Old 06-09-2010, 10:18 PM   #127
H3LlIoN
Drives: '09 Yarrrr hatch
cdy...any word on flow shop/rough cost?
As to cams...two weeks before I can get her in to the shop. Sry for the bad news gents.
Toyota
Moving Forward
...even when you don't want it to.
Special thanks to Cali Yaris, 1NZYaris1 and lilredrocket
H3LlIoN is offline   Reply With Quote
Old 06-10-2010, 02:38 PM   #128
H3LlIoN
bleh...$320 to $400 to flow head. I'm not paying for that. I'll just dyno it and be happy, or not.
Toyota
Moving Forward
Old 06-10-2010, 03:14 PM   #129
^ supposed to be Gude's job anyway.
Old 06-10-2010, 06:36 PM   #130
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Ba-dum-che.
Old 06-10-2010, 09:17 PM   #131
Jason@SportsCar
We contacted them during our search for head/cam work, I was not impressed. They had no specs, or even basic information - what should be basic if someone was actually doing this work - they had to call me back with the answers. Confidence, zero. They appear to be a middle man for an unknown machine shop.
Old 06-10-2010, 09:26 PM   #132
H3LlIoN
Yeah I'm waiting to see numbers to make final judgment, but I'm overall less than pleased at the experience so far. Any time I ask any questions, I get the run around about corporate espionage and such...all the while I'm thinking "dude. you've got $1620 of my money, you better come up with something!" Any way, he seems pretty sure of his product, so I'll wait and see what the numbers come back with.
As of right now, tech guys are telling me there may be some clearance issues putting my cams in the factory head, we'll wait and see what happens though, I'll get some putty and check it out.
Any body have a link for the ARP head stud kit?
Toyota
Moving Forward
Old 06-10-2010, 09:28 PM   #133
H3LlIoN
Also not happy with the turnaround time, but again, the whole point was for someone to "be the guinea pig," so whatev.
Toyota
Moving Forward
Old 06-10-2010, 10:02 PM   #134
rob323
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car
If the head has been measured, factory cams measured, stock head flowed to see what potential it had and how much work it needed, then every port worked on, then reflowed, ports reworked to equal them up, reflowed again to double check, then grind custom cam to suit, then preassemble to make sure cam doesn't foul on the head etc, I don't think a month is at all unreasonable (unless much shorter promises. were made and broken).
I was once told by a very experience engine head guy, that it takes him about 8 hours per port for 2 valve per cylinder motors and more for 4 valve per cylinder motors.
rob323 is offline   Reply With Quote
Old 06-11-2010, 09:15 AM   #135
H3LlIoN
Well if he had said "hey listen, it's gonna be a month and a half" I'd be cool with it, but he started telling me @ week three that I "should have it by the end of next week" which kinda' pissed me off.
Toyota
Moving Forward
Old 06-11-2010, 12:03 PM   #136
Jason@SportsCar
You have to respect someone trying to protect their investment in the R&D process, and they are certainly within their right to do so. However, I have not talked to one reputably engine builder that would not share all of the data I asked for - this goes for both our current and past projects. Most of these guys are secure enough knowing people come to them because of reputation, and based on that alone they will share - telling someone flow numbers does not tell how you achieved them.
I think the issue here is caused by the dealer. They likely fear that if anyone knew what machine shop made the parts they would be cut out of the loop.
Hopefully the difficult journey pays off for you.
Old 06-11-2010, 12:36 PM   #137
cdydjded
Drives: Yaris LB Turbo
ARP does not have head bolts or head studs for the 1NZ. Use brand new factory bolts & you will not have any issues.....
Old 06-11-2010, 06:26 PM   #138
H3LlIoN
I know Garm & Aras are running head stud kits...who makes 'em? With as often as this engine will be coming apart, I'd rather not fork for new bolts every time I break it down...
Toyota
Moving Forward
Old 06-11-2010, 07:38 PM   #139
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
I really hope for the best!
I know years ago when I was big into Hondas, there had been a lot of mixed results both performance wise and customer service wise with Gude. When I saw their name pop up in the Yaris circle, I was quite surprised.
Old 06-12-2010, 03:05 PM   #140
We got ARP studs for a different car and re-threaded both the block and the head.
There is a thread on MI for aftermarket studs available from a company in Spain.
Old 06-12-2010, 08:08 PM   #141
H3LlIoN
ty Garm
Toyota
Moving Forward
Old 08-18-2010, 07:50 PM   #142
GnomeBody
AD&D Dork
GnomeBody's Avatar
Drives: 07Liftback/07sedanS
Any luck?
Mods: K&N filter, Megan Coilovers, Ultra Racing 19mm rear sway bar, Sun tachometer, Window Tint.
GnomeBody is offline   Reply With Quote
Old 08-20-2010, 05:06 PM   #143
D&D
It's Quacktastic!
D&D's Avatar
Drives: '07 Yaris Hatch
<-- subscribed :)
D&D is offline   Reply With Quote
Old 08-20-2010, 11:36 PM   #144
Bluevitz-rs
Updates?
Head Liner / Ink removal bikegerm Cosmetic Modifications (Exterior/Interior) 11 06-23-2009 03:56 PM
Fitting amplifier to Yaris head unit nish1979 In Car Entertainment + Electronics (audio / video / alarm) 3 04-08-2009 06:18 AM
Changing LED's In Projector Head Lights whooppee777 Cosmetic Modifications (Exterior/Interior) 16 03-01-2009 02:07 PM
Req: Head unit suggestions. xed In Car Entertainment + Electronics (audio / video / alarm) 21 08-09-2007 07:38 PM
human head in coffee beans wushumasterku Off-topic / Other Cars / Everything else Discussions 8 04-19-2006 11:39 PM
