Old 01-17-2011, 05:35 PM   #1
billfires
Drives: 2010 3dr LB
TPMS with snow tires
I searched but was unable to find the answer. Bought 4 used 195/60-15 tires and had them mounted on 4 steelies from an 08 yaris sedan (that had the original tires w/ TPMS sensors still installed). I put 2 of the snow tires on my daughter's 08 sedan and 2 on my 2010 LB and both venicles have the TPMS light on. Is there any way to reset the light? Thanks for any help. Bill C
billfires is offline   Reply With Quote
Old 01-17-2011, 07:03 PM   #2
Lil Abner
Drives: 2009 3dr LB Manual
There are two things you can do. You can either re-program the TPMS sensors for each car (a pain), or do a bypass switch for the winter. I run winter tires on separate steelies, and I have the switch installed. Try this:
http://www.yarisworld.com/forums/sho...ht=TPMS+switch
I zip tied the switch next to the module, which is right above the glove box opening. Just remember to flip the switch back in the summer!
Old 01-21-2011, 07:24 PM   #3
billfires
Drives: 2010 3dr LB
Just an update, the light has gone off on my 2010 LB after aprox 250 miles. I don't know why it went off as no reprograming was done. As far as I know the light is still on in my daughter's 08 sedan. Bill C
Old 01-21-2011, 10:11 PM   #4
If you park the car near the tires/wheels that you removed, the TPMS system will actually read the sensors and clear the light. If you then drive a certain distance before the system sees them again the light will come back on.
Review: Pirelli Winter Carving Snow Tires Lil Abner Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 12-07-2010 01:04 PM
what snow tires good for Yaris Hatchback. opor24 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 16 12-28-2009 12:53 AM
Tall thin Snow tires for 14" rims regal Wheels, Tires and Suspension Forum sponsored by The Tire Rack 18 07-25-2009 08:40 AM
