Old 07-09-2011, 08:29 PM   #37
mmrdelany
Drives: 2009 5dr hatchback
Will an 08 headlight fit an 09?
mmrdelany is offline   Reply With Quote
Old 07-09-2011, 09:32 PM   #38
^ No. Front and rear bumpers changed in '09+, the headlights are not compatible at all, and older tails stick out on an '09+ bumper.
See here for pics of 2008 tails on a 2009 model Yaris:
http://www.microimageonline.com/foru...008+tails+2009
Old 07-10-2011, 01:20 AM   #39
mmrdelany
I ordered the front two headlights from logical-source.com for an 09 model and the shipment came in today. It was an 08 model with additional mounting holes to match the newer model. Should I even attempt to see if it fits or return it?
Old 07-12-2011, 12:24 AM   #40
mmrdelany
yeah they dont fit.
Old 04-07-2012, 04:31 PM   #41
Noel_Malta
Noel_Malta
Drives: 2010 5-Door hatchback 1.3L
will a front bumper add-on lip from the 2008 model fit on a 2010 bumper version?
Noel_Malta is offline   Reply With Quote
Old 11-02-2017, 11:52 AM   #42
mr_robot
Drives: Yaris
I can’t tell the difference between the two headlights?
I need a new bumper and was considering the 2009 for my 07.
mr_robot is offline   Reply With Quote
Old 11-02-2017, 01:16 PM   #43
heeroyuy01195
Post count means nothing.
I'm pretty sure the 09+ Yaris headlights were the same shape as the previous years but they added DRLs. The Tail lights on the LB are slightly different on the 09+ models. If you put the 07 tail lights (For example the RS lights) on the 09+ models they will sort of hang over the bumper towards the hatch.
Old 11-02-2017, 01:21 PM   #44
The inside edge of pre'09 headlights are a straight line front to back. '09 to '11 curve inward slightly mid point.
Old 04-30-2018, 10:00 AM   #45
dcp520
dcp520's Avatar
Drives: 2010 Hatchback
Tried a pre 2009 headlight on a 2009+ Yaris. Different headlights. Doesn't fit, notice the bumper curve and hitting the headlight.
2009+ has a slight curve near bottom of headlight.
Pre 2009 on left. Post 2009 on right.
dcp520 is offline   Reply With Quote
Old 06-16-2018, 11:36 AM   #46
Desircustoms
Drives: 06 Yaris RS MT
Good info! Now we know we also need headlights if we want to install a post 09 front bumper on a pre 09 car... The post 09 RS bumpers are very appealing to me.
Desircustoms is offline   Reply With Quote
Old 06-16-2018, 11:55 AM   #47
enviri
enviri's Avatar
Drives: 2010 Yaris
yup, JDM late08-early10 RS bumpers are the best
Old 11-15-2021, 04:19 PM   #48
Djoisan
Djoisan's Avatar
Drives: none
Thanks for info!
Djoisan is offline   Reply With Quote
Old 12-21-2021, 06:08 AM   #49
David90
Drives: Mazda
Originally Posted by goku87 View Post
With each passing post I'm getting closer and closer to buying a new Yaris lol.
Best post I saw all day!
David90 is offline   Reply With Quote
Old 06-03-2022, 02:36 PM   #50
sh0rtlife
im going to bump and old sticky and HOPE someone can 110% verify
to be clear..
the 05-07 vs 09-11 hood is 100% the same?
what about the 05-07 vs 09-11 hatch?
i assume 3dr and 5dr use the same hatch?
i may have found a source thats still making the hatches and hoods in CF for about 300$, so i want to be dead nuts sure before i pull the trigger, im looking for weight savings only..and the parts WILL GET PAINTED...found front doors too but 1200 for a pair is painfull
Old 02-12-2024, 10:08 PM   #51
AlbinPrani
Drives: Man
Send a message via AIM to AlbinPrani Send a message via Yahoo to AlbinPrani
Is the source you found for the CF hoods and hatches reliable, and have you checked customer reviews or testimonials to ensure the quality and fitment of their products?
AlbinPrani is offline   Reply With Quote
Old 08-17-2025, 12:55 PM   #52
BIGTAZ351
147K-Blue / 24K-Yellow
BIGTAZ351's Avatar
Drives: 2010 Ylw 3dr. AT(Blue-Wife's)
But did they bolt in?
OK but would the 2008 style bolt on the 2010 car?
I have always wanted Projectors on my 2010, but they only come 07/08 Style...
Wife Whacked a Deer, so full 2008 nose will be going on the car, I realize the lower bumper "support/push bar" is also likely different, but I need to know if there is anything to do with mounting 2008 lights on the 2010 that is different? Or will I have to change the upper radiator support or whatever?
All Weather Package, Power Package, Cruise, WeatherTech Floor Mats. Altimax Arctic Winter Tires.
Repair List:
1 new blower motor, making funny noise. @ 91K (Water pump @ 120K)
Mod List:
1. Black tape on most of the annoying blue high beam light behind the lens. (thank you CTScott)
BIGTAZ351 is offline   Reply With Quote
Old 08-17-2025, 02:29 PM   #53
2008 bumper covers and headlights are direct bolt on to a 2010. Rad supports, crash bars, tow hook location are all the same.
Body kits for a 2009? dimsum69 Cosmetic Modifications (Exterior/Interior) 63 03-10-2016 06:47 PM
For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers m911gt Items for Sale by private party 6 04-25-2009 08:52 PM
2009 Sedan Aerokit Front Lip Part #? Split Cosmetic Modifications (Exterior/Interior) 9 11-26-2008 07:19 PM
