Old 05-23-2010, 11:33 PM   #235
Originally Posted by sk8manmike View Post
What's the best way to go about splicing for the CC switch? Shave the wire coat and solder on to it?
That, or use a properly sized tap splice.
Old 05-24-2010, 01:35 AM   #236
mick.wheelz
mick.wheelz's Avatar
Drives: 2006 NCP91R, 1991 ST184R
Send a message via MSN to mick.wheelz
has this actually been tried on an AUDM ECM, I know it does not work on euro models (they seem to run different engines/ECM's alltogether)
mick.wheelz is offline   Reply With Quote
Old 05-24-2010, 07:15 AM   #237
mick.wheelz
so i checked my ECM, pin 40 is dead.
Old 05-24-2010, 08:54 AM   #238
That makes sense. It seems that the cruise control functionality is only programmed in the USDM Yaris ECM.
Old 05-24-2010, 07:42 PM   #239
mick.wheelz
that sucks, who has a USDM ECM they want to give me :p
Old 05-26-2010, 05:38 PM   #240
PhillyG
Drives: 2009 Yaris
just a side note... i finally got my parts in today. had them shipped to work because for some odd reason shipping to a business is cheaper. was gonna wait till this weekend and do the install.. notice how i said was? well.... during some down time....... it was really super easy! especially since i read just bout every post on the CC subject. many thanks to everyone! it works.. and looks factory!
PhillyG is offline   Reply With Quote
Old 05-28-2010, 04:04 PM   #241
sk8manmike
sk8manmike's Avatar
Drives: 2007 Yaris 4d Sedan
I've run into a problem: I can't get the black wire cover off of the ECM Connector A21.
I've read CTScotts tutorial:
http://www.yarisworld.com/forums/sho...+connector+a21
But i still can't get it off the top so i can insert the wire. I've feel like i'm pulling every direction in can think of to get it off.
Is there something I'm missing?
sk8manmike is offline   Reply With Quote
Old 05-28-2010, 04:31 PM   #242
Once you remove the tiewrap, to remove the black strain relief/cover piece you pry it out, or squeeze it and pull up. It is snapped into the back of the connector.
Old 05-28-2010, 11:05 PM   #243
sk8manmike
sk8manmike's Avatar
HOLY CRAP......
Ok let me tell you about the scary thing that happened to me right when i was about to get done with this mod.
I finished attaching my switch to the ECM and was now going to do the wire jump in the fuse box on my 07 MT Yaris..........
I put the first wire inside next to the white cable on the right and as I was putting the cable into the slot with the blue cable --- the car freaking lunged forward about 6 inches. Needless to say it scared the s**t out of me. I had the car on halfway (engine off - lights on), so i thought maybe it just did that because i had it kinda on. I turned it all the way off and tried again - same thing happened.
I attached pictures below to show you what i did and can take more if need be.
So whats going on guys? You think theres something wrong with my switch - like the buttons are always on or something?
When it lunges forward and always sounds like it wants to start - i think it stops because i pull the wire out when it lunges at me.
Any advice?
ECM CONNECTOR
CURCUIT BOARD
FUSE BOX - FOR CC JUMP, I put other wire next to the blue one and it lunges at me.
Old 05-28-2010, 11:25 PM   #244
Even if the switches are NC instead of NO, it shouldn't try to start. I see you are using a piece of bare wire. Are you sure it is only making contact with the blue and white wires?
By the way, the violet wire between the blue and white is the output to the starter, so making contact with it would indeed crank the starter.
Also, your Sedan is MT, not AT?
Old 05-28-2010, 11:35 PM   #245
sk8manmike
sk8manmike's Avatar
MT - i'm pretty sure i've only been touching the blue wire - i made the wire have a lot of bare wire so that i can check the voltage easier
Old 05-28-2010, 11:54 PM   #246
Everything looks correct. I would make your connections with the ignition off (and perhaps the battery disconnected as well). Then, carefully connect the battery / turn the ignition on.
Old 05-29-2010, 12:22 AM   #247
sk8manmike
sk8manmike's Avatar
I can't seem to produce any Volts between the connection anymore - it took me awhile to get the previous ones too. I'm pretty sure that the connection is whats keeping my CC from working.
Any idea who sells T Splice or something similiar? I'd hate to have to buy it from Amazon and wait another week.
Old 05-29-2010, 12:28 AM   #248
Radio shack and most auto parts stores sell them.
Also, to make sure your switches are correct; If you measure the voltage between the two terminals of the first switch, with the ignition on, you should see 12 volts. If you see zero, then your switches are normally closed, instead of normally open.
Old 05-29-2010, 12:45 AM   #249
sk8manmike
sk8manmike's Avatar
I'm not getting any voltage on the first switch.
This the switch for all four spots: http://www.radioshack.com/product/in...ductId=2062543
One of the reviews states that besides being crappy switches, they have a habit of going to a closed states when worn.
Old 05-29-2010, 01:12 AM   #250
sk8manmike
sk8manmike's Avatar
I'm using 22 Gauge Wire - is that what gauge T Splice I should get? I'm not sure what gauge wire runs to the fuse box.
Old 05-29-2010, 12:18 PM   #251
It's somewhere between 18 and 20 gauge I believe. The tap splices are usually good for a range, so if you can get 22 to 18 gauge ones you'll be fine.
For the no voltage on the switch, measure the red wire to ground (with the ignition on). If that is still zero, then disconnect it from the switch and measure the red wire separately to ground. If it is still zero, than your ECM pin is not properly seated.
Old 05-29-2010, 02:39 PM   #252
sk8manmike
sk8manmike's Avatar
Nice - My Terminal in the ECM wasn't completely seated - looking back at my first pic you can clearly tell that its only partly in. I have voltage now going to my switch and i'm going to do the jump and pick up some T Splice afterwards.
Cruise Control Available for 06/07 Yaris TOYOTaejien General Yaris / Vitz Discussion 8 08-27-2010 01:58 PM
Cruise Control chessclubloser DIY / Maintenance / Service 11 03-27-2010 12:59 PM
