| View Poll Results: Would you buy one? | |||
| No |
5 | 5.10% |
| Yes (for $75) |
46 | 46.94% |
| Yes (but it would have to be less than $75) |
7 | 7.14% |
| Yes (but I still want it to also display the time) |
40 | 40.82% |
| Voters: 98. You may not vote on this poll | |||
#199 |
Yes. All Yaris with AC have it. No aftermarket device would interface to it though, as it isn't universal enough.
#200 |
pink wheels are cool
im really excited to see the final product and to get it installed!
#201 |
![]() ![]() ![]() ![]() Drives: '07 Yaris HB Join Date: Apr 2006
I was thinking of putting it in the plastic covering by the wind-shield washer lever - you know, the one that covers the hole for the push start button?
I could get a rectangle shape laser cut, then laser cut a piece of thin plexi-glass to glue onto it, then put the screen below. That way the wires can run through the hole, and I could still see it while driving. Not the best solution but I think that is where I am going to place mine. |
#202 |
![]() ![]() ![]() ![]() Drives: Black HB Join Date: Oct 2008
About time, but I wanted all the other cool functions too lol. Can't have everything I guess? lol
#203 | |
![]() ![]() ![]() ![]() ![]() Drives: car Join Date: Oct 2008
For example when people get in my car I proudly tell them that some crazy CT electrical engineer fabricated up a switch for my airbags. This is a great project and you shouldn't fear the scangauge because yours is going to be way better! Also, as an owner of a tach, I would like to see a version of it fit under my single DIMM head unit or as an AC vent replacement, both are great ideas. |
#204 | |
#205 |
![]() Drives: 2010 Yaris Hatchback 5dr Join Date: Dec 2009
Awesome work CTScott, it's looking amazing :)
for this
#206 |
Update: 1/20/2010 - Final design review and testing:
After installing the proto in my Yaris and driving around with it for a week, I found that bright sunlight was a major problem. This time of year, most of my driving is either in the dark or on overcast days, so it took a few days to encounter the worst case conditions. After speaking with some display manufacturers about the issue, I was able to find a different type of display that is far more sunlight readable. I explored many options, including many that would have doubled to price of the product. The display I finally chose fits better within the space, so it is not recessed, as the original had to be. Also, the text is black on white or orange (other colors will be available as well), so the display is similar to the fuel gauge, rather than the original clock display. YarGauge - 0120.jpg Here is a list of all of the current features. If there are any additional requests let me know ASAP, as I am preparing to cut the final version of the circuit board. 1. Clock and outside temperature on second line. 2. Display modes for top line: a. RPM numeric b. RPM bargraph c. Fuel Economy (MPG) d. Battery Voltage e. Coolant Temp f. Intake Air Temp g. Fuel system status h. Calculated Engine Load % i. Throttle Position % j. Speed k. Number of stored DTCs l. List of DTC's m. Clear DTCs / Reset MIL (Check engine light) 3. Programmable Shift Indicator / Light - This optionally displayed feature will display an indicator between the time and temp on the second line. Considering the small size of the display, this feature will also have a 2 wire output that will drive your choice of LED, mounted wherever you choose. 4. Cruise Control Indicator - For those with 06-08 Yaris, who have done the DIY cruise control, this feature will display an indicator between the clock and temperature to indicate that cruise control has been activated. This will require a one wire connection to your DIY switches or OEM CC stalk. 5. Automatic Dimmer - The new display is much brighter than the original, so I found that I absolutely needed the dimmer feature. 6. Configuration options a. US or Metric units b. Time display - 12 or 24 hour c. Shift light enable/disable d. Cruise Control Indicator enable/disable |
#207 |
![]() ![]() ![]() ![]() ![]() Drives: . Join Date: Apr 2007
Scott enough already!
!!! All of YW can't wait anymore release it
#208 |
![]() ![]() Drives: Blazing blue 08 LB Join Date: Oct 2008
#209 |
Drives: '10 Yaris5drHB+99 4runner LTD Join Date: Sep 2009
1) how does the user give it instructions ?
#210 |
![]() ![]() Drives: '07 M&M LB Join Date: Jul 2007
This is just amazing! Can't wait for final product!!!
#211 |
#212 |
Scott,
On my dads car the other day he showed me a really cool feature. It tells him how many miles till empty. Any way to add that in? |
#213 | |
This would give two more screen - Gallons or Liters left (rather than black bars) and estimated miles left at current burn rate. |
#214 |
very cool!
#215 |
This guy Scott is a genius! My money is READY! OMG this is gonna be so cool to have!
AEM CAI, NST Pulleys/SSK, WR 4-2-1 Header, TRD axelback, R1 Concept Rotors, TRD Sway Bar, Nitto Rear Strut Bar, Cusco GT-Zero Coilovers, 1ZZ-FE 1.8L TB |
#216 |
![]() ![]() ![]() ![]() ![]() Drives: Polar White - 5 Door '09 LB Join Date: Aug 2006
Awesome! So would we be able to configure it to show our current fuel economy / mpg AND miles left to empty?
| in dash clock as tach? | Cosmonaut | In Car Entertainment + Electronics (audio / video / alarm) | 10 | 07-12-2010 11:27 AM |
| digital tach, 52mm, preferably blue leds | severous01 | Cosmetic Modifications (Exterior/Interior) | 5 | 05-15-2009 10:58 AM |
| Digital Tach | nqd | Performance Modifications | 4 | 05-17-2007 12:04 PM |
