Old 03-26-2010, 09:14 AM   #1
llama
Drives: Yaris 2006 1.0 T3
Question New stereo for Yaris 2004 query.
Ive got a 1.4 D4-D yaris and id like to change the stereo however i cant find any new fascias for my model (2004)
Does anyone know from where i could purchase one? its very similar to the one below however theres a small cash box on the bottom left and the cigarette lighter is on the right:
http://cgi.ebay.co.uk/TOYOTA-YARIS-C...item2c51864276
i could simply install a new stereo in the bottom try however i think it would look stupid having 2 stereos on top of each other!! i would like my stereo looks like the one below (mine is exactly like this one, except the stock stereo is installed instead):
http://www.toyotaownersclub.com/foru...1104417266.jpg
Thanks!!
Llama :D
llama is offline   Reply With Quote
Old 03-26-2010, 02:50 PM   #2
IllusionX
Drives: 07 Yaris Sedan Aero
it's kinda hard to find that part in other countries as this model came with integrated radios and was not sold in USA.
anyhow.. this will fit your vehicle..
http://cgi.ebay.com/ebaymotors/Car-R...fAudioQ5fVideo
Old 03-26-2010, 03:00 PM   #3
Take a look at the following thread:
http://www.yarisworld.com/forums/sho...ighlight=radio
Old 03-28-2010, 12:26 PM   #4
llama
ok thanks :D
Old 03-28-2010, 01:03 PM   #5
llama
however is the link i sent (1st one) enough? and would i need the ISO adapter?
Old 03-28-2010, 02:13 PM   #6
I can't tell from the picture in your 1st link if the radio hole is the correct width for an aftermarket radio or if the ISO adapter would be required to make fill the gap on the sides of the radio.
Old 03-30-2010, 05:49 AM   #7
llama
The aftermarket stereo will fit in for sure. what id like to know is:
  • After buying this could i just slip in my aftermarket stereo
  • Do i need the ISO adapter (as far as i know its that cable that u use to connect the stock wires to connect and aftermarket stereo)
Thanks again :)
Old 03-30-2010, 02:04 PM   #8
IllusionX
you do not need the iso mount for the dash kit i showed you. It has screw holes and should fit just right in.
Old 03-30-2010, 04:04 PM   #9
llama
Yes however i dont think it would fit. see my stereo looks somewhat like this one:
http://www.fitaudio.com/storedimages.../headunit1.jpg
a newer version, though it seems its extremely similar! so ders no way u cud fit that in because theres the old stereo blocking it and even if u pulled it out i would look really bare wudnt it?
Old 03-30-2010, 04:28 PM   #10
You definitely need the replacement face piece for the dash (like the one in your first post). The question is if the replacement piece has an opening that is 180mm wide (standard DIN radio width) or 200mm (a wider width common with non-integrated Toyota radios). If the replacement trim piece has a 180mm wide opening, then that and the wiring adapter is all you need. If the replacement trim piece has a 200mm wide opening, then you also need a kit that adapts the opening to the correct width for an aftermarket radio.
Old 03-30-2010, 04:44 PM   #11
llama
Thanks a lot then :)
Old 03-30-2010, 06:36 PM   #12
IllusionX
cept that replacement face piece for the dash is impossible to find, at least, that i know of, in Europe.
aftermarket, fascia, new to forum, stereo
Blown Fuse - Stereo !?! click.mine In Car Entertainment + Electronics (audio / video / alarm) 16 10-05-2017 09:35 AM
Stereo Upgrades....what to do!? gravylegs In Car Entertainment + Electronics (audio / video / alarm) 39 02-28-2010 01:58 PM
FS: Bluetooth Stereo Headphones and Ipod Transmittor Sabretooth Items for Sale by private party 3 05-06-2009 06:59 AM
toyota vitz 2004 Fraz In Car Entertainment + Electronics (audio / video / alarm) 3 12-18-2006 03:31 AM
