Old 02-10-2010, 07:02 PM   #19
even richard holdener's setup peaked around 6000rpm
Old 02-10-2010, 09:12 PM   #20
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
better springs = stronger or "high pressure" springs
I don't have a recommendation, I have stock springs and I'm happy with my results so far. I see no need right now for higher revs - the car doesn't make more power up there.
I can almost guarantee that you're starting to float the valves past 6000 RPM. With 20 psi of boost pushing them open, plus the high revs and the fact that they are pretty soft to start with.
Old 02-11-2010, 05:41 AM   #21
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
I can say that many owners who built a 1NZFE focused more on the bottom end (pistons and rods) which it's the right thing... but when planning beyond certain power and boost you can't leave a stock head pure and plain!
What about a Top End build? Is there a secret for the ultimate powerband of a 1NZFE?
Parmas is offline   Reply With Quote
Old 02-11-2010, 01:47 PM   #22
it's no secret. port and polish, then work on valves, then work on cams. Cams are tricky with VVT-I though, in my experience.
Old 02-11-2010, 07:21 PM   #23
rob323
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car
Basically, the camshaft that you run depends where the power band will be in the rev range.
Ideally, you choose your camshaft based on the intended purpose of the vehicle and where abouts you want the power band to be in the rev range, then select valve springs (and sometimes valves) to suit, and then size your turbo, intake, exhaust and intercooling system accordingly.
In theory, the design of the 1NZFE does not suit really high revs due to the bore to stroke ratio.
If using stock cams, then the factory redline (or slightly higher if it helps with your gear change points) will suffice.
rob323 is offline   Reply With Quote
EVERYONE PLEASE STAY SAFE! Shroomster Off-topic / Other Cars / Everything else Discussions 5 01-01-2009 05:47 AM
CEL blinking during rev limit hit. ddongbap General Yaris / Vitz Discussion 2 10-01-2007 02:10 AM
Hyper Rev: Vol# 108 Vitz (No. 3) **IN STOCK & READY TO SHIP** KamiSpeed Sponsors Classifieds Area 1 03-03-2007 01:50 PM
