Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > Middle East
Old 07-08-2010, 07:22 AM   #19
amaze_2
amaze_2's Avatar
Drives: 2008 yaris
@duke diba 2008 din ang modelo ng yaris mo? ako 2008 din 82twkm ang natakbo ko. ayos pa naman ang hatak.?anong symtoms pag kailangan na natin mag palit ng fuel filter?
amaze_2 is offline   Reply With Quote
Old 07-08-2010, 07:28 AM   #20
nazier
black shark
nazier's Avatar
Drives: black toyota yaris t3 sprit
Originally Posted by duke_afterdeath View Post
F.I.Y.
Recently I replace my fuel filter for my yaris sedan and I was amazed (i think syntax to was amazed) when we found out where the fuel filter located.
Check the picture below, it is under the rear passenger seat of your car.
what ever you do dont fuck up the seal, u will have problems like im having now the dealer some how stuff it up twice now, when u fill the car will leak fuel and it will smell,
www.justbabynappies.co.za
nazier is offline   Reply With Quote
Old 07-08-2010, 07:31 AM   #21
duke_afterdeath
duke_afterdeath's Avatar
Drives: 2008 Yaris Sedan
kapag naka idle ka parang mamamatay ang makina nagba vibrate sya mararamdaman mo din sa kuryente sa AC sumasabay ung power kapag nag gas ka..symptoms din ito ng baradong trottle,, dahilan nman ng bardong trottle, iwasan daw sa carwash spray ng tubig diko alam futher reason pero un lang nakuha kong info, maybe the water somehow gets into the trottle...
45k na yata takbo ko...
cguro lang dahil na din sa madalas ako magrefill na nagblink na indicator kaya na pump na pati residue ng gas
duke_afterdeath is offline   Reply With Quote
Old 07-08-2010, 07:44 AM   #22
amaze_2
amaze_2's Avatar
Drives: 2008 yaris
thanks duke sa info. kasi ako talagang pag 3bars or 2bars nilalagyan ko na agad kasi advice din sa akin ng mechanic makasira ng fuel pump pag nag empty.
Old 07-08-2010, 11:50 AM   #23
duke_afterdeath
thanks nazier,, so far no leak at all
Old 07-11-2010, 09:00 AM   #24
zsazsa zaturnnah
zsazsa zaturnnah's Avatar
Drives: 2010 Yaris YX
My 2nd car Daewoo Lanos nuon! Pupugak-pugak! Pumapasok sa primera pero halos agaw-buhay sa segunda! Go agad ako sa Doha (mga tropang mekaniko), hayun kakaexplain ko lang, binuksan ang likod at binaklas ang upuan ... voila ... Indiana Jones and The Lost Fuel Filter ... pareho lang pala sila ng Yaris!
Sabi sabi hindi nga daw maganda halos nasasaid ang gasolina kasi nasisipsip ng fuel filter ang mga residue kaya bago daw mag blink eh fill up na ng gasoline!
zsazsa zaturnnah is offline   Reply With Quote
Old 07-11-2010, 09:20 AM   #25
syntax
syntax's Avatar
Drives: Yaris Sedan 2010 "shadow"
correct ka dyan zsazsa at masama daw sa fuel pump ang halos wala ng gas sa tangke dahil un ang nagpapalamig sa kanya.
syntax is offline   Reply With Quote
Old 07-11-2010, 11:35 AM   #26
duke_afterdeath
plangak!!! hehehe...
Old 07-12-2010, 02:17 AM   #27
zsazsa zaturnnah
Bwahahahaha ... you're learning ... hindi ka na maibebenta! Bwahahaha!
Old 07-12-2010, 02:31 AM   #28
syntax
syntax's Avatar
duke?
Old 07-12-2010, 05:26 AM   #29
duke_afterdeath
Originally Posted by syntax View Post
duke?
Yaris Oil Change DIY rningonfumes DIY / Maintenance / Service 91 01-11-2019 08:18 PM
The Nitrous Thread ChinoCharles Performance Modifications 116 02-16-2016 04:07 PM
Yaris Fuel Pump HTM Yaris General Yaris / Vitz Discussion 12 03-22-2012 04:34 AM
Change to high quality filter lead to drastic drop in fuel efficiency lh59 DIY / Maintenance / Service 19 07-02-2009 03:22 PM
Fuel Filter abbeyaris General Yaris / Vitz Discussion 35 03-22-2009 12:40 PM
