Old 05-12-2011, 01:55 AM   #1
skootdog
skootdog's Avatar
Drives: 2011 White A/T
DIY Hatchback Spoiler Install
1) This is the painted spoiler with the hole drilled for the bolt it came with.There is a indention where it mounts to the car and a 19/64 drill bit fits perfect. 2) I Held the spoiler on the car and centered it with the indention it has for the window washer. I marked it with a sharpy. 3) I drilled holes with a small bit first 5/64 ( Used as a pilot) And then the main holes with a 21/64. 4) I then lined up by sight where to drill the hole on the underside of the door on the passenger side so I could reach the nut. I used a 3/4 hole saw bit. 5) The Hole. You have two metal panels to drill through. 6) The drivers side hole you can reach by taking the gromet off that conveys the wires for the door lights. Just give it a tug but dont pull to hard so that you damage the wires inside it. Once separared you can look through and see the hole. 7 & 8) The hardware comes with a Phillip head bolt, A locking nut and a rubber washer that I put in between the spoiler and the top of the car. I also put some silicone around the hole before I put the rubber washer down and the head of the bolt to seal it Just in case). Not to much though you dont want it squirting out when you tighten it. You have to reach in the holes with a pair of needle nose pliers to get the nut on. I highly recommend two people for this part. I did it myself and it was a pain. 9) Its comes with double sided tape circles that you use to mount the painted chips that cover the mounting holes. I used a little alcohol and a cotton ball to clean the hole and the bottom of the chip before sticking it on there. Don't get your fingers on the tape! 10) I took a Cap Plug and covered the hole on the passenger side. I had trouble finding this part until I saw one on my work truck and took it HAHA! The ones at the auto store were too small and I also checked audio store No luck. It was bigger than the hole I drilled so I just drilled it out with the side of a bit untill it was big enough. Hopfully ya'll will have better Luck. 11) Just pop the gromet back in and your done.
"Because it's Racecar"
skootdog is offline   Reply With Quote
Old 05-12-2011, 02:04 AM   #2
skootdog
skootdog's Avatar
Here's the car.
Old 05-12-2011, 08:40 AM   #3
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
nice good job!!!!! just curious though do you have to have a nut on the other side cant you just drill a hole that will hold the screw without the nut on the back??
Old 05-12-2011, 02:32 PM   #4
AppleJacks716
Drives: 2010 5 Door
He said in the DIY the spoiler came with nuts.
The rally style spoiler offers the same installing by using a gromet. But its a rather large hole to drill.
AppleJacks716 is offline   Reply With Quote
Old 05-12-2011, 05:33 PM   #5
Shinare
Bronze bombshell yaris
Shinare's Avatar
Drives: 09 Yaris HB 3door
Looks really nice!
Old 05-12-2011, 05:41 PM   #6
marcus
toyota
marcus's Avatar
i did notice that there is still a difference from the original.. this one goes flat alligned with the roof vs jdm rs spoiler is tilted up a bit....but design is exactly the same though guess its just the angle...
Old 05-12-2011, 10:14 PM   #7
auxmike
auxmike's Avatar
Looks seriously nice. You did a killer install!
I did the smaller 2008 "S" spoiler and it was NOT an easy job...
Old 05-13-2011, 12:39 AM   #8
skootdog
skootdog's Avatar
Yea the nut comes with it and the metal is way to thin. At least i wouldn't want to trust it at highway speeds. Thanks Guys glad ya'll like it.
Old 05-13-2011, 07:55 AM   #9
willygoodness
Drives: 09 yaris hb
!!! nice
where did u get that wing from?
willygoodness is offline   Reply With Quote
Old 05-13-2011, 08:02 AM   #10
willygoodness
Drives: 09 yaris hb
ahh... was it the jumbodepot one? if it is.. it looks better in your photos than on their ebay photos :/
Old 05-13-2011, 01:18 PM   #11
marcus
toyota
marcus's Avatar
any photo from top and bottom...?
Old 05-14-2011, 03:01 AM   #12
bzinn 1
bzinn 1's Avatar
Drives: 2008 Yaris HB
that looks really nice....good job on install.
Old 05-15-2011, 04:42 AM   #13
sosopo
sosopo's Avatar
Drives: 2008 Toyota Yaris LB
Im looking foward to install this spoiler...but i read in another post that this spoiler is unsafe...anyone having problems with it?
sosopo is offline   Reply With Quote
Old 05-15-2011, 10:35 AM   #14
marcus
toyota
marcus's Avatar
unsafe??? if you want you can use 3m tape at the same time to make sure it doesnt go off..
Old 05-15-2011, 04:22 PM   #15
skootdog
skootdog's Avatar
Yes, This is the Jumbodepot spoiler.
Old 05-15-2011, 04:25 PM   #16
skootdog
skootdog's Avatar
No, I didn't take anymore photo's
I don't see how it would be unsafe. There is no way this thing is ever coming off.
Old 05-15-2011, 08:37 PM   #17
sosopo
sosopo's Avatar
yeah MARCUS thats what im going to do....anyway I'll take the risk cuz it looks sick!!!
Old 05-15-2011, 11:16 PM   #18
bzinn 1
bzinn 1's Avatar
use 3m tape and the screws and nuts to hold it in place and it will never come off.
DIY Sedan Spoiler Install Kaotic Lazagna DIY / Maintenance / Service 36 01-20-2020 12:35 AM
Compilation of Yaris How-tos/DIYs YarisBueller DIY / Maintenance / Service 39 04-28-2018 09:47 AM
DIY Spoiler JohnnyBomber101 Performance Modifications 11 04-18-2011 10:08 PM
Micro Image underpanel install DIY cali yaris DIY / Maintenance / Service 27 08-29-2009 10:48 PM
DIY Sedan Spoiler Install Interest? Kaotic Lazagna DIY / Maintenance / Service 28 09-12-2007 12:02 AM
