Old 08-12-2010, 08:13 PM   #1
Jason@SportsCar
xB final drive swap
If anyone is interested, we have done the xB final drive (4.312) swap in our Yaris, fits and works perfectly.
Parts needed from Toyota/Scion:
33321-52110* this part has been superseded new number is 33321-52111 output shaft
41221-52270, ring gear
90105-11040, ring gear bolts (8)
Depending on mileage you may also want to replace bearings and seals, but you don't need to source those from Toyota.
Old 08-12-2010, 09:23 PM   #2
2manywheels
Drives: 09 YarHB
Thanks for the info man!!
CUrious.. what does that do for the Yaris??
2manywheels is offline   Reply With Quote
Old 08-12-2010, 09:25 PM   #3
Jason@SportsCar
Makes it accelerate quicker.
Old 08-12-2010, 09:27 PM   #4
2manywheels
Drives: 09 YarHB
So.. if I had a second motor that was being "built" this could be a great addition to the package? I am assuming this is for the manual tranny
Old 08-13-2010, 01:07 AM   #5
darkMINI
Drives: 08 hatch
It works for manual or automatic, it changes your gear ratio. Similar to running shorter tires. Of course you will lose top speed considerably and your speedo will be off(reading faster than you are actually going), so if you do any highway driving ... you will be sad. :(
Nevertheless it's an awesome mod for the track and would probably benefit from the addition of a limited slip differential as well.
'08 3dr HB, Black Sand, AEM, 16x6.6 Mini-Cooper wheels, DynoMax, Cruise, de-TPMS'ed.
darkMINI is offline   Reply With Quote
Old 08-13-2010, 01:45 AM   #6
Jason@SportsCar
The car will be quicker all the way to the 117mph speed limiter. Ever driven an xB, this is the same gearing.
You would think the speedo would be off with a gear change... But Toyota must be pulling the signal from the output shaft, or axle, because ours did not change at all. Its not like doing a gear change in a rwd car where the signal is pulled from the trans.
Old 08-13-2010, 02:09 PM   #7
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
RING GEAR part# for AUTOMATIC is: 41221-52090.......
Old 08-13-2010, 04:12 PM   #8
hatchbackkid82
Drives: .
Just called my local dealership they want about $580 for all the parts Any one know if this mod is really worth the cost of the parts and the hours spent taking the tranny apart?
Why not just get the XB tranny?
Old 08-13-2010, 06:51 PM   #9
Tamago
Tamago's Avatar
Drives: ZZW30
if it's worth it to you to have shorter gears, then it's worth it
the actual transmission case will not fit without modification (from the xA or xB) in the yaris (confirmed by Morgan)
however, you could purchase a used xA/xB transmission from car-part.com or a local junkyard for less than $200 and disassemble it yourself, you'd only need to buy wear-parts from toyota.
be careful that you don't purchase a transmission from an older ECHO, as they have a 6bolt ring gear, and the scions have an 8bolt ring gear.
i personally HATED the short gearing in the scion. 4300rpm at 80mph was annoying, and did not yield very good mileage. the ECHO transmission i had in the xA was awesome, and my mileage improved almost 10%. the only time i missed the shorter gears was on very tight autocross courses.
Old 08-13-2010, 07:27 PM   #10
hatchbackkid82
Drives: .
HOLY CRAP 4300rpm at 80 mph
It's like you were always in VTEC
That would be hell for me considering, I have a modified nitto mid pipe with one resonator
Old 08-14-2010, 08:27 AM   #11
Tamago
Tamago's Avatar
Drives: ZZW30
to answer the speedo question from earlier:
because the speedo ring gear turns the same speed as the axles, changing the ratios before it would not affect your speedometer readout.
it's possible that ABS equipped yarii derive speed from the wheel sensors themselves, but that would be a question to be answered by CTscott or someone who's looked over the ecu wiring for ABS/NON equipped cars.
Old 08-14-2010, 10:17 AM   #12
You can pick up an xB trans for less than $500 and just pull the parts from that.
Old 08-14-2010, 10:34 AM   #13
Tamago
Tamago's Avatar
Drives: ZZW30
however, you could purchase a used xA/xB transmission from car-part.com or a local junkyard for less than $200 and disassemble it yourself,.
exactly ;)
Old 08-16-2010, 06:43 PM   #14
Jason@SportsCar
Just make sure if you are going to the trouble to do the gear change you put in an LSD at the same time.
Old 08-16-2010, 06:45 PM   #15
Jason@SportsCar
WOW, we got ours from TRD for a fraction of that. TRD racer support program: http://www.trdusa.com/thegarage.cfm?team=grassroots
And after racing the car at Miller this past weekend, the gear change has been one of the most effective mods yet.
Old 08-16-2010, 06:59 PM   #16
2manywheels
Drives: 09 YarHB
Any footage from Miller?? :)
hehe..
Video whore here.. lol
Old 08-16-2010, 07:00 PM   #17
Jason@SportsCar
hehe..
There will be.
Old 08-16-2010, 07:03 PM   #18
2manywheels
Drives: 09 YarHB
Woohoo!!
Thanks for keeping us on on your trials and ventures!!!
Yaris Motor Swap Thread *Read before posting swap threads* Sabretooth Performance Modifications 219 06-10-2025 03:58 PM
TRD final drive hare Performance Modifications 10 01-15-2010 01:19 PM
Final Drive t0m4s Performance Modifications 17 04-11-2009 04:16 PM
Final Drive t0m4s Central and South America 0 04-07-2009 07:06 PM
final drive rx100 Performance Modifications 2 08-21-2007 02:26 AM
