Old 03-16-2010, 09:56 AM   #1
steve nic
Drives: subaru impreza
squeeking clutch on a d4d
as stated above we have a 2002 d4d yaris in the family which has developed a squeek when you depress the clutch!and the local toyoa dealer recommends a new clutch@£600the clutch feels fineany ideas people?
cheers steve
steve nic is offline   Reply With Quote
Old 03-16-2010, 03:13 PM   #2
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
You need to provide more information. If it is the throw out bearing, it could mean a new clutch is in order.
Old 03-16-2010, 03:36 PM   #3
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
Yeah, need a little more description.
Is the squeak while the pedal is being depressed (the motion of the pedal is causing the squeak), or is the squeak constant AFTER the clutch pedal is depressed.
If it's clutch pedal motion, could be the pivot point at the end of the clutch slave cylinder needs some lube, or even just the pedal linkage needing lube. If the squeak it constant when you push in the clutch, it could be the throwout bearing. The work required to replace the throwout bearing is 95% of the work required to replace the clutch, so you might as well replace the clutch at that point.
Definitely get a second or third opinion before you go replacing the clutch!
Old 03-16-2010, 07:21 PM   #4
steve nic
it squeeks only when pressed and the noise is from under the bonnet!
Old 03-16-2010, 07:39 PM   #5
Loren
What?
Loren's Avatar
If it's a very light squeak, it could still be the slave cylinder rod. Pretty common issue.
Clutch shudder when setting off in 1st gear BuildCode DIY / Maintenance / Service 87 06-17-2015 08:14 AM
Help Me Find The Right Clutch RacerFreakXXX Performance Modifications 18 10-20-2010 06:20 PM
ACT clutch kit Jason@SportsCar Items for Sale by private party 11 03-31-2010 04:05 PM
Restarting car after popping the clutch... PaidTimeOff General Yaris / Vitz Discussion 21 02-26-2009 02:40 PM
Having clutch issues ? hystria DIY / Maintenance / Service 10 08-22-2007 12:34 PM
