Old 12-02-2008, 11:47 AM   #1
dmehak
Drives: Yaris 5-Door
Bad Speed Sensor?
This morning my girlfriend went out to start her 2007 Yaris 5-Door, and the ABS and emergency brake warning lights illuminated on the dash. She took the car into the dealership, who ran a diagnostic (and charged us $105 CAD to do so), and they informed us that the left rear speed sensor has gone bad. They were also saying this sensor is part of the entire hub assembly and that we’re going to be looking at $650 - $750 CAD to have it repaired. The car has about 72,000km on it which puts us just outside of the 60,000km factory warranty.
Has anyone had any experiences with their speed sensor failing? Or could anyone explain more about what the sensor actually does? Is there any risk not having it repaired right away?
Thanks guys.
dmehak is offline   Reply With Quote
Old 12-02-2008, 11:57 AM   #2
I currently have the same situation with my Dodge Caravan. The speed sensor is monitoring for wheel lockup and will trigger a pulsing application of brake pressure to slow the vehicle down without locking up. There is no risk to not having it repaired right away, as without it functioning you are simply operating in a non-ABS mode.
Old 12-02-2008, 11:59 AM   #3
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
I can't tell if the rear wheel has a stand alone sensor and trigger wheel or if it is integrated into the bearing housing. but that seems a little on the high side, should be more to $300-450 CAD MAX because labor shouldn't cost more than maybe 2 hours and the part
(rear hub housing with speed sensor) maybe around 200-250 CAD
you are, like previously posted, going to be driving w/o abs,
Old 12-02-2008, 12:34 PM   #4
dmehak
Thanks for the help guys. Just a quick update on this. She started the car at the dealership when she was leaving, and the lights came back on, but after about 30 minutes of driving they turned off. Is this normal for this problem?
I’ve had problems with the StabiliTrak sensors in my car freezing on really cold days and giving me false warning lights on the dash, I don’t suppose it could be anything like that?
Old 12-02-2008, 12:55 PM   #5
Shroomster
Shroomster's Avatar
was it below freezing?
not to rule it out but it may have been a possibility....
if it comes on sporadically you may have a ground wire loose somewhere in that circuit or the connection may be loose/bad/corroding....causing an intermittent problem
Old 12-02-2008, 02:26 PM   #6
TinyGiant
Tiny Giant Clothing
TinyGiant's Avatar
couldnt you take the fuse out for the ABS and just run it without the abs?
Old 12-02-2008, 02:42 PM   #7
IllusionX
Drives: 07 Yaris Sedan Aero
that would result in an ABS light. And in the event of an accident. good luck with the insurance.
Old 12-02-2008, 02:42 PM   #8
TinyGiant
Tiny Giant Clothing
TinyGiant's Avatar
ahh
Old 02-04-2009, 06:16 PM   #9
clayky
Drives: '07 Yaris S Sedan
This exact problem happened this time last year to my '07 sedan. It was a bad left rear sensor covered under warranty. Now it's happening again and I'm 2,500 miles outside of the basic warranty (of course). I did however, find a TSB for this very problem for both rear sensors. Something about a corrosion problem. If it's very expensive I'll just hold out for the Civic Si I've had my eye on.
clayky is offline   Reply With Quote
Old 02-04-2009, 06:44 PM   #10
devinlamothe
devinlamothe's Avatar
Drives: '07 Yaris HB
Take a look at this thread: http://www.yarisworld.com/forums/showthread.php?t=11533
It's happened to a LOT of people in Canada with a Yaris/Corolla.
devinlamothe is offline   Reply With Quote
Old 01-16-2010, 11:33 PM   #11
beleza33
Drives: 2007 Toyota Yaris
Word for word the problem you guys are having, I'm currently having. I have a 2007 Yaris that I bought in March of that year. I'm a little over 38,000M and of course I got the basic 36000/3 year warranty. I went to the dealer when my ABS/Brake lights came on and BAM! $600-$650 to fix. I'm getting some second/third opinions on the issue because this is NOT an issue I or ANY person should be having with a car under 3 years old that has reasonable wear. At NO time during the possession of my car was it immersed under water or even in high flood water so this problem is unacceptable. They're going to get SICK of me.
beleza33 is offline   Reply With Quote
Old 01-17-2010, 12:15 AM   #12
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
If the hub has to be completly replaced it would take a Toyota Tech no more than 1/2an hour
I say this becuase as a lot of people know ,that have put in Hub spacers
it takes less than that to remove the hub and bolt it back up with the spacer behind it .
as for the part failing at 38,000 miles
In New Zealand standard waranty is 3yr's 100,000KM or gold warranty
5 Yr's 150,000KM
Old 02-04-2010, 05:06 PM   #13
Jake
Drives: 1997 Yaris Sedan
Faulty Speed Sensors
Hi, replying here. Just posted a thread about my issues with the same problem. Have you had any feedback besides what is on here?
thanks,
J
Jake is offline   Reply With Quote
Old 02-08-2010, 11:21 AM   #14
pokoki
Drives: 2007 Yaris type S
Does any one know the TSB # for the rear speed sensors???
pokoki is offline   Reply With Quote
Old 02-08-2010, 11:28 AM   #15
127.0.0.1
T-SB-0120-08 ?
seal allows corrosion on abs sensor
Old 02-08-2010, 01:01 PM   #16
devinlamothe
Sadly a TSB does nothing unless you are under warranty. :(
Old 02-08-2010, 01:34 PM   #17
pokoki
Well that sucks.
I just rolled 100K, and it has been a problem free 100K miles. I took the car to the car wash to wash off all the winter salt/garbage, and within 10 miles the ABS and the Parking brake lights came on. I hit the brakes to check the ABS, and sure enough, no ABS...
I figured some dirt or snow got lodged, so I cleaned everything by hand, and the lights are both still illuminated.
Guess that means I need to visit the stealership
Old 02-08-2010, 02:34 PM   #18
POORSHA
POORSHA's Avatar
Drives: 2008 LB
With all the problems toyota is having I can't imagine they won't fix them free. who knows.
POORSHA is offline   Reply With Quote
Bad Air/ Fuel mixture sensor warning for ALL Yaris owners eric81 General Yaris / Vitz Discussion 31 04-21-2012 09:28 PM
The Official Having A Bad Day Thread. *MAD DOG* Off-topic / Other Cars / Everything else Discussions 7 11-15-2008 09:38 AM
Speed sensor for navigation install saue1436 In Car Entertainment + Electronics (audio / video / alarm) 5 04-12-2007 10:40 PM
swap for 2zz-ge???? yarisTOONR82 Performance Modifications 12 03-23-2007 08:15 PM
