Old 06-24-2010, 01:13 PM   #1
big lo
big lo's Avatar
Drives: 2007 VIOS
Fog light question
I was wondering, can the stock foglights stay on, when using the the Hi beams? Is their a way I can have them on when the headlights are off? I ask this question because to day I will be doing a retrofit on the headlights and putting the halo wires to the parking light, it would look better to have the fogs on with the halos. My problem is since my car came with the stock fogs the wires dont allow you to run with them on, only when you turn on the headlights. Wondering can I splice the wires to the parking lights to have it functioning, plus the fogs are HID so I dont want to over charge the wires, can anyone help me with this pickle? Holla at me please.
Old 06-24-2010, 01:44 PM   #2
If you have the OEM ones where you have the fog light switch as part of the headlight stalk then do the following to allow them to come one with either the high or low beams:
Take the wire that is in pin 4 of the headlight stalk (it will be orange, beige or white, depending on year and if you have DRLs) and cut it (leave yourself some room on either side of the cut to be able to work with the wire.
Take the harness side of the cut wire and cap it off.
Take the connector side of the wire and tap it to the white wire in pin 13.
Old 06-24-2010, 01:48 PM   #3
Brian
Brian's Avatar
Are you still using the projector fogs? If you are, remove the factory foglight harness and use the one that comes with the kit. You should be able to turn them on/off whenever you want.
Old 06-24-2010, 02:02 PM   #4
big lo
big lo's Avatar
Drives: 2007 VIOS
Attachment 34678
Thanks for the info, just to let you know my is the 2007 sedan S class. Now as for the harness thats located to the fuse box correct? The colors that are here is red, green, light green and two that are spaced with green and grey, so run that by me again please.
Old 06-24-2010, 02:06 PM   #5
The connector pictured above is under the lower steering column cover on the left side, right at the base of the headlight switch.
Old 06-24-2010, 02:12 PM   #6
big lo
big lo's Avatar
Drives: 2007 VIOS
Good looking Brian, your info will be sorted out as well, just need that extra push. Holla at me. I will post the out come tonight, after all has been done.
Old 06-24-2010, 02:19 PM   #7
big lo
big lo's Avatar
Drives: 2007 VIOS
Good looking out CT that was very helpful, like I said I will post up the out come tonight, thanks you & Brian for being so supportive to my project. Holla at your boy.
Old 06-24-2010, 05:49 PM   #8
heeroyuy01195
Post count means nothing.
Drives: AW11, NCP91, Old Motorcycles
is there any way to get the OEM foglights to turn on by themselves without the headlights?
heeroyuy01195 is offline   Reply With Quote
Old 06-24-2010, 06:27 PM   #9
IllusionX
Drives: 07 Yaris Sedan Aero
CTScott: what does pin 13 do?
Old 06-24-2010, 07:57 PM   #10
Yes - Instead of of connecting the wire from pin 4 to pin 13, connect it to pin 11 (which is a white wire with a black stripe). Then, it will turn on with or without the headlights.
Old 06-24-2010, 07:59 PM   #11
Pin 13 is the feed to the relay coil for the taillights. It gets switched to ground when the headlight stalk is in any mode except off.
Old 06-24-2010, 08:37 PM   #12
big lo
big lo's Avatar
Drives: 2007 VIOS
CT thats what I want to do. I want to be able to turn on the fogs when I want should I follow this quote and forget what you had sent to me? Holla my dude.
Old 06-24-2010, 08:53 PM   #13
Yes. To make it easier for tapping the wires together (so you are tapping same sized wires together), connect the wire from pin 4 to pin 7 (the smaller white wire with a black stripe, 3rd from the right in the picture above).
Old 06-24-2010, 09:03 PM   #14
big lo
big lo's Avatar
Drives: 2007 VIOS
Ok, with this then I will be able to turn on & off from the stalk switch correct? And thanxs again my dude.
Old 06-24-2010, 09:53 PM   #15
Yes. But, with this wiring change you will be able to turn on the fogs without turning on the headlights.
Old 06-26-2010, 10:52 AM   #16
big lo
big lo's Avatar
Drives: 2007 VIOS
Alright, I tried that option, and the HID was making noise, and the plug wasnt plug in so I put back the wire the way it was, maybe I connected the wrong wire, but you said the the third wire to the right (white with a black line), I heard that noise and just put back the wire. If you have a option that I can run with holla, and if possible with a pic of the harness with plug and the right wire to use. Please hit me up when you can thanxs.
Old 06-26-2010, 12:32 PM   #17
The plug definitely needs to be plugged in, other wise things are floating, and that might be why your HIDs were clicking. the connection point is the 3rd from the right.
Old 06-26-2010, 12:42 PM   #18
big lo
big lo's Avatar
Drives: 2007 VIOS
So should I disconnect the HID from the fogs, try what you wrote again when finished then connect them again? And yeah they were clicking, I was worried about that, and put the wires back the way they were. Holla at me CT.
Sorry! Another fog light question. Jrilla DIY / Maintenance / Service 4 08-23-2009 02:25 PM
fog light lens question? Adriaan Cosmetic Modifications (Exterior/Interior) 0 04-13-2007 11:30 AM
question on Fog light clfile Cosmetic Modifications (Exterior/Interior) 6 11-09-2006 07:11 PM
