Old 03-16-2011, 02:34 PM   #19
manuel_Ga20
manuel_Ga20's Avatar
Drives: Yaris 2008 Hatchback 5 doors
I figured out that those slots that i told youwere working right just when the car was on, the cord that you toldme it's fine, so now i tested all. The fuses again with. The. Car. On and it seems that the number 26,23,17 and 16 are the ones not working, and i figured out when i saw the description on the manual that those fuses are for: 26 (id/up/MirHTR, 23 CIG (i think is for the cigarrete and actually i tried and it wasnt working i dont smoke so), 17 panel 1 and 16 panel 2!
manuel_Ga20 is offline   Reply With Quote
Old 03-16-2011, 02:41 PM   #20
26 (ID/UP/MIR HTR) is fed from the 30A DEF fuse, so you will need to check that fuse out. If you pull it out it should be visibly blown if it is bad.
23 (CIG) is fed by 7,5A ACC2, which is located in the fuse holder that is mounted to the top left side of the main body ECU.
17 (PANEL1) and 16 (PANEL2) will only be on when the headlights are on.
Old 03-16-2011, 02:46 PM   #21
manuel_Ga20
So none of them has anything to do with the locking and unlocking system? What could it be then? I'm getting at this afternoon all those fuses that you told me!
Old 03-16-2011, 02:54 PM   #22
Do the door lock/unlock switches on the drivers door work, but the buttons on the remotes do not?
Old 03-16-2011, 04:12 PM   #23
manuel_Ga20
That is correct the doors lock and unlock from inside from the pilot door but it doesn't work with the wireless control!.
PD: I tested the fuses 16 and 17 with the lights on and they do work, the 23 i changed it for a new one now it's working, i'm trying to find the 30A big fuse to see if that is the bad thing about the fuse 26! I guees that will not fix my lock and unlock system!
Old 03-16-2011, 04:27 PM   #24
manuel_Ga20
Bro i tried the fuse 26 again with a new 30A DEF and it still no receiving any power! So that's making me crazy! Also the alarm thing that i guess i have to configure it again i think that is the issue with it! What do you think?
Old 03-16-2011, 04:51 PM   #25
Now that I look at the diagram again, 26 will only be powered when the rear defogger is on.
Is your wireless control the real Toyota one, or is it an aftermarket alarm?
Old 03-16-2011, 05:13 PM   #26
manuel_Ga20
I will test it with the defogger on! The alarm is the original one the toyota one! The one that it comes with the key!
Old 03-16-2011, 05:21 PM   #27
OK. One more thing to try at this point is to make the system relearn the remotes:
http://www.yarisworld.com/forums/sho...19&postcount=6
Old 03-16-2011, 09:33 PM   #28
manuel_Ga20
You were right the fuse was good, so all the fuses are working properly! and i bet the ECU it's okay! so i will try to do the things that the other post says! thank you! i let you know tomorrow!
Old 03-17-2011, 09:45 PM   #29
manuel_Ga20
CTScott i tried what you told me and it seems that the wireless control works good because i can set it up, i follow all the steps that you told me, after i press LOCK-UNLOCK for 1 - 1.5 seconds, i press the LOCK button for 1 seconds and the doors LOCK and UNLOCK that means that is set up! after that i open the door and get out of the car and i tried to see if the control was already working but again nothing happened! i hope you know how to solve this issue, this thing is making me crazy!
Here is the video of me trying to set it up!
http://www.youtube.com/watch?v=5rTn6Wwy3XA
Old 03-17-2011, 10:06 PM   #30
The video definitely helps. I think you are almost there. When you do the 1.5 second holding of the two buttons, you are supposed to release them and then hold just the lock button for more than one second.
I think you are getting the double cycling of the locks, which is saying that there is an error registering the remote because you are missing that step.
Old 03-17-2011, 10:21 PM   #31
manuel_Ga20
actually i did that after holding the two buttons i just held the LOCK button for about 1 sec, after that the car locks and unlocks, and as the post that you sent me about how to configure it, it says that it will lock and unlock once, and that is what i'm getting, so i believe my remote it's okay! but i still don't get it why it doesn't lock and unlock my doors! Thank you for all the advices!
Old 03-17-2011, 10:32 PM   #32
OK - If you are getting a single lock/unlock, then it believes that it registered the transmitter.
If I saw correctly, you are using "rewrite" mode, which is two cycles of the ignition switch. Try doing "add" instead, which is one cycle.
Old 03-17-2011, 10:33 PM   #33
manuel_Ga20
i will do it now and i will let you know!
Old 03-17-2011, 10:49 PM   #34
manuel_Ga20
i just did it and it happened the same thing, i configured it and i received the LOCK UNLOCK once i opened the door and close it and tried to lock it from the control and nothing happened so i don't get it, the control its working, the receiver it's working and all the fuses are in place! I don't know what did i do after i installed my new stereo!
Old 03-18-2011, 01:42 PM   #35
manuel_Ga20
Don't you have any other ideas CTScott?
Old 03-18-2011, 01:52 PM   #36
So, the keyless entry system seems to be fine - The remotes can be registered with successful confirmation, so they seem to be fine as well. So, the question is why then does a working system not work?
The only thing I can think of at this point is that the Body ECU believes that the engine is running, since the remotes are not operable once the engine is started. I would try unplugging the harness from the back of your new radio to see if then the keyless entry works. If it does, then we know that there is a wiring issue there that is confusing the Body ECU.
door, ecu, ecu wiring, stereo, wiring
Car doors are not self-locking when left unlocked fainty_girl General Yaris / Vitz Discussion 27 03-14-2011 10:12 AM
lambo doors.. @@ ?? why not !!! S69 Cosmetic Modifications (Exterior/Interior) 11 04-11-2007 06:14 PM
Speaker grills / holes on the doors. IsLNdbOi Wash, Wax, Detailing, Exterior Repairs 3 09-15-2006 11:28 AM
do u think a coilover from tein (3 doors) will work with sedan ( 4 doors) mariosuper Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 07-21-2006 05:59 AM
