Old 12-15-2009, 03:44 PM   #1
127.0.0.1
Drives: '10 Yaris5drHB+99 4runner LTD
scangauge-xgauge-outside temp-works
that is all
127.0.0.1 is offline   Reply With Quote
Old 12-15-2009, 03:50 PM   #2
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
That's great! Only I didn't even know it supports outside temp. I'll have to look into it.
Old 12-15-2009, 08:36 PM   #3
WD-40
07 Yaris RS
WD-40's Avatar
Drives: Red 07 Yaris RS
Thats nice .. supplying us with the code .. priceless
Yaris lover
WD-40 is offline   Reply With Quote
Old 12-15-2009, 09:52 PM   #4
127.0.0.1
here
http://tinyurl.com/yblyyfx
Old 12-15-2009, 10:17 PM   #5
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
^lol
Old 12-15-2009, 11:06 PM   #6
enviri
enviri's Avatar
Drives: 2010 Yaris
any other findings we can plug into the scanguage? :P
Old 12-16-2009, 12:19 PM   #7
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
i'll have to try this one... i've been just using the Air Intake temp for a rough guess. Sucks that way, often times the AI is off by 10-15F compared to thermometers on bank signs.
Old 12-16-2009, 02:21 PM   #8
127.0.0.1
yeah, air intake temp is much warmer
use the scangauge II web site, go to xgauge commands,
use CANSF ambient air. use the latest guide, and nothing that says experimental
it is dead-on accurate and takes data from the probe for the a/c unit. if you have A/C your yaris will have the temp probe. this is nice to know when you are driving in freezing rain or wet roads close to freezing.
Old 12-18-2009, 12:27 PM   #9
Has anyone else tried this on a pre-2010? It doesn't work on my 09, nor on Crashy, as neither of their ECMs support the OBD PID "01 46".
Old 12-18-2009, 12:38 PM   #10
127.0.0.1
yeah I have a 2010 5 door US model automatic
here is the code I loaded
Ambient Air Temperature (F)
07DF0146 04410546 2808 00090005FFD8
AIR Degrees Fahrenheit
I haven't tested below zero, to see if it will throw a neg in there....
it only got to 9 degrees at home so far and my Yaris
blew me a 7, 8, 9, 11 all the way to work. it is dead-on accurate
(my home probe is on the sunny side, my Yaris is downhill from it, hence colder)
The other built-in indicator on the scangauge
(FIa) Intake air was showing 22-24 deg (not useful data)
Old 12-18-2009, 12:41 PM   #11
After I tried it (and also tried it directly by CAN bus message to the ECM) I realized that you have a 2010. When I request the list of supported PIDs from the ECM 0146 is masked as an unsupported PID, so I have a feeling that ambient air temp is a new PID for 2010.
Old 12-18-2009, 01:58 PM   #12
127.0.0.1
wowser, so I just kinda got lucky playing with the xgauge and 'common'
can bus data. mine happens to be 'common'. woot. !
all the more reason scangauge > ecometer
FYI ha, tried cansf fuel level code, that one doesn't work
Old 12-19-2009, 07:29 PM   #13
BuildCode
BuildCode's Avatar
Drives: Black 5-Spd Sedan S
Arg! I was so looking forward to using this till I read further!! (I have a 2009)
BuildCode is offline   Reply With Quote
Old 12-19-2009, 08:23 PM   #14
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
eh.... 08 here... wish I had a 2010 tho... the extra air bags would be nice if I get in a wreck.
Old 12-19-2009, 09:22 PM   #15
LtNoogie
LtNoogie's Avatar
Drives: '08 Bayou Blue LB AT
Well, here's the ghetto way. It's worked well since August when I put it in the car.
http://www.yarisworld.com/forums/showthread.php?t=20840
Temp guage and compass in Rear view mirror Chaad32 Cosmetic Modifications (Exterior/Interior) 10 10-30-2020 08:47 PM
Official Scangauge II Thread - Share your Data, Discuss Settings ,Problems, Findings! TRD_Yaris General Yaris / Vitz Discussion 183 02-01-2017 01:18 PM
Works bell/Nardi quick release steering wheel setup blacksandiegovitz Cosmetic Modifications (Exterior/Interior) 35 09-02-2009 06:52 PM
Inlet air temp vs. vehicle speed LtNoogie Performance Modifications 8 04-27-2009 01:20 AM
