#55 |
![]() ![]() ![]() ![]() Drives: Yaris LB Turbo Join Date: Aug 2006
when to go synthetic? Whenever you want. I did @ 5200 miles. opinions are like belly buttons, everyone has one.
#56 | |
![]() ![]() ![]() Drives: 2007 Orange Yaris Hb 3Drs Join Date: Dec 2006
People must understand this: Mobil 1 and Castrol Syntec ARE NOT synthetic oils! There is no benefit to use those two oils, unless you need a better start-up on cold mornings. Synthetic oils that allow for extended oil change intervals, are Mobil 1 Extended Performance (although still not a 100% real synthetic oil), RedLine, Motul, Amsoil, etc. Last edited by hystria; 02-06-2007 at 09:36 PM. |
#57 |
![]() ![]() Drives: Yaris Y Sedan Join Date: Aug 2006
Castrol oil 10-30w
hey guys what do you think of castrol oil???
#58 | |
#59 |
Castrol GTX is a very fine mineral oil - to be changed every 6 months. The perfect choice for regular oil change intervals
#60 | |
#61 |
ex-yaris owner
Drives: 08 solstice gxp, 06 triumph s3 Join Date: Oct 2006
switched my tranny to redline 75w90 @ 800 miles. switched my engine to amsoil 5w30 @ 3200 miles. my car loves me.
#62 |
Who said Yaris was slow?
#63 |
![]() Drives: 07 Yaris Hatchback Join Date: Feb 2007
My own synthentic oil test
Back in 83 or 84, I forget exactly which right now, I bought two new bottom end Hondas with solid lifter valve trains that, because of component wear, required periodic adjustment . The specs on the valves were .005 + or - .002. At the first oil change I went in and ever so precisely set the valves at .005 and put synthetic in one and petroleum base in the other. I then checked the valves at each synthetic oil change of 10,000 miles and every other petroleum based oil change of 5,000 miles. The petroleum based reached or exceeded .007 at 65,000 and the synthetic reached it at 155,000. I've run synthetics at the first oil change in every new car since, I'd guess that would be ten or twelve including three Toyotas, and none of them have been oil burners and I have ran all of them more than 250,000 miles before trading.
#64 | |
ex-yaris owner
#65 |
![]() ![]() Drives: honda civic hatch Join Date: Jan 2007
I have read on here i beleive that some amsoil guys go over 20k before a change? If so do you change the filter out in there somewhere? I have used mobil 1 succesfully for years. I know its not the same as amsoil but i always changed it and the filter every 3k regardless. I was just wondering about filter change on such a long interval.
91 SE-R. R.I.P old freind The influence of peers on individual behavior illustrates the seductive power of conformity And, I don't mind at all being looked down upon by purists. Indeed I don't mind at all being looked down upon by those whom I do not look up to at |
#66 | |
![]() ![]() ![]() Drives: 2007 Yaris Hatch Join Date: Feb 2007
