Old 09-06-2010, 12:26 AM   #1
KrazyDawg
KrazyDawg's Avatar
Drives: 08 3dr LB AT
Replace Stock Speakers
I'm looking at replacing my front speakers and I've narrowed my selection down to the Kenwood KFC-1662S or Kicker 07DS600. I'm also open to other suggestions.
I don't plan on having an amp or sub. I'll also be replacing the factory stereo.
KrazyDawg is offline   Reply With Quote
Old 09-06-2010, 01:05 AM   #2
Alien Mantis
Secret Agent
Alien Mantis's Avatar
Drives: 2008 Yaris Hatch
I got these puppies in my Yaris, I like them.
http://www.sonicelectronix.com/item_...TS-G1643R.html
Good cheap speaker that works with lower power.
( as in: straight off the deck power )
Good hi and mid, but don't expect these speakers to give you much bass.
They won't.
I run a subwoofer in my Yaris.
I use my Pioneer HU to cut all the lower frequencies going to my 6 1/2" speakers, so they can crank louder without distorting.
My sub gets all the low freq's, so everything stays clean.
My x-over point between my speakers and my sub is 125hz.
Keep it simple!
Old 09-06-2010, 02:05 AM   #3
cfeng
Drives: Yaris 2010 Liftback
Polk Audio Component speakers are amazing!
http://www.amazon.com/Polk-Audio-DB6.../dp/B000P0R6LQ
cfeng is offline   Reply With Quote
Old 09-06-2010, 02:57 PM   #4
KrazyDawg
KrazyDawg's Avatar
Were those speakers installed in the front? For some reason, Crutchfield likes to list 6 1/2" speakers as rear seat side panel speakers. I know the sticky here lists it as front speakers for the liftback.
Old 09-06-2010, 07:21 PM   #5
Alien Mantis
Secret Agent
I bought a set of 6 1/2" and a set of 5 1/4" speakers.
I popped my panels off, and looked the situation over.
I decided to gut the factory speakers, and mount the new speaker inside the factory plastic rings that are actually part of the old speaker.
The plastic housings are pop-riveted to the car.
The front and rear factory speakers are slightly different in size.
The front ones seemed to be slightly larger than the rear ones.
( 3dr HB Yaris )
So I test-fit the two different sizes of the new speakers, and found out the 6 1/2" ones fit both locations the best.
So I went back to the store and exchanged the set of 5 1/4" speakers for another set of 6 1/2" speakers.
So I am running all 6 1/2" speakers in my Yaris.
I had to do a little trimming on the plastic ring in the front locations, to allow the new speakers to sit flush, but it was easy with my Dremel tool.
I should have taken pictures of it, but I did not.
( Easier to just show a picture, than to try and explain it. )
Old 09-23-2010, 02:39 PM   #6
KrazyDawg
KrazyDawg's Avatar
Am I going to have any problems with installing a 6.5" speaker in the front that has a top-mount depth: 1-11/16"? Crutchfield shows that it won't install in the front. Do I have to do anything outside of the standard install to make it fit?
FS: AFE drop-in filter and Stock Airbox with Cutouts FunctionSpec Items for Sale by private party 16 06-02-2010 02:36 PM
Stock Wheels 15' and Black Stock Hood (SoCal) White Yaris Items for Sale by private party 9 01-07-2010 01:39 AM
stock speakers are terrible, just look! MiniTRD In Car Entertainment + Electronics (audio / video / alarm) 19 11-24-2009 12:57 PM
FS Part 1: Many Stock Yaris Parts Kenshin Items for Sale by private party 5 11-23-2009 11:17 PM
wtf want to replace stock stereo gichlid In Car Entertainment + Electronics (audio / video / alarm) 5 09-06-2006 01:40 AM
