#19 |
![]() Drives: yaris 1.0 petrol (Y2K model) Join Date: Jan 2010
Stupid question:
Lefty Loosey, Righty Tighty, so if I am in front of the car I push on the torque wrench from the right hand side of the nut to unscrew it... correct? The last mechanic was either ham fisted, or didn't bloody well change the oil in ages. I suspect the latter since the colour is very dark on the dip stick. I think I'm going to have to start hammerring it, as I'm a bit worried about using my massive torque wrench. Like it's massive - I only use it as the rear wheel on my bikes take 65nm, but this yolk is good for 200nm. The minimum setting is 30nm, will that be OK to use? |
#20 |
Half a Bubble Off Plumb
The drain plug nut is on the underside of the car, pointing up. It's upside down. Looking at the nut, as if you were on your back under the car looking up at it, it tightens turning clockwise and loosens counterclockwise. If you're talking about pushing toward the right side of the nut facing it from the front of the car, you're talking about toward the left side of the car, and you're tightening it. Look at the nut and work out the clockwise/counterclockwise thing before you tear something up.
#21 |
All done lads, was dead easy in the end. Now to source a good value OBD II.... local shop stocks them, but at €170 I think I'll pass.
If they worked on bikes too I'd buy one, but it turns out there is a different model for the bikes. |
#22 |
The wife left the lights on in the car while in work, so the battery was dead as a dodo.
After jump starting her, the engine management ligt went out -- so I guess you do need to issue a reset with an OBDII after fixing a problem. I guess it must have been crying for a service eh? |
| KCALB SIRAY - Photo Scavenger Hunt | KCALB SIRAY | Photo-Video-Media Gallery | 5 | 03-02-2009 10:44 AM |
| New car shopping - long post | littlecarlove | General Yaris / Vitz Discussion | 19 | 11-01-2006 10:58 PM |
