#19 | |
![]() ![]() ![]() ![]() Drives: 2010 Yaris S Join Date: Apr 2010
simply sick...how does one go about acheiving -4 camber? Are you running two set's of camber bolts per shock in the front? |
#20 | |
haha so true |
#21 |
07 Liftback
Drives: 2007 Yaris liftback black Join Date: Oct 2009
Your correct running two spc camber bolts for the front Thanks to Garm for his knowledge and also to his shop micro image for setting me up with those bolts.
#22 |
4dr=FTW
OK so I got the wheels on today. didnt expect to cuz I ordered the tires a tad late (noon) but got them on before the day was over, Im not real happy whith the wheel setup but thats what I get for listenin to the discount tire guy and not my drift buddies :P
![]() the wheels are Axis OG oldschools 15x8 +25 offset (aoe springs stock shocks) and the poke is good but now I cant move if someone sits in my back seat lol I was wonderin blackvits how much and how difficult is the camber kit. and what suspension are you runnin
HAA HAA .... dangly parts
#23 | |
Drives: yw calls me douche and racist. Join Date: Aug 2007
Your setup is very similar to mine. Low, rims, random bars on the back. |
#24 |
Drives: yaris 4 doe Join Date: Jun 2010
That MR-S on the 1st page is funny.
What kind of exhaust is that? ![]() Mr "Track Attack" |
#25 |
I feel a little poke commin' through.. on you...
#26 |
Super Newbie
Drives: 2007 Yaris Liftback White Join Date: Jul 2007
jaytee, what is the tire size for your setup?
Looks like the right tire size for the wheels but the wrong size to make those wheels fit on the car. |
#27 |
4dr=FTW
225/50/15 and they the ideal fit for the wheels as far as an oem look is concerned but I wanted it to look a tad more . . . Radical lol, ie shorter tires and stretched rubber so on so forth but I'm stuck with them for now
#28 |
Slowy getting there
Haha... Should have went 225/45 to avoid the rub on the rear. Do a DIY on rolling your fenders.
#29 |
Slowy getting there
The MR2's exhaust is a custom setup with Super Trapp mufflers and they sound freaking amazing!!!!!!!
#30 |
07 Liftback
To answer your question JayTee the camber kit is not that expensive or really hard to put in I Just used 2 front Eccentric style bolts from Spc on both front shocks, actually got the kits from Garms shop Micro Image online and made my own Shims for the rear all it is a thicker washer like Penguin makes with the top grinded off them with camber u should be able to minimize or even take care of the rubbing issue those shims basically just go behind the rear hubs...really easy install, oh I'm just running Tein basic coilovers with one locking ring removed from the rear cause it's maxed out anyway with just Trd rear sway that's all....I probably would have gone with a 195/50/r15 to give it a stretch for some clearance as well.Instead of he 205's that u runnin would help give it some clearance as well or if you want more maybe 185/45/r15.
#31 |
07 Liftback
And yes ddongbap you probably did see me around before no I actually work at Tustin Lexus tech over there...righT next door to Tustin Toyota small world for sure lol...
#32 |
Super Newbie
185/55 would of worked out well.
Take it back and complain, the tech recommended it and now you cant have passengers in the back seat. And btw, that MR-S has some ugly wheel/tire setup.......i hope you are some badass on the track cause that shit looks ugly....lol |
#33 |
#34 | ||
4dr=FTW
![]() Quote:
oh and better pics comin up
#35 |
4dr=FTW
| Will this work? | umm_bacon | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 09-10-2007 10:16 AM |
| My Work, Your Work - Stories and Fun | SmallCarGuy | Off-topic / Other Cars / Everything else Discussions | 0 | 09-02-2007 08:43 PM |
| Anyone in So Cal needs work on their Yaris | Bdaslug | California | 24 | 08-26-2007 06:10 AM |
| need 17inch rim guidence | chino_potato | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 46 | 04-09-2007 01:09 PM |
| Yarisworld Parts List - Work in progress | vodkalush | General Yaris / Vitz Discussion | 5 | 02-13-2007 07:12 PM |
