#1081 | |
![]() D.
. CLA 250, 4MATIC |
#1082 |
Ok, this is only a sketch (it's a cross section parallel to the car, right in the middle of the passenger's seat) these are my thoughts in paper and it's only an idea, I took some liberal dimensions and I don't know the specs of the I6SW so I'm assuming 7 inches in diameter and about 6 inches depth.
I know I could shrink every thing a little bit more, and/or change the angle of the mini-woofers. I thought it this way because my wife usually takes her shoes off and she could rest her feet on top, well not in winter until its warm and cozy, but that is once in a while, 99% of the time I drive alone. I'm going to have to make a mock up and sit my self to get a feeling on how bad the space would be! ![]() D.
. CLA 250, 4MATIC |
#1083 |
Roadrunner Jr.
E-mail to you D. There are possibilities here. it's just about how much we want to put into it. The nice thing about these Imagines is the reverse surround. That allows for excursion without having to worry about the surround rubbing.
“To argue with a person who has renounced the use of reason is like administering medicine to the dead.” ― Thomas Paine |
#1084 | |
Looking into the glove box area too. D.
. CLA 250, 4MATIC |
#1085 |
Not a lot of space, the glove box as is, it's about 0.15 cuft, using all the space of the glove box I'm guessing about 0.25 cuft.
I'm still on the idea under the glove box/fire wall.... ![]() D.
. CLA 250, 4MATIC |
#1086 |
I kinda looked around up there too when the idea came up. Decided I needed my glove compartment more and stuck with the trunk placement. I really like the idea of having it up front. But unless I glassed off the entire bottom access to the dash, I couldnt find a good way to get space for a cabinet.
#1087 | |
A few days with the sub up front and it's not going back to the trunk! I hope the idea of the I6SW works even if it's under the glove compartment in a removable enclosure. D.
. CLA 250, 4MATIC |
#1088 |
![]() ![]() Drives: Yaris 08 Join Date: Mar 2009
LOLLL wow... how many RMS whatt do you have in your car?
#1089 |
Not a lot but just enough for SQ
Tweeters.....75w Mids............75w Mid-Bass......100w 200w soon! Sub-W.........500w Mid-Bass upgrade to 200w soon! D.
. CLA 250, 4MATIC |
#1090 |
Roadrunner Jr.
We can probably extend the top of the enclosure you have illustrated UP to just under the AC/Heater unit... That may give you the ability to flatten the front of the enclosure out a little.
You may also want to think about making the subs fire onto the firewall area and have an inch or two of space from the firewall and the bottom of the woofer. Still having the woofers in a sealed enclosure of course. Think of it liek a downfiring setup, except aimed to the firewall instead of down.
#1091 | |
D.
. CLA 250, 4MATIC |
#1092 |
Bronze bombshell yaris
Drives: 09 Yaris HB 3door Join Date: Sep 2010
Not if she's ticklish! heh
Now I drive a CARMINE RED METALLIC 09 Yaris 3-door!! I'm Back!!! WooHoo!! Mods done so far: Tinted windows, Viper 211HV Remote Keyless Entry, Atoto Android headunit, backup camera, steering wheel controls Before it was totaled I drove a 2007 Black Sand Pearl 3 Door Lift-Back M/T with 49k miles. Stock Everything except for black tint, all red badges, red dash, and stealth garage door opener. Ultra-Gauge mounted on steering wheel. A1 Electric MES Central Locks and Avital 3100 Alarm system.
#1093 |
I'm going to call it... "Foot Massage" as a sales point... LOL
I'm plying with the L6s ring's in the area below the glove compartment, I'll shoot some pictures tomorrow. D.
. CLA 250, 4MATIC |
#1094 |
Roadrunner Jr.
Scott's still working on getting the official specs into .PDF...
#1095 |
Awesome!
Sqcomp... did you just change your avatar? D.
. CLA 250, 4MATIC |
#1096 |
I just couldn't stop thinking about it, here are some pictures with the L6 rings, they are about 8" in diameter. I sit down for a minute to see how bad it is, It's ok as long as you don't want to stretch your legs.
Now I have to calculate how much space is behind there, and take in consideration the thickness of the MDF if any. May have to glass the area and fill it up and check the internal volume. ![]() ![]() ![]() D.
. CLA 250, 4MATIC |
#1097 |
Roadrunner Jr.
Here's the thing, you could shrink down the trim rings, specially in the center. I would definitely recommend glassing. The trick is making the enclosure go up BEHIND the dash around the heater core. Now, this is where cabosil type material will help you. I'd like to be able to see you shrink down the space that is taken up in the foot-well.
...and yes, I changed the avatar. I'm thinking about something else. I got my hands on some vintage gear...they don't make it like that anymore.
#1098 |
SQ, I have a friend who gets older stuff at flea markets for use at his trailer on the river! I've told him more than once, he should restore and resell this stuff but he wants it for cheap sound that wont matter when it floods! GRRRrrr
| sound deadening: sq footage amount for 3dr | goku87 | In Car Entertainment + Electronics (audio / video / alarm) | 29 | 11-14-2013 01:37 PM |
| 2007 Yaris S Sound Deadening | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 70 | 12-13-2010 08:40 PM |
| Sound deadening | 06vitzRS | General Yaris / Vitz Discussion | 10 | 05-05-2010 02:51 PM |
| Sedan Door Panel Deadening | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 42 | 06-01-2009 03:47 PM |
