Old 04-02-2010, 10:50 AM   #289
No, (1) because we changed the manifold too and (2) we haven't tuned on the dyno yet (wastegate failed last time).
Hoping for a new appointment next week!
Old 04-04-2010, 04:50 AM   #290
changchewsoon
Drives: Vios Turbo
Send a message via MSN to changchewsoon Send a message via Yahoo to changchewsoon
thanks a lot garm and parmas, it is because of people like you guys all over the world inspires people like to me to want to push the 1nz-fe further! :)
i too can't wait to see garm's latest update and also parmas's build....man just thinking about them gives me goosebumps!
i've learnt a lot just by reading both your threads.
454 whp, 1.7 bar boost, pump gas, water/meth.
501 whp, 2.2 bar boost, pump gas + avgas, no water/meth.
www.viosturbo.com - World's first 500 WHP 1NZ-FE
changchewsoon is offline   Reply With Quote
Old 04-04-2010, 10:49 AM   #291
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
That is why we post here my friend !
Of course we are many here and I think there are more than just us building the ultimate 1NZ so please contribute your info
Parmas is offline   Reply With Quote
Old 06-10-2010, 04:04 AM   #292
Parmas
Parmas's Avatar
Update:
Let me revise the situation.... During the last months I had my tuner claiming that the problem of the tune up was coming from a loss of compression. Since there were too much money to repair and buy the extra parts I decided to hold the project until I had further cash in my hands.
During the time, I came accross one of my friends who is an expert on this and decided to help me out on this. Of course we began by checking the compression again and duhhh it came out that it is good on all 4 cyclinders. We retried again the test and still no problems.
Seeing this out he told me to change the tuner and retry the tune again. I went to talk with the new tuner and he told me that we need to check all the necessary wiring in case the previous tuner messed up something. We indeed found some wiring not matching with the ecu instruction manual regarding VVT connection so this might be the problem.
The other thing that might mess up with the tune is that the ECU supports VVT but not VVTi. There is an option to activate the VVT at a certain rpm and switch it off at another rpm. I contacted the ecu company for more info on this and he said that the ecu was tested and tuned succesfully on a 1ZZFE VVTi engine.
I booked a tuning session for next week so until then crossed fingers
Old 06-10-2010, 11:40 AM   #293
ooh, exciting! I'm very glad you checked the compression yourself, proving the first tuner to be wrong, making excuses like that for his lack of skill.
Good luck and we're all waiting to see how she does!
Old 06-17-2010, 11:00 AM   #294
Parmas
Parmas's Avatar
Today I went to my tuner to discuss how we can get this right....
Well there is some issues we need to face and we are unsure whether the management used is capable to tune VVTi correctly.
1st problem: Mode selection
- On the ecu there are 8 Modes one can select, from batch fire with single coil mode to Full Sequential mode. The only problem I am seeing is the Crank Trigger. If you refer to the attachment you can notice Mode 6 - Phased Sequential with multicoils, Crank Trigger 36 -1 input, no TDC (which is my current setup). According to H3ilton, our engine crank trigger is 34. If he is right, (and we will check about this to confirm) the ecu will not support this crank trigger and so tuning cannot be done efficiently.
- 2nd Problem: VVTi control
The ecu surely support VVT with an on and off rpm setting but since now we cannot find a way in the ecu's software that can tune on a range of degree angles. We only can signal the camshaft timing plunger at a certain (still unknown) pulse modulation frequency at a set RPM number. Still, when signaling the plunger we don't know for sure how the cam will react in terms of degrees but we are assuming that when not signaling the plunger the engine is fully retarded and when singaling the engine is fully advanced. At this point, if we are assuming right, the midrange power will be affected drastically. If I am right our engine varies timing within a range of 40Degrees.
In order to solve this problem, my tuner recommended of eliminating the VVTi by making the stock camshaft fixed (if it can be done) or else upgrading the cams.
- 3rd Problem: Ignition Coils
I was thinking of putting the stock ignition coils as members of this forum suggested but when talking with my tuner he said that the ecu do not support the stock 4wire coil with igniters. In order to work we need 2wire coils that are capable to work with the ecu. (Refer to attachment) First wiring diagram shows my current setup while the other shows the wiring diagram for full sequential
- 4th Problem: Installing TDC - Currently not used
According the Toyota Engine manual page 40, the stock ecu use the camshaft position sensor (TDC) to make the VVTi work efficient. Our ecu supports this feature and it could be installed without problems. So I ask, is the TDC a must to have it installed to make the VVTi work properly on a standalone management?
Any suggestions are apprectiated
Old 06-17-2010, 11:19 AM   #295
I've asked my tuner your question, Parmas.
But what did GoTech say? Since it's their tuning computer, they should be able to answer most of your questions.
Old 06-17-2010, 11:27 AM   #296
Parmas
Parmas's Avatar
I am awaiting response from them but certainly many engines that work with pulse modulation frequencies vary from engine to engine model. I think at this point it is more a Toyota thing than Gotech but thats just me.
What does the tuner told you about this Garm?
Old 06-17-2010, 11:46 AM   #297
Parmas
Parmas's Avatar
Here is a link for the sake of the people who don't know what we are discussing about: Pulse width modulation frequency
http://autospeed.com/cms/title_Perfo...4/article.html
Old 06-17-2010, 12:18 PM   #298
The AEM EMS has a wizard for Toyota motors, I believe it automatically sets parameters for VVTI. So I'm not sure I'll be able to answer your question, but Art is going to look into it further.
Old 06-17-2010, 12:28 PM   #299
Parmas
Parmas's Avatar
You are a life saver thank for your support and God Bless your management
Current Setting are :
- Frequency @ 60Hz = 3600rpm / minute
- DutyCycle @ 7.1% = 4.25s / minute
What do you think about the other issues I mentioned apart PWM?
Old 06-17-2010, 04:02 PM   #300
rob323
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car
To me, it sounds more likely that the problem is the engine management, than the engine. Might be cheaper to use something like Adaptronic which utilises all the factory sensor & igniters and has continuously variable control over the vvti.
I'll pm you an email conversation I had with Adaptronic recently.
rob323 is offline   Reply With Quote
Old 06-17-2010, 04:49 PM   #301
Parmas
Parmas's Avatar
I checked the specs of the e420c and seem that VVTi isn't mentioned but as you sent me the pm it seems it can eventually.
I am going to give the last try to the present management if tuning fails again then I have to change it to another that accepts VVTi or I have to consider removing VVTi completely like many honda removing Vtec.... will see what comes up next
Old 06-17-2010, 05:23 PM   #302
rob323
Yes, that was why I emailed them. To make sure.
I haven't played enough with these motors to find out just where the cam sits when the vvti solenoid is unplugged but maybe that is the best way for you to do it now unless you can get the continuously variable control working.
Old 06-17-2010, 05:57 PM   #303
^ we know that works too. Just not as much control in tuning.
Old 06-17-2010, 11:24 PM   #304
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
It reverts to the 0° position.
Old 06-17-2010, 11:28 PM   #305
rob323
So does the vvti just retard the cam, or advance it?
Old 06-18-2010, 04:48 AM   #306
Parmas
Parmas's Avatar
The VVTi retard and advance the camshaft angle based on the engine:
- RPM
- Temperature
- Load
If you see the image below you can notice that the camshaft is being advanced or retarding according these factors. Although there are six diagrams of camshaft angles, three of them are matched with others. I marked them for you to understand with ease.
It is hard to notice correctly if the overlaps are the same but if you see accurately, the camshaft angle figures are labeled with a 7-digit number. Some of them are actually the same label so it makes me think that infact they are at the same position.
So lets make a summary of this:
Camshaft Angle 1 - Fully Retarded
During idling \ Light Load (1a) = At Low Temperature (1b) = Upon Starting \ Stopping Engine (1c)
Camshaft Angle 2 - Fully Advanced
At medium Load (2a) = In low to Medium Speed Range with Heavy Load (2b)
Camshaft Angle 3 - Retarded but more advanced than Angle 1
In High Speed Range with Heavy Load
Still.... if you notice the 2nd and 3rd diagrams you will notice that the valve has only two ports and not three, which I am thinking are Angles 1 and 2. So that makes me think, where would the valve be at Angle 3?
Motor Longevity Pavel Olavich DIY / Maintenance / Service 10 03-17-2012 11:43 AM
cali yaris built motor cali yaris Performance Modifications 83 09-03-2009 11:08 PM
Fan motor noise... 500snakz General Yaris / Vitz Discussion 10 12-01-2008 02:43 AM
Exchanging Motor on a Liftback 1.3 Lt weckjuan Performance Modifications 8 11-12-2006 10:58 AM
