Old 07-05-2010, 03:25 PM   #1
brg88tx
Drives: 07 Yaris Sedan, Auto
good way to guestimate your mpg using the digital gas gauge
in the short time i've owned my yaris sedan i have figured that the first bar is good for about 75 miles, then about 50 miles per bar thereafter. going by this rough estimate that's 425 miles/11.1 gallons for 38.3 mpg.
you can use this a a rough gauge to see whether you are above or below 38.3 mpg while you are driving around. for example, when you are at about half a tank if you have over 225 miles when the fifth bar drops, you are above 38.3 mpg approx.
brg88tx is offline   Reply With Quote
Old 07-05-2010, 04:40 PM   #2
brg88tx
sorry, i meant to say if you are at 225 miles when the 4th bar drops you are on pace to beat 38.3 mpg.
Old 07-05-2010, 06:40 PM   #3
daf62757
Nothing beats a Toyota!
daf62757's Avatar
Drives: 2013 Yaris 5 dr liftback
I have found that the last three bars get less than 50 miles. They usually get around 40 miles.
Big Dave
Indianapolis, IN
Synthetic Oil....its in my car.....for at least 10,000 miles!
daf62757 is offline   Reply With Quote
Old 07-05-2010, 07:48 PM   #4
big lo
big lo's Avatar
Drives: 2007 VIOS
That goes to show ya, that the Yaris is good on gas mileage. And you save a dollar or two in you pocket.
Old 07-06-2010, 11:03 AM   #5
daf62757
daf62757's Avatar
I just wish Toyota would have spent a few more dollars on:
1. better instrument cluster
2. larger gas tank...at least 15 gallons
3. insulation or sound proof material
Big Dave
Indianapolis, IN
Old 07-07-2010, 01:15 PM   #6
brg88tx
well, on my way to work my 4th bar dropped at 224 miles, so i should be just about on pace for a 38 mpg tank. i'll let y'all know how it turns out.
Old 07-09-2010, 05:32 PM   #7
b_hickman11
Drives: 08 Sedan
Then it would cost more than a Corolla.
Old 07-09-2010, 05:33 PM   #8
b_hickman11
Drives: 08 Sedan
Not very accurate way of getting your mpg. I have got up to 120 miles on the first bar before.
Old 07-10-2010, 12:10 AM   #9
Ryude
Drives: 2007 Ford Mustang GT
I don't understand how hard is it to simply use a calculator and divide miles by gallons at the pump.
Ryude is offline   Reply With Quote
Old 07-11-2010, 12:27 PM   #10
daf62757
daf62757's Avatar
I don't think so. It would cut into Toyota's profits but I don't think it would cost more than a Corolla.
Big Dave
Indianapolis, IN
Old 07-11-2010, 04:12 PM   #11
brg88tx
it's not "hard" at all, i simply posted this as a way to guestimate your mileage between fillups without the use of a scanguage or ecometer.
Old 07-12-2010, 01:19 PM   #12
KrazyDawg
KrazyDawg's Avatar
Drives: 08 3dr LB AT
I'm usually good for around 70 and if I'm doing bad it's around the high 60s. I also noticed every bar was 50 miles after. On the second bar, I would get 120 or if if I drive slower than 65, I'll get more than 130.
KrazyDawg is offline   Reply With Quote
SO I RAN OUT OF GAS THE OTHER DAY ROCKLAND TOYOTA General Yaris / Vitz Discussion 76 10-23-2008 02:02 PM
Single DIN Digital Gauge Cluster Galavoxx Performance Modifications 11 12-29-2006 03:09 PM
