Old 09-11-2010, 01:16 AM   #1
Swallow
Swallow's Avatar
Drives: Yaris Sedan YRS
Question Missing Screw from Engine Compartment
Hi everybody,
A few days ago I took my Yaris (Sedan YRS 2008) to the dealer for regular maintenance service. They told me there is something wrong with oil pan and that the oil pan should be changed. After I got back the car, I took a look at the engine compartment and I FELT there is a screw missing in the engine compartment ( red arrow and red circle)
Could you please take a look at your engine and tell me if my guess correct?
http://i55.tinypic.com/2v8lrn7.jpg
Thank you in advance
ONLY YARIS !
Swallow is offline   Reply With Quote
Old 09-11-2010, 11:17 AM   #2
Klink10
Klink10's Avatar
I've looked at various pics of other engines on this site. I could not see a screw in any of those either. I would ask that you check yours again to see how deep the recess is. I believe it is there as an attachment point and would not get a screw until whatever goes there gets well...attached. Don't forget these engines are used in other applications and in those something may be affixed at that point.
Old 09-11-2010, 12:23 PM   #3
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
I don't think you have to worry. On the 3 dr that is used to tie down a wiring harness.
Old 09-11-2010, 02:23 PM   #4
2007yariz
Drives: Yaris sedan
Yep i looked at mine, the middle one stables the wire with a that screw.
2007yariz is offline   Reply With Quote
Old 09-13-2010, 08:26 PM   #5
Swallow
Swallow's Avatar
Thank you for everyone's reply.
Anyone with a Yaris Sedan model?
ONLY YARIS !
Old 09-14-2010, 08:04 AM   #6
Swallow
Swallow's Avatar
ANY IDEAS?
ONLY YARIS !
Old 09-14-2010, 10:28 AM   #7
BLH
Drives: 2007 Yaris Sedan
My left driver side 2007 Sedan has a wiring harness for the ECU there with a fastening mount.
I did not see any harness in your photo. I do see what looks like a Master Brake Cylinder Reservoir that is on the other side of the engine compartment on mine.
Is yours a right driver side Yaris?
If so it may not have a harness to fasten down.
BLH is offline   Reply With Quote
Old 09-14-2010, 08:24 PM   #8
MUSKOKA800
MUSKOKA800's Avatar
What could possibly be wrong with your oil pan?????????????
Damn Stealerships!
Old 09-14-2010, 10:04 PM   #9
oh don't worry, every time I do anything in my engine compartment I end up with a couple screws left over... nothing bad happened yet :D
but seriously! I'll double check on my car (RHD too), but I don't think we have anything there, like someone else mentioned, our ECUs and brake boosters are swapped, so we don't have a cable running there.
Old 09-15-2010, 04:10 AM   #10
Swallow
Swallow's Avatar
Yes, you are right! I am from Australia and the steering wheel is on the right side here!
So everything is right? Should I rest assured?
ONLY YARIS !
Old 09-17-2010, 01:09 PM   #11
just to confirm, took a closer look at my engine, same hole right there, with nothing in it
Old 09-19-2010, 01:54 AM   #12
so the hole is to tie down a wiring harness, but only in LHD vehicles.
mystery solved, go YarisWorld!
The Nitrous Thread ChinoCharles Performance Modifications 116 02-16-2016 04:07 PM
DIY: Intake Installation redyaris DIY / Maintenance / Service 53 08-23-2014 06:34 AM
A Mystery Oi'll Say! Yar Is Word Fuel Economy Forum 16 05-11-2013 05:22 AM
Ringing noise from engine compartment ! unclenefeesa DIY / Maintenance / Service 16 12-07-2011 01:06 PM
Clean Engine Compartment captainm27 General Yaris / Vitz Discussion 30 04-18-2009 03:11 PM
