Old 12-05-2010, 04:21 PM   #55
rob323
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car
Unplug the line from the bov and hook it up to a boost gauge to make sure you are getting vacuum when you lift off.
rob323 is offline   Reply With Quote
Old 12-05-2010, 04:29 PM   #56
Tamago
Tamago's Avatar
Drives: UZJ100
you should have vacuum at idle, no need to hook up a boost gauge, just unhook it and stick your finger over it while the engine is idling. you should feel if you have vacuum. is the vacuum line hooked up to the correct side of the throttle body?
Old 12-05-2010, 04:31 PM   #57
rob323
If the vacuum line is hooked up to the wrong side of the throttle body, you will still have vacuum at idle though.
Old 12-05-2010, 05:36 PM   #58
Tamago
Tamago's Avatar
Drives: UZJ100
true, but not as much ;)
Old 12-05-2010, 07:07 PM   #59
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
Tamago and rob323: Ok. Here is a picture of the Zage BOV. I was told it was a re-circulating BOV, but i'm pretty sure it's atmospheric.
I'm kinda confused about what you guys are saying about the vacuum line coming off the throttle body. I don't see any vacuum lines on the throttle body; i went to the intake manifold. This is how I have it hooked up...
So that's how I have it hooked up. Am I doing something wrong?
Focus_Shift: Mounted the AEM meth tank inside the car. It's towards the back infront of where the spare tire goes. The backseat isn't there, so it's mounted on a board that was put there to prevent things from sliding forward, where the back seat used to be.
Old 12-06-2010, 04:44 AM   #60
chexmix
Drives: scion xb
damn nice man.. cant wait to see your car in full action
chexmix is offline   Reply With Quote
Old 12-06-2010, 09:11 PM   #61
pimp my yaris
C'est la vie
pimp my yaris's Avatar
Drives: 2009 2 door hatchback
Looks like its hooked up right to me. My BOV vented very easily and I adjusted the spring tension to make it tighter. I have some compressor surge with normal driving. U may notice a problem with dying out if it vents easily. If you recirculate BOV gasses you wont have any problems though.
pimp my yaris is offline   Reply With Quote
Old 12-08-2010, 12:13 AM   #62
PETERPOOP
PETERPOOP's Avatar
hks ssqv 3 blow off valve installed. hoping to tune it in the near future.
http://www.youtube.com/watch?v=zIQUd6l7r5U
Old 12-08-2010, 02:39 AM   #63
TEHxFALLEN V1.2
TEHxFALLEN V1.2's Avatar
Drives: '08 Lexus IS-F
Sick shit bro, where you get? and did you pay retail?
Sponsored by: Micro Image
http://microimageonline.com
Old 12-08-2010, 02:41 AM   #64
PETERPOOP
PETERPOOP's Avatar
Thanks. $150 bucks from a ebay powerseller. Needed to buy the adapter flange too.
Old 12-08-2010, 09:50 AM   #65
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Wow, that's cheap. I think I paid like $379 for the SSQV for my previous car. Your car is looking good BTW. Clean install.
Old 12-08-2010, 10:00 AM   #66
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
is your AFR hitting 15-16 while you're on it?
Old 12-08-2010, 01:18 PM   #67
PETERPOOP
PETERPOOP's Avatar
Originally Posted by cdydjded View Post
Just to let you know, if you paid $150 for it & it was new, its a fake. Its a counterfeit piece. Iv been a distributor of HKS, $150 is below wholesale. Im not flaming you or trying to insult you, Im just informing you of the fact. I have one of those on my car, so far, so good, so dont worry about it failing or anything. Here is info about it directly from HKS:
http://www.hksusa.com/info/?id=3646
I was well aware of the fakes out there on ebay. However, the price on these might be lower than you think. I was looking at reputable websites that are HKS dealers, and there were selling it new for around $200 dollars.
It has the hologram backing and everything seems to be legit? The quality looks and feels top notch.
Anywho, if it's a fake, it's a fake. I was aware of the possibility. But, I'm still sure it's better quality than the one the zage kit came with. It also sounds 10x better than the zage one, IMO. Hopefully it doesn't die out on me in a couple of days.
EDIT: I looked at the website you provided from HKS about the counterfeit identification, and I am thinking mine might be legit.
According to their website, this is a fake HKS:
REAL HKS:
The difference I see here is the "HKS" emblem that is on the side. If you look at my picture of my BOV, it does have the emblem..
Also, my BOV didn't come with the adapter flange like the website shows the counterfeit one does. I had to purchase that separately. My box also has the Japanese characters on the back side of the box, like the real one indicates on the HKS website.
Maybe the counterfeits are getting better?
EDIT AGAIN:
Here's some pictures of the box if anyone can tell anything from that.
It might be at certain times. The car isn't tuned for the turbo yet. However, if you watch the wideband and listen to the engine, the numbers on the wideband are at about 11-12 right before I shift. That is usually the accurate AFR during the current gear you are in (from my experience). The wideband takes time to adjust through your AFR while you are WOT through the gears. So it will show numbers alot of numbers while it's trying to read the AFR, then it steadies out to a constant number right before you shift.
Old 12-08-2010, 02:53 PM   #68
Focus_Sh1ft
Focus_Sh1ft's Avatar
Drives: 08 Yaris Turbo; 06 tC Turbo
Hmm, it still sounds like you're surging with the SSQV, but I might be wrong. It does sound a lot better though. I'm debating if I should follow suite or not.
As for the fake BOV, who cares? The only thing that matters is that it works. If that holds, then you just got a sweet deal on an even sweeter BOV.
Focus_Sh1ft is offline   Reply With Quote
Old 12-08-2010, 02:59 PM   #69
PETERPOOP
PETERPOOP's Avatar
I don't know where you can hear any compressor surge in that video? There is very minimal compressor surge, or if any with this BOV; as far as I can hear in person. You don't HAVE to get this exact bov. There ARE others out there. ;)
EDIT: Tuning session set for this Saturday morning. :)
Old 12-08-2010, 05:44 PM   #70
PETERPOOP
PETERPOOP's Avatar
I don't think mine is fake.
Old 12-08-2010, 06:54 PM   #71
Tamago
Tamago's Avatar
Drives: UZJ100
i'm glad you went turbo :)
Old 12-08-2010, 07:53 PM   #72
PETERPOOP
PETERPOOP's Avatar
amen to that! i now see the light
Scion XB 1NZ-FE Turbo build xbgod Forced Induction Forum 417 07-24-2011 09:16 PM
XBG's Total Build and Update Thread xbgod Performance Modifications 10 11-18-2010 11:19 PM
Whats needed to turbo charge the yaris? Arkhangel Forced Induction Forum 44 03-02-2009 10:08 PM
