Old 09-03-2011, 11:44 AM   #1
willygoodness
Drives: 09 yaris hb
rattly clutch.. ?
howdy,
i've noticed my that when i'm driving around or even just revving and holding the revs at anything over 2000rpm with my foot off the clutch peddle, there's a slight rattle and over the last month its turned into a higher pitched rattle.. but if I rest my foot on the clutch peddle the sound disappears. If I press it down only 1cm or all the way the sound goes away.
I've had a quick search for clutch rattles and gearbox rattles and couldn't find anything that sounds like my problem.
Has anyone had this problem/annoying sound? Any idea what it could be?
Maybe the lube on the gear selector/clutch cable in the engine bay might fix it?
09, 1.3L manual hatchback.
willygoodness is offline   Reply With Quote
Old 09-03-2011, 02:55 PM   #2
MickZEL
MickZEL's Avatar
Drives: Yaris sedan
This may be a spring on the clutch disc
They may become weak and begin rattly.
Possible cause overheating of the clutch disc.
I like very much travel
MickZEL is offline   Reply With Quote
Old 09-03-2011, 10:55 PM   #3
TLyttle
TLyttle's Avatar
Drives: 07 Yaris sedan
Apparently this is a common complaint in the Echos. Replacing the clutch isn't cheap, either!
Old 09-04-2011, 01:38 AM   #4
Throwout bearing? Mine did that.
HELP PLEEEASE!!! my yaris starts whenever I step on the clutch pedal. trini_per4mance DIY / Maintenance / Service 42 03-27-2017 04:59 AM
Clutch shudder when setting off in 1st gear BuildCode DIY / Maintenance / Service 87 06-17-2015 08:14 AM
Help Me Find The Right Clutch RacerFreakXXX Performance Modifications 18 10-20-2010 06:20 PM
Restarting car after popping the clutch... PaidTimeOff General Yaris / Vitz Discussion 21 02-26-2009 02:40 PM
Having clutch issues ? hystria DIY / Maintenance / Service 10 08-22-2007 12:34 PM
