#163 |
WCOAST CANADIAN DRIVER!!!
Drives: 2010 Hatch 5DR - AUTO/AC Join Date: Jun 2010
In Chilliwack, BC, Canada - where I bought my new 2010 Yaris Hatch 5 dr - I was told that all I had to was bring it in every 8000KM - and it'd run perfect thru to 200,000 KM's. (I was also told to budget about 1.9 cents per KM for potential maintenance.)
#164 | |
![]() ![]() ![]() ![]() ![]() Drives: 07 Yaris S Sedan 5-Speed Join Date: Oct 2008
I don't believe it either. Sure it's possible, but I'm certain this isn't a common issue by any means but rather a rarity. There are a number of high mileage Yaris's that have reported no issues. Mine is at 85,000 miles and shows no sign of wear and is repair free. |
#165 |
![]() ![]() ![]() Drives: 07 Yaris LB Join Date: Aug 2007
I know is hard to believe that such simple part like a water pump will fail so soon, I almost don’t believe it either when this happened to my yaris, most of the cars know days can do more than 120K w/o replacing the water pump but on 1nz-fe its common, even the prius has the same problem, I was told by the mechanic at the Toyota dealer that they replace them all the time.
The yaris is not the first car I owned and surprisingly it’s been the one with more defects. When I traded my 350z for the yaris I did it for gas economy and good quality, the Z was amazing in quality but I needed a 4 seater. Here are few pictures that show my WP leak and know my GB |
#166 |
![]() ![]() ![]() Drives: 2010 Prius, 2007 Yaris Sedan Join Date: Oct 2009
I had that same pink crust on my WP, and the typical pink marking on the underside of the hood. I believe it had only leaked for a short amount of time and stopped somehow, as it was just all crust, not wet at all, but I went ahead and replaced it anyway. I also changed out the long life coolant to regular stuff. I hope I did the right thing there, as the long life coolant seems to be the problem for these water pumps...
#167 |
What is the general cost of replacing the water pump on a Yaris at a dealer or typical shop (with labor)?
#168 | |
#169 |
If that's the case, then great. But from what I have read on here with the W/P problems, that was the main thing that seemed to be the problem. This is all second have from what I have read.
#170 |
The coolant may be a good reason for the WP to go faster, probably Toyota pink coolant doesn’t lubricate the pump the way it should, if that’s not the case the 1NZ-FE water pump is made with cheap materials and wear fast...
#171 |
Its a mysterey to me why this happens. ECHOs had the same water pump/coolant and I NEVER saw a post about the wp going.
#172 |
![]() ![]() Drives: NONE Join Date: Oct 2008
#173 |
"LibertyRides!"
Drives: 2010 Yaris 3Dr LB | 2020 Stang Join Date: Mar 2010
Just turned over to 5,000 miles on my way to work this morning... almost six months old! Only a routine oil change so far...
*NO PROBLEMS* Cheers!
~ Mark ~ 2010 Yaris 3-Dr Liftback, 5-Speed Manual, P185/60R 15, Bayou Blue Pearl I Love my YARIS Most miles Tank: 538 tank/10.148 gal = 53.015 MPG / Most MPG: 54.95 MPG (ethanol) 425 tank/7.73 gal "The evils of government are directly proportional to the tolerance of the people." -- Frank Kent |
#174 |
I'm hitting 60k miles never had a problem regular synthetic oil changes, used only premium 93 gas only since day 1. Have the NST pulley set as well on the water pump, might have to replace it soon since a nice groove is showing up on my pulley.
a.k.a. "Aothachos"
#175 |
![]() ![]() ![]() Drives: 2010 Yaris "5-door" Join Date: Mar 2009
"premium" (as in price) gas in a Yaris? Why on Earth?
#176 |
You're just wasting money on 93. The Yaris is tuned for regular 87. Running higher may actually have a similar adverse affect as running regular in a premium car.
#177 |
Audio Junky
51,500k miles/2.5yrs and going strong. Still just one repair on an axle seal @ 13k miles. Running 10k synthetic oil intervals with 5k filter intervals. Stock everything, only mods are tints, subs, and scanguage. Should be close to 60,000 miles by september. My car is about to become a work tool, so i'll probably jump from doing 20k a year to 25-30k a year.
#178 |
![]() Drives: 2007 YARIS 3 DR HATCHBACK Join Date: Oct 2008
OTOWNYARIS....If you have not seen my post about the TSB EG048-07 you might consider looking at it. This TSB outline the replacement of the defective fuel tank
fillerneck cover....if the failure occurs outside your warranty period the canist/filter parts cost is near $1000 from your pocket..... Check your VIN # and see if it applies to you... it happened to me the FIRST time I took a 2 hour drive in a constant rain... |
#179 |
![]() ![]() Drives: Mazda Protege5 Join Date: Jan 2007
We have updated results for the Yaris to include owner experiences through March 31, 2010. In terms of repair trips per 100 cars per year:
2009: 20 participants, no repairs reported yet 2008: 7 2007: 20 All are very low, and much better than average. We have two additional statistics, "Nada-odds" and "Lemon-odds," to indicate the percentage of cars with no repairs in the past year and those that required 3+ trips to the repair shop. In the case of the Yaris, the percentage with no repairs is about 87 for the 2007 and 92 for the 2008, and the percentage of lemons is less than one for both years. A big thank you, once again, to everyone who has been helping. We'll have further updates in August and November. With more participants, we could provide more precise information and provide all three stats for all model years. Especially need more 2009s and 2010s. To see how competitors compare, and to sign up to help improve this information: Toyota Yaris reliability comparisons |
#180 |
Updated stats in a couple of weeks.
Sample sizes are small for the 2009 and up--especially need more participants for these years. To help provide better information on your year: Car reliability research |
| News : 2007 Toyota Yaris - the little Euro's official arrival | VitzBoy | General Yaris / Vitz Discussion | 9 | 06-06-2017 01:51 AM |
| Toyota Yaris to Sponsor FOX's "Prison Break" | YarisBueller | General Yaris / Vitz Discussion | 0 | 04-30-2006 09:01 PM |
