Old 01-31-2007, 03:40 AM   #1
jouslee
Drives: White 2007 2 Door hatch Yaris
How Heavy is the flywheel?
Hey guys I was just wondering how heavy the stock flywheel is for our Yaris'
Thanks
-Josh
jouslee is offline   Reply With Quote
Old 01-31-2007, 03:44 AM   #2
Yaris TTE JWRC
Drives: 07 5spd red Yaris HB 1.5L 16V
Thanks
-Josh
18-20lbs
Yaris TTE JWRC is offline   Reply With Quote
Old 02-05-2007, 01:11 AM   #3
jouslee
mmm... isn't that a bit heavy for a small car like ours?
Old 02-05-2007, 01:34 AM   #4
Yaris TTE JWRC
negitive- the old echo's flywheels weights about 18lbs.
Old 02-10-2007, 11:33 AM   #5
jouslee
I donno man.. My buddies stock weight on his VW Corrado (200ish HP) is about 18 lbs.
This may be the cause of our cars having a sticky feeling...
Old 02-10-2007, 01:54 PM   #6
bugnuts
bugnuts's Avatar
Drives: 2007 Yaris Liftback BBP
The heavier a flywheel the better the idle, If you lighten a flywheel sometimes the engine wants to stall...Then again if you lighten it it will also rev faster and give better racing performance, So it is a draw between racing and everyday driving.
"I am un chien andalusia" - Black Francis
bugnuts is offline   Reply With Quote
Old 02-14-2007, 06:29 PM   #7
jouslee
bad idle? Really? I thought having a lighter flywheel is going to make it hard to drive not because of rough idle but because there is less inertia on the flywheel therefore the flywheel is more prone to stop moving when the clutch is applied (Which causes a stall).
Anyways, the stickiness i was talking about is when you rev your engine the rpm stay at the same level for a second when you release the gas.
I'm thinking that this stickiness is due to a heavy flywheel.
Any opinions? Anyone with a light flywheel?
Old 02-14-2007, 06:39 PM   #8
Doc Zaius
Lurker supreme!
Doc Zaius's Avatar
Drives: old and boosted!
I think there are rumours about that the "sticking" is due to the drive-by-wire throttle system. I was also hoping that lightening the flywheel would get rid of this, but would probably only be a partial solution.
2006 Red Blitzed RS 5-door
Old 02-14-2007, 07:07 PM   #9
heylookitsjames
maintenance of momentum
Drives: 2007 5spd 3dr
light flywheels have the potential to do exactly what both of you described.
heylookitsjames is offline   Reply With Quote
Old 02-14-2007, 07:38 PM   #10
ItsMyDaily
The LittleBastard
ItsMyDaily's Avatar
Lighter is going to help greatly in acceleration. I had a 8lbder on my S and it improved the car all around nicely. never stalled, but on occassion would see the rpms drop low while stopping.
Yaris Mods:
20% Tints
Ground wires
2007 Toyota Yaris Liftback - Current
2004 Honda S2000 - Sold
1986 Toyota Corolla SR5 - Sold
DIY: Groundwire Kit
ItsMyDaily is offline   Reply With Quote
Old 02-21-2007, 09:36 PM   #11
Moose
Resident Redneck
Moose's Avatar
Drives: 07 Polar White Yaris Sedan 5M
The "throttle stick" is the "lag" in the electronic throttle (drive by wire). The computer takes measuresments from the vacuum system before making throttle adjustments- after you let off of the throttle, there is still "excess" air cycling into the intake manifold via the EGR valve (exhaust being rerouted into "fresh" air for emissions requirements). Once the "over idle" exhaust gas is pushed into the intake and the computer senses an idle-quality amount of exhaust gases coming from the EGR, the throttle lets off. Basically, the throttle "sticks" to allow all exhaust gases to be expelled.
As far lightened flywheels go, lighter flywheel = quicker engine response at the expense of torque. You will have better high end power, but less "grunt" off the line. The same principle works with lightened underdrive pulleys- they allow for higher revs and less parasitic draw, but lose their "underdriving" power- this is why your lights will dim under hard acceleration/high revs- the alternator is not working at peak efficiency.
My other rides:
2003 Honda Civic LX Coupe 5M- S/C K24 w/ LSD coming soon!
1999 Honda Civic EX Coupe 5M w/ B18 powaa
1985 Toyota Celica GTS Coupe 5M- track whip
http://www.importlounge.com
Moose is offline   Reply With Quote
Old 02-22-2007, 10:47 AM   #12
jouslee
oh okay, that explains a lot. but EGR didn't seem to effect my Rx-7 it does in this car... Dang... Is there anyway to disable the EGR system electronically?
Old 02-22-2007, 02:18 PM   #13
Moose
Resident Redneck
Moose's Avatar
Nope- the EGR system is simply a tube from the exhaust manifold/downpipe leading to a mechanical valve in the intake manifold. Removing the system will cause your vehicle to sound like it has an exhaust leak, trip a CEL, and make the car run a little crappy (you would lose some pep).
It's just one of those things you're gonna have to live with. Thanks CARB!
My other rides:
lightweight flywheel from fidanza dngz Performance Modifications 34 02-03-2009 11:02 PM
