Old 02-26-2011, 11:28 PM   #1
Lil Abner
Drives: 2009 3dr LB Manual
Exclamation DF210 Spring Install Problem
I installed a new set of DF210 springs yesterday that I got from Garm. Install was easy. I know people complain about the uneven drop of the DF210's, but the pictures by other members don't seem to show that.
However, after installing mine, my rear was quite a bit lower than it seemed like it should be. The some measurements:
Front ground to wheel well: 24"
Rear ground to wheel well: 23" (an inch too low??)
In the back, I have a small 8" sub, and a "milk crate" with about 6 engineering textbooks. Oh, and 1/2 a tank of gas. Looking under, the bottom 3 coils are fully collapsed. Those coils don't have the black "wrap" on them.
For the rear, I placed the ends of the springs towards the back of the car. I might try rotating them to the front tomorrow and see if it helps.
So, is this normal?
Edit: Also looking at pictures, it seems the bottom 3-4 coils are suppose to have the wrapping on them. Mine didn't come with that wrap, so my bottom coils, which touch, don't have any wrapping.
Thanks in advance.
Curt
Old 02-26-2011, 11:49 PM   #2
SeriousBlack
SeriousBlack's Avatar
Drives: 2007 Yaris RS HB
Photos?
SeriousBlack is offline   Reply With Quote
Old 02-27-2011, 12:06 AM   #3
Lil Abner
Here you go:
Side Shot (sorry, in garage):
Front wheel and measurement:
Rear wheel and measurement:
Spring Shots (driver side):
Old 02-27-2011, 12:14 AM   #4
give it some time to settle in.
Old 02-27-2011, 12:17 AM   #5
Lil Abner
The front, or rear? Or both? I'm assuming you mean the front will settle to match the rear?
Old 02-27-2011, 12:20 AM   #6
I should drop in the front as the springs settle. The rear not so much as the load it holds isn't as great, hence the shape, size, coil difference in the springs from front to back.
Old 02-27-2011, 11:08 AM   #7
SeriousBlack
The rear looks about as low as it should go, subs, milk crate and all - mine sit around the same. As for the front, it's quite a bit higher than it should be, relative to the rear. Usually on the DF's the front is around .4" or so higher. My springs have not sagged that much in three years, though.
Old 02-27-2011, 11:38 AM   #8
Lil Abner
SeriousBlack, thanks for the heads up. I figure I'll let it be until this coming weekend. Worse case, I'll add a 0.5" spacer in the rear to balance it all out.
Old 02-27-2011, 08:16 PM   #9
detroiter
detroiter's Avatar
I was going to say, it's going to take a good week or week and half for it to settle in pretty well. Also I know it might sound like a stupid question but when you measured, where you on completely even ground? Even a slightly uneven surface can make one side look much more off than the other.
Old 02-27-2011, 08:53 PM   #10
Lil Abner
Yes, it was on a level surface. It was like that as soon as I took it off the lift. And I have the lift in my other garage.
Old 02-27-2011, 10:17 PM   #11
bzinn 1
bzinn 1's Avatar
Drives: 2008 Yaris HB
Mine was the same way....no worries.....the front struts are pretty strong and so is the new spring and it takes a couple of weeks of driving to settle to the advertised ride height...
the backs wont go much lower,maybe a half inch or so,you got the same measurements I got on my install day and through the first week.
Compilation of Yaris How-tos/DIYs YarisBueller DIY / Maintenance / Service 39 04-28-2018 09:47 AM
Micro Image underpanel install DIY cali yaris DIY / Maintenance / Service 27 08-29-2009 10:48 PM
Hyperco 5.5" single pigtail rear spring test kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 06-15-2009 11:11 AM
TANABE DF210 Spring Install [pics] Chris07LB DIY / Maintenance / Service 148 07-16-2007 10:26 PM
Spring Install Price redglare45 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 06-30-2006 09:32 PM
