Old 08-29-2011, 11:28 PM   #1
detroiter
detroiter's Avatar
How to change radiator fluid/
Well the car is a bit over 110k and I figure it's time to change the radiator fluid, as well as it's starting to get low from evaporating over time ,etc. Is there a writeup or can someone put up a step by step on a proper way to drain the fluid and refill it? Thanks!
Old 08-29-2011, 11:45 PM   #2
Brian
Brian's Avatar
Page 8 of the cooling section in the factory repair manual. I change mine at 90k.
Old 08-30-2011, 05:35 AM   #3
detroiter
detroiter's Avatar
Could you please post me a link to the manual? I'm having a hard time finding it, thanks!
Old 08-30-2011, 05:41 AM   #4
Klink10
Klink10's Avatar
Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Technical Forums > DIY / Maintenance / Service..............2007 Yaris Factory Repair Manual
That's not a link but it's where to go on this forum. Find that and it will link you to the service manual for the 07. Things haven't changed that much so it should help you out.
Did mine not to long ago. if you have any questions shoot me a PM.
Old 08-30-2011, 02:47 PM   #5
Vinceb
Drives: 2008 5 Speed Sedan
thanks for the info, found what I think I need in the manual. does anybody know, does it matter if I use prestone premix (green) vs toyota super long life fluid (pink) ? - no leaks, levels still ok, color is still bright pink. 152,000km
Vinceb is offline   Reply With Quote
Old 08-30-2011, 02:50 PM   #6
A-Dingo-Ate-My-Baby
Drives: yaris
the new green prestone 50/50 premix that works on ANY car ANY cooling system
(says on bottle) will work fine anywhere Toyota red is specified
otherwise, stick with Toyota red from the dealer and u cannot go wrong
old-school prestone green is NOT recommended
A-Dingo-Ate-My-Baby is offline   Reply With Quote
Old 08-30-2011, 03:16 PM   #7
bronsin
bronsin's Avatar
On my ECHO you just opened the radiator drain and take the radiator cap off. Engine is cold! All the coolant the book says is in there came out
Close the drain and fill with 50/50 mix of coolant and water. Start the engine and warm it up until the coolnt level in the radiator goes down. Top up the radiator and rstart. Keep filling it until it doesnt go down anymore.
Yaris is the same?
Old 08-30-2011, 08:45 PM   #8
Klink10
Klink10's Avatar
Doing mine....I drained the
1. Radiator
2. Block via the valve on the backside of the engine
3. Overflow tank on the side of the radiator
Did I get it all?
Nope......Pull the fixture where the bottom radiator hose attaches at the engine behind which is the thermostat. If you easily pry out the thermostat you will see a cavity. That's where the remainder will be.
Anyway I caught the fluid and measured comparing to amount required and I got it all.
Yaris Oil Change DIY rningonfumes DIY / Maintenance / Service 91 01-11-2019 07:18 PM
My Oil Change Help Me, Please! JetfireK General Yaris / Vitz Discussion 6 01-09-2011 10:25 PM
$86.44 for oil change? I feel screwed behour General Yaris / Vitz Discussion 98 01-04-2010 07:10 PM
MJ dead 90tsi Off-topic / Other Cars / Everything else Discussions 28 06-26-2009 02:20 PM
Oil change question Ryu DIY / Maintenance / Service 22 03-07-2006 11:21 PM
