Old 10-26-2010, 11:10 PM   #1
xxae07xx
hook em
xxae07xx's Avatar
Drives: black 08 lb
HELP! MI retrofit install problems!
i wired everything up and got everything where i though it goes and i guess it works...for the most part anyways. driver side works perfectly, but passenger will only shine brights and the halo doesnt work. im not sure what to do. ive checked everything fuses wiring etc, unplugged and replugged.... theres only one way to wire the projector is there not? and halo is spliced into ddl, red to green and black to white/black. anyone???
xxae07xx is offline   Reply With Quote
Old 10-27-2010, 07:53 AM   #2
jamal1984
The Beautification of Car
Drives: Toyota Yaris S
Send a message via MSN to jamal1984
i ran into this problem before, it's ended up is the harness relay is bad, if you just bought it, return the harness and get a new one.
Those harness is not cheap either
jamal1984 is offline   Reply With Quote
Old 10-27-2010, 10:14 AM   #3
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
is it possible that the halo is out.
Old 10-27-2010, 11:24 AM   #4
xxae07xx
hook em
xxae07xx's Avatar
Drives: black 08 lb
The halo is the least of my concerns. I'm primarily focused on why my projector will only shine bright and no low beam period.If it is the harness I wonder if MI would be willing to send me a replacement.
Old 10-27-2010, 11:33 AM   #5
jamal1984
then the halo wires is not correct right that is why you don't get low beam.
It's possible it's your harness, but if the halo wires not connected right, then halo and low beam will not working.
Good Luck
))) Tein Super Compact coilover install tips ((( aucorium DIY / Maintenance / Service 4 10-25-2011 12:42 AM
HELP needed for carputer project: Powered USB hub install Astroman In Car Entertainment + Electronics (audio / video / alarm) 15 11-01-2010 05:18 PM
Micro Image underpanel install DIY cali yaris DIY / Maintenance / Service 27 08-29-2009 09:48 PM
