Old 05-06-2010, 02:00 PM   #1
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
fnkngrv's Amp and Tube Install
Well after running the rear end of my audio system in a temp solution for a couple years I finally decided to finish things off. I didn't perform a DIY per se as I still only have my Blackberry as a camera, but I do have before and after pictures.
> I started off with the amp install by taking a slide bar from the hardware store and mounted it to the inside of the sidewall of my trunk.
> I then used cardboard to come up with a fitment template for my mounting board.
> I rerouted all my wiring to behind the new mounting board.
> I then mounted my board to the mounting bracket after wrapping the board in carpet that I could find as close to the other color in the trunk.
> I put the mounting board in place and screwed it down with one screw above the amp and one that sits under the amp.
> I attached the amp to the mounting board and reconnected the wires.
> Lastly I removed the cloth straps for my Bazooka Tube and installed the stainless brackets.
Before:
After:
Old 05-06-2010, 09:31 PM   #2
Alien Mantis
Secret Agent
Alien Mantis's Avatar
Drives: 2008 Yaris Hatch
The "before" was tacky.
The "after" looks sweet! Nice and clean. Good job.
Does that bass tube give you enough bass?
( I would have taken a totally different route, but I need more bass. )
Old 05-06-2010, 10:37 PM   #3
fnkngrv
fnkngrv's Avatar
I like what I have for bass. It is a deep and rich tone. I am actually bumping up I think to slave another 10 off the first one, but really I feel that with how I have my system set up I have very clean and loud sound when I want it. With a tube it generally fills your stage where as traditional subs give you more pound...kind of tough to describe unless you have experienced both in earnest. I have a friend that has 4 BTA's in his trunk of his G6 and it is pretty incredible, but then again he has a lot of wasted space that way and I prefer to at least have some room.
Old 05-09-2010, 03:24 AM   #4
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
What brand of sub and amp are those?
rye7jen is offline   Reply With Quote
Old 05-09-2010, 10:22 AM   #5
fnkngrv
fnkngrv's Avatar
It is a BTA10200, the current gen is a BTA10250 for the sub...
Amp is an Alpine MRP-F250. I did have a PDX however I swapped with someone that needed the PDX more than I did plus with the swap that they gave me I could not pass it up...
Old 05-09-2010, 10:58 AM   #6
custom Lftback
custom Lftback's Avatar
Alpine V-power FTW! I have the mrp-m500
C-Lift
Old 05-09-2010, 01:26 PM   #7
fnkngrv
fnkngrv's Avatar
Even tho the PDX series is spectacular the MRP series is very clean and has excellent clarity as well. I really don't feel like I downgraded per se.
Help with choosing Amp kit myt In Car Entertainment + Electronics (audio / video / alarm) 7 01-20-2009 02:00 AM
