Old 12-06-2010, 01:56 AM   #1
Midnight Drifter
Going Retro
Drives: '09 Tacoma | '90 Tercel
150 FWHP
It's a nice, round number. Tethered to a 2,300 lb car, it might not be blazingly fast, but it's pretty darn quick. It would easily max out the Yaris' speedometer.
That's my ultimate goal. The method I have in mind is via a custom head and supercharging.
The question is, can it be done - and streetable - on 91 octane pump gas?
Or is turbo the only method?
The S/C kits I've seen only seem to add 30chp... if that. 150WHP iirc is in the vicinity of 190 at the crank. Is it doable?
I really prefer that supercharger whine and instant response.
...any input is appreciated.
Midnight Drifter is offline   Reply With Quote
Old 12-06-2010, 02:18 AM   #2
how do you get a 21% cost from bhp to whp?
Old 12-06-2010, 02:22 AM   #3
Midnight Drifter
Going Retro
My Supra made 141 to the wheels on the dyno, and the engine was a bit tired. I'm guessing 175-185 of its original 200 ponies were still being put to the ground, considering it hit 60 in around 8 seconds flat.
If the cost is greater, that would suck. If the ratio is too pessimistic, awesome. I'm still a bit new to the calculations game.
Old 12-06-2010, 06:43 AM   #4
from what we've seen of dynoe'd stock cars, the yaris is rated at 109hp (or was it 106?) and puts around 90hp at the wheels (less for auto transmissions)... so it's close to the rule of thumb of 15% drivetrain loss :)
150whp is a relatively easy goal using a turbo, might be a lil tougher with a supercharger...
Old 12-06-2010, 07:39 AM   #5
Tamago
Tamago's Avatar
Drives: ZZW30
i made 155whp for under $1000 with a turbo.. which hit full boost by 3300rpm.. is that instant enough for you? ;)
Old 12-06-2010, 07:53 AM   #6
Maitre_Te_Te
Drives: Yaris 08
WOW..... what is your setup?????
Maitre_Te_Te is offline   Reply With Quote
Old 12-06-2010, 09:48 AM   #7
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
this is interesting topic... i want around 200hp on the yaris. my crx had 215whp with 10psi non/vtec. i think that was enough for a 1500lbs car. i miss the turbo now =(
Old 12-06-2010, 01:06 PM   #8
Tamago bought parts and built his own setup (and always neglects to mention that detail, lol). For those with the skills (and the tools), you can do a turbo set up for cheap just like he did.
For the rest of us, this + management:
http://shop.microimageonline.com/ZAG...S-Zage-tky.htm
Old 12-06-2010, 06:05 PM   #9
Tamago
Tamago's Avatar
Drives: ZZW30
i like to give the kids something to go to ;)
Old 12-06-2010, 06:58 PM   #10
Midnight Drifter
Going Retro
Not really. I do lots of technical driving. AutoX and the like. Turbo response isn't very linear, and again...
...the sound... that whine superchargers make is just delightful.
So 15% drivetrain loss is what we're dealing with, then?
That's roughly 173HP at the crank to get 150 to the wheels. Is squeezing 173HP out of a supercharged (I'm guessing Blitz is the best choice here) 1NZ-FE possible?
Old 12-06-2010, 08:23 PM   #11
Tamago, gotcha and lol.
midnight, you will get about 135 whp out of the supercharger kit. you're asking for 40 more whp from additional mods and tuning. Possible, but difficult. Probably will have to fabricate a fixed pulley for more boost to make that work.
it would be far cheaper to (1) use smaller wheels and (2) swap in an xB final drive to lower your gearing for Auto X.
+ light flywheel
+ weight reduction
+ racing tires
I have no trouble autocrossing a turbo car, btw
Old 12-06-2010, 10:03 PM   #12
pimp my yaris
C'est la vie
pimp my yaris's Avatar
Drives: 2009 2 door hatchback
Very do-able with turbo!
pimp my yaris is offline   Reply With Quote
Old 12-06-2010, 11:39 PM   #13
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
You won't get 150whp with the blitz. Maybe if the dyno you go to reads higher than most. I got 140 whp with every supporting mod out there besides nitrous oxide. I also tuned with the emanage ultimate to achieve the 140whp. However, I could have re-dyno'd at the previous place I dyno'd at, before I got the tune done, and it probably would have shown 160-170whp.
Anyways, the problem with the supercharger is, even when I was at 140whp, the belt keeps slipping.
I decided to go the turbo route, and I now know what it feels like to have some "power" in the yaris. I couldn't even imagine riding in garm's car.
Old 12-06-2010, 11:53 PM   #14
Midnight Drifter
Going Retro
Hm...
...what about centrifugal superchargers, like Vortech? Supposedly they're more efficient (although you lose that lovely Roots whine) and - I may be wrong here - instead of bolting directly to the head, they pipe to the factory intake manifold.
...meaning of course, that you can intercool them for a cooler/denser air charge. I think?
Old 12-07-2010, 12:57 AM   #15
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
^^ Power Enterprise had a kit like that ^^
Old 12-07-2010, 05:17 AM   #16
Focus_Sh1ft
Focus_Sh1ft's Avatar
Drives: 08 Yaris Turbo; 06 tC Turbo
Save yourself the headache and go turbo. Plus, what kind of response are you looking for here? An approriately paired turbo on our cars gets fast spooling times. Mine begins spooling around 2200 RPMs.
Focus_Sh1ft is offline   Reply With Quote
Old 12-07-2010, 09:42 AM   #17
ilikerice
ilikerice's Avatar
+ light flywheel
+ weight reduction
+ racing tires
should add a Kaaz lsd to that list imo... with a stock car using R compound tires, there is alot of wheel spinning when dodging cones.. i mean if your going into the tranny to swap out a final drive gear, why not swap the diff while your in there.. right?
Old 12-07-2010, 12:31 PM   #18
^ good idea. or better yet an OS Giken for $1600. THAT LSD ROCKS. Just happen to have an extra one in stock too.
150 hp+ Echo cdydjded Performance Modifications 13 07-09-2009 05:47 PM
