![]() Drives: 2007 Yaris, Hatchback Join Date: Jan 2009
Hello,
I will soon be upgrading my wheels and tires on my car from the standard OEM, 185, 15” inch wheels to some 17”s , but I have a question that I have seen similar answers too, but not exactly. Original tires/wheels 185/ - 15”inch steels Yokohama OEM. Upgrades tire/wheels 205/45/17 - 17” inch - Enkie EDR9 (17x7). (38 offset - which is best from what i have read). Wrapped with rubber- Yokohama AVID ENvigor (H&V) shown on tirerack as a 205/45R17. My main concern is rubbing/ scratching, I would not like to hear this very often – if at all, and wanted to know from more knowledgeable people here, if this will happen, and if so how much will it rub. Edit From what i can find on tirerack, the 205/45R17 and the current 185/65R15 have the same/ similar diameter, 24.3 vs the current 24.4, so i guess this answers my own question, and should be fine, any ones else concur. Only real difference is the Rim Width and the Tread Width. Darwin Last edited by Darwin84020; 07-02-2011 at 04:17 PM. |
![]() ![]() ![]() Drives: 2009 3dr LB Manual Join Date: Mar 2010
Is you car currently lowered? Or will it ever be?
Well I know the 215/45/17 Yokohamas I just put on my stock 07 sedan kiss the front wheel well on big road dips i.e bridges and train tracks. Other than that they ride great and the ride height is slightly higher at 45. But still, the rub can get especially aggravating day in day out. I'm sure the plastic wheel well can only take so much before it gets annihilated, and from what I gather, that plastic liner goes for like $400 to replace. I'm gonna switch to either 215/40/17, but if the shop says there is ANY hint of a rub risk with those, I'll go further down to the sure thing of 205/40/17.
やりすぎだ~
If your car isn't lowered then the setup you have (17x7 +38 offset with 205/45/17) will be fine.
![]() ![]() ![]() ![]() ![]() Drives: Scion FRS RS2, ‘21 Crosstrek Join Date: Oct 2008
Your OEM rubber should be 185/60-15, not 185/65-15. 185/60-15 has a diameter of 23.7" so you may well be advised to go to 205/40R17 for something closer or slightly smaller to further lessen the chance of rubbing.
Good Luck and Enjoy!
TRD Upgrades: 18" Wheels wrapped in 215/35/18 PZero's, Sportivo Shocks/Struts, Lowering Springs, Swaybar, Axle-Back Exhaust, Oil Cap, Rad Cap, Signage. Aftermarket Goodies: Piggies SS, K&N Drop-In, Blitz S/C, DC Header, NST Pulley) Toyota Options/Accessories: Sport Pedal Covers, Sport Shift Knob, Ipod Interface, Summer Mats, Winter Mats, Cruise Control, Auto-Dim Mirror, Echo steelies with winter boots.
![]() ![]() ![]() Drives: Toyota Belta Join Date: May 2011
yup I will be going with a 40 series when I am ready as well. 45 is too fat imo.
| wheels and tire combo advice. | bwd1973 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 7 | 03-26-2011 12:13 PM |
| Tire advice for 17" wheels | coolj | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 2 | 01-12-2011 01:06 PM |
| Ordered some wheels, need advice on tires | 47_MasoN_47 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 10 | 04-21-2010 04:56 PM |
| Could someone give me some advice on these set of wheels | fujiwaru | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 07-25-2009 07:33 PM |
