-2009, 11:19 PM   #27
YarisOwnersDad
Is now a Corolla S Owner
Drives: 2010 Corolla S
Oversize tires will cause the odometer to register fewer miles than actually driven, not more miles. So, you would be getting better mileage than you think, not worse.
Think of it as the car traveling further for each rotation of the bigger tire because of its greater circumference.
By the way, who was the roundest knight at the Round Table?
Sir Cumference, of course!
YarisOwnersDad is offline   Reply With Quote
Old 12-31-2009, 12:10 AM   #28
Yaris Hilton
Smile
I resemble that!
Time to look like Santa's over till next year.
Old 12-31-2009, 09:51 AM   #29
MadMax
MadMax's Avatar
Thanks YarisOwnersDad, I needed a chuckle this morning!
And ya look younger being "clean cut," Mr Hilton!
Happy New Year to you all!
Cheers! M2
Old 01-01-2010, 06:40 PM   #30
TheSilkySmooth
I miss the beard!
Old 01-01-2010, 08:10 PM   #31
Yaris Hilton
Smile
Took a bit of getting used to for me, too.
Old 01-03-2010, 01:29 PM   #32
detroiter
detroiter's Avatar
Is anyone elses yaris idling a bit higher even when it's fully warmed up, as compared to when it's a hot summer day and the idle of the car is very low when it's warmed up? Seems like my Yaris keeps a higher idle when it's cold out as compared to a summer day, even after it's fully warmed. Not a HIGH idle, just higher than if it's hot outside.
Old 01-04-2010, 10:13 AM   #33
Yaris Hilton
Smile
Mine does for a good while after the "COOL" light goes out, but it's not actually fully warmed up. After a good long drive, it falls back to a hair over 600 RPM. In a cooler place (it's 19 F here this morning), it might not drop back to normal idle speed.
Old 01-05-2010, 10:20 AM   #34
docB
Drives: '09 Yaris Sedan
If you have the air control set to defrost or defrost/floor, the air conditioning will cycle. That will raise the idle.
docB is offline   Reply With Quote
Old 01-06-2010, 06:38 PM   #35
hpvampiress
Drives: Black 5 door Liftback
I often have to put on my defroster and then realize much later I've still got it on when it's no longer needed. The defroster runs the air conditioning compressor, so it eats gas.
Ah! That's probably why my gas mileage has dropped so much lately! Along with winter road as well, of course.
hpvampiress is offline   Reply With Quote
Old 01-07-2010, 01:55 PM   #36
YotaYaris
YotaYaris's Avatar
Drives: 09 3dr (sold), 12 SE 5spd : )
I filled up this morning at one of my normal spots and what did I see on the pump.....
10% ethanol
That must be why I am down to 39MPG on average. That and more city driving has made me lose about 3-5MPG.
Its all about the MPG's !!
YotaYaris is offline   Reply With Quote
Fuel Economy swng Fuel Economy Forum 2089 01-23-2015 07:41 PM
My progression into hypermiling BailOut General Yaris / Vitz Discussion 8 10-13-2009 07:31 PM
Do you get about 4 MPG less during winter ? paraganek Fuel Economy Forum 24 05-18-2009 10:52 AM
Anyone from Missouri? MPG problems inside 4MPG Fuel Economy Forum 31 12-17-2008 06:48 PM
Free gas for any vehicle. ketel0ne General Yaris / Vitz Discussion 4 09-19-2006 09:07 AM
