Old 09-01-2011, 07:10 AM   #1
kenkyd
kanye
Drives: 11 Corolla S
Send a message via AIM to kenkyd
Question Corolla Cruise Control
I have a 2011 Corolla, 5 speed w/cruise control. When in cruise, if I pull the car out of gear, the cruise remains on and the engine revs at the limiter. Should it do that? My 92 Accord would rev a slight bit when pulled out of gear, but then cancel cruise. Dealer said cars changed in 2006 and all cars do what mines doing, but when I said I had a remote start installed on a stick he said maybe it's that. Is this normal or not?
kenkyd is offline   Reply With Quote
Old 09-01-2011, 12:42 PM   #2
It sounds like the cruise control clutch switch is bypassed. There is a second clutch switch that is supposed to be installed on MT Toyotas with CC that closes opens when the clutch switch is pressed (as opposed to the starter clutch switch, which closes when the clutch is fully depressed).
Old 09-01-2011, 02:57 PM   #3
kenkyd
kanye
I don't press the clutch to take it out of gear when coasting to a light or stop.
Old 09-01-2011, 03:01 PM   #4
Ahhh - There's your problem. The low end Toyota transmissions don't have a neutral switch on the tranny, so unless you touch the clutch the ECM has no idea that you are no longer in gear.
Old 09-02-2011, 12:39 AM   #5
jpmck03
jpmck03's Avatar
Drives: 2025 GR86
Based on first hand knowledge, if you bump the shifter out of gear in a Yaris with the factory cruise control the engine will bounce off the rev limiter until you hit the brake or clutch.
DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag CTScott DIY / Maintenance / Service 307 04-04-2023 03:43 AM
Newly refreshed 2011 Toyota Corolla Kal-El Off-topic / Other Cars / Everything else Discussions 23 11-27-2010 12:57 PM
