#37 |
I'll post pics of the cabling once I clean it up. Frankly, that area is a mess right now!!! I cared to get it working, not to make it pretty.
I didn't use a switch. If I need to open it, just roll one lock and the other one will follow. The nice thing about the A1 keyless unit is that about 5s after contact, the doors unlock themselves, and once you turn off the car, they unlock automatically. It's a nice feature really |
#38 |
~ ambient one ~
Drives: 2009 Bayou Yaris Liftback Join Date: Jan 2007
Sweet W.A.S.P.! Looking to get it in a few months. If I run into problems, you're a local guy ha!
AMBIENTLIFESTYLE
Tri-State Sport Compact EZine ambientlifestyle.com------------ambientlifestyle.ning.com ![]() Micro Image Store - Network - Online microimageonline.com------------microimage.ning.com |
#39 | |
![]() Drives: 2007 Yaris LB Black Join Date: Jan 2007
Can any of you guys who have done this install post a quick list of what tools are needed or that you used? I'm pretty new to DIY stuff, so I'm still learning. |
#40 | |
![]() Drives: 2007 Yaris Sedan Join Date: Jan 2007
A drill Various screwdrivers Wire strippers and cutters and stuff I can't think of much else. You don't need anything you don't have in the garage. The pros solder the wires when they splice into the electrical system. I use those tap connecters. Not quite as permanent, but easier. |
#41 |
アキバ製
Drives: 09' White LB, Celica GTS Join Date: Apr 2009
I have the same power window kit, but cant find a power source and illumination source to tap to that wont blow fuses. any help?
#42 |
![]() ![]() Drives: 2008 Red Yaris LB Join Date: Nov 2008
Is it possible to get the switches in the panel near the e-brake?
#43 |
![]() ![]() Drives: '07 M&M LB Join Date: Jul 2007
I have a question what is this part I have on red called or where can I buy it? I am reffering to the piece to hold the door cable and the metal piece from actuator thank you.
#44 |
#45 |
Just Ordered
Hi all! I just ordered the keyless entry/power locks kit below. This thread should come in very handy while I try to install it. I'll try to take pictures of my install as I progress. Thanks!
http://www.a1electric.com/Merchant2/...Code=W01C-712T |
#46 |
Free Mustache Rides
are they both universal kits? would love to have some power windows. and a key faub would be nice too.
#47 | |
http://www.a1electric.com/Merchant2/...ct_Code=Master |
#48 |
Drives: Yaris Join Date: Aug 2009
how long does the install take for the door locks and windows?
#49 |
It took me about 4 hrs to install power locks on both doors and the trunk. I'm sure it could be done faster but I work at a leisurely pace. LOL! I did not do the windows, as I like having the manual cranks.
#50 |
Drives: Toyota Matrix Join Date: Nov 2009
How are the motors / locks holding up? Another question, are the power window motors noisy and slower than OEM standards?
#51 |
Yes- I fit in it.
I put mine in in April... So far no problems.
I'm surprised it doesn't have a pull-start ! |
#52 |
What to Mod Next?
Drives: 2008 3Dr HB, Bayou Blue Join Date: Oct 2009
I have had mine in for over a year without problems. With the exception that I had to readjust one of the lock actuators. As far as the noise is concerned, I would say that both are about equal to that of OEM motors and locks. Initially I didn't hook the horn circuit to the locks, but couldn't hear them engage so I added that wire along with the lighting circuit to flash. The window motors are quiet and smooth and just as fast as oem, but it took me about 3 weeks to stop reaching for the window crank.
#53 |
![]() Drives: 2008 2 door hatchback Join Date: Aug 2011
#54 |
1.5 or 2.5 both=0-60 in 8
Why didn't i see this thread before i did my locks? it took me a long time to figure out the actuator location.
Mine was installed in 5 hours 2 doors only and with a budget of around $40 only. Keyless entry.
| Questions and advice required about power upgrading(windows & locks) | W.A.S.P | DIY / Maintenance / Service | 10 | 07-22-2009 02:59 AM |
| Need Help - Electrical (finding Power) | Ayka | DIY / Maintenance / Service | 7 | 10-12-2006 11:51 AM |
| The power upgrade thread | ChinoCharles | DIY / Maintenance / Service | 19 | 09-27-2006 03:14 PM |
| Custom Sub Enclosure (inc sub, power cap, amp) | wado | Items for Sale by private party | 3 | 09-18-2006 11:53 AM |
