![]() Drives: 2007 Yaris Join Date: Jun 2010
2007 Yaris Door Lock Issue
Hi Folks,
I bought Toyota Yaris recently and have issue with driver side door lock. The car lock fine but key open door intermittently. The key works great on passenger side and also tried 2nd key and same issue. I thought i look around for quick DIY for lock so does any one have see this problem and know quick fix? Also if have to replace lock is this something I can DIY? If so appreciate if you can share procedure. Thanks for your help! |
Does the key bind, where you can't turn it all the way, or does it turn all the way, but not unlock?
#5 | |
Thanks |
You can pick up a little squeeze tube of powdered graphite at an auto parts or home center. You simply stick the tip into the lock, squeeze it a couple times, and then run the key in and out a bunch of times to distribute it.
Thanks. I will try it out and post the results.
This worked!! Thanks a lot for quick response and your help.
| News : 2007 Toyota Yaris - the little Euro's official arrival | VitzBoy | General Yaris / Vitz Discussion | 9 | 06-06-2017 12:51 AM |
| TSB's | WD-40 | General Yaris / Vitz Discussion | 27 | 06-06-2007 01:11 AM |
