View Poll Results: Would you buy one?
No 5 5.10%
Yes (for $75) 46 46.94%
Yes (but it would have to be less than $75) 7 7.14%
Yes (but I still want it to also display the time) 40 40.82%
Voters: 98. You may not vote on this poll
Old 08-15-2010, 11:11 PM   #451
What I'll most likely do is install 2-3 in relatively local cars. That way, if they find any issues that require software fixes, I can easily reflash them.
Old 08-15-2010, 11:36 PM   #452
swidd
Drives: Yaris HB
So who's moving to Connecticut with me? uuuuhaul!
swidd is offline   Reply With Quote
Old 08-16-2010, 07:01 AM   #453
Lewis
Our off road vehicle
Lewis's Avatar
Drives: 2009 Yaris 3dr
central NJ close enough Scott?
Lewis is offline   Reply With Quote
Old 08-16-2010, 08:34 AM   #454
dean_park
Drives: 2011 VW Golf TDI
If it's a serial reflash, I should be able to handle it. I'm a mechanical engineer but I dabble on the sparky stuff.. I do flash firmware on a lot of our equipment and our vendors equipment. I'm also originally from RI (even lived in Middletown CT for a year), so I used to be local....eh, probably doesn't help.
Should I just send my resume for consideration? lol
dean_park is offline   Reply With Quote
Old 08-16-2010, 11:13 AM   #455
The YarGauge uses two microcontrollers - One for the display and analog inputs and the other for the CAN bus communications. The CAN bus one requires a JTAG interface for programming.
Old 08-16-2010, 12:01 PM   #456
POORSHA
POORSHA's Avatar
Drives: 2008 LB
I live in Dayville ct and am willing and able to be a test subject. Ok not me but my car.
POORSHA is offline   Reply With Quote
Old 08-17-2010, 08:05 AM   #457
CheapOldGuy_v1.1
Frugal and middle aged...
CheapOldGuy_v1.1's Avatar
Drives: 2008 Meteorite Metallic AT LB
I'll volunteer! I live one town north of where you bought your car in south central MA. My 08 LB is best 14K I ever spent. I'm also very familiar with the tech side.
______________________________________
CheapOldGuy_v1.1 is offline   Reply With Quote
Old 08-17-2010, 04:03 PM   #458
advocate
Drives: car
Hrmm I'm all the way in california but we use JTAG here at work to program our drives!
Old 08-17-2010, 04:55 PM   #459
Revsson
Noobs to the back of the line!
j/k
Old 08-18-2010, 01:34 PM   #460
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
I have a USB JTAG Cable, I would buy a full working product when it comes out if it integrates nicely, I just can't tear apart my gf car just to test stuff :( Wish I could.
Old 08-29-2010, 10:51 AM   #461
IsLNdbOi
IsLNdbOi's Avatar
I hope these are finally available by Christmas!
Old 08-29-2010, 04:34 PM   #462
I found a new LCD this week that I am hoping will overcome the sunlight visibility issue. It is an OLED display, which is supposed to have excellent sunlight visibility. I should be receiving my sample this week to test.
Old 08-29-2010, 04:35 PM   #463
IsLNdbOi
IsLNdbOi's Avatar
Good to hear. I thought those things were in very short supply. How does using an OLED display affect the final price?
Old 08-29-2010, 04:49 PM   #464
OLED displays are finally becoming readily available and no longer crazy expensive. The original LCD was costing me $12 and the OLED is $72 in quantity, but to have true daylight readability will be worth the extra cost. This display was over $200 when I looked at it a year ago.
Standalone devices like the scangauge can get away with <$10 LCDs, because of location. The killer for the YarGauge is having it recessed behind the smoked plastic of the cluster.
Old 08-29-2010, 05:36 PM   #465
Lucas13
Drives: 07 Yaris LB
A non smoked lens will do the job as well right? maybe finding some way of reproducing the same lens but in clear and at the same time everything else will be mo readable during the day what will be cheaper the OLED display?
Lucas13 is offline   Reply With Quote
Old 08-29-2010, 06:15 PM   #466
sleey0
Drives: 2008 Yaris LB
Unless it is Super-AMOLED, which I highly doubt, you have it backwards.
OLED displays are very nice and produce rich colors and deep blacks, but their worst flaw is daylight visibility, which is pretty weak. I wish OLED had great visibilty in the sun but they do not. The reason being is there is no backlight which is found on a traditional LCD. Instead, it uses a bioelectrical chemical to light and this washes out badly in the sun.
Just warning you before you make a mistake and buy them.
sleey0 is offline   Reply With Quote
Old 08-29-2010, 07:48 PM   #467
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
CTScott, I use to use this mp3 player back in high school - http://asia.cnet.com/reviews/musicpl...6925p-1,00.htm
It used OLED technology and I was able to read song titles walking around the border of the school during lunch time in the sun.
I don't think it should be a problem i the YarGauge as well because the cluster sits a little angled down in the area, doesn't it? it isn't directly sitting flat per say....at least when you install/remove it, it mounts a little tilted...
Old 08-29-2010, 08:23 PM   #468
That was my impression as well. The VAR that is sending me the samples claims that they are a vast improvement over earlier generations of PMOLED displays. I guess we'll see. As Kioshi mentioned, the display is not in direct sunlight, so perhaps the high contrast ratio behind the smoked lens will do it. The gas gauge is just a backlit transflective LCD, but it is a higher contrast one than I've been able to source.
in dash clock as tach? Cosmonaut In Car Entertainment + Electronics (audio / video / alarm) 10 07-12-2010 12:27 PM
digital tach, 52mm, preferably blue leds severous01 Cosmetic Modifications (Exterior/Interior) 5 05-15-2009 11:58 AM
Digital Tach nqd Performance Modifications 4 05-17-2007 01:04 PM
