Old 03-07-2007, 05:32 PM   #19
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
[QUOTE=ChinoCharles;60238]-slaps forehead-
Listen, here is the deal... with exhausts on your Yaris... first of all, you guys are still running a stock midpipe right in the middle of your system. You'd probably see better gains replacing the header and midpipe than you would the header and axleback portion. The key is to "get it out." Running 2.25" piping for the first 50% of your exhaust will free you up... running 2.5" piping to 2" piping then back to 2.25", that is just crazy. If you expect noticable performance gains from that kind of a setup, you're crazy too. QUOTE]
I wasn't expecting big gains, but I'm not excited about low end loss either. I really wanted it for the sound and stainless construction.
Old 03-07-2007, 05:53 PM   #20
ROCKLANDTOYOTA
JOE GIRTH
Drives: YARIS 3DOOR
Originally Posted by Nimble View Post
NEWS FLASH!!! A Yaris is slow even with a header, pulley, intake, exhaust, lightweight oil filter cap, high performance windshield washer fluid tank, color matched badges, less than 1/2 a tank of gas, and you cutting your legs off to save weight.
this is the kind of crap answer i didn't expect to see in this forum but its all good.........
http://www.carid.com/toyota-accessories/
site has a FEW interesting yaris items.....
ROCKLANDTOYOTA is offline   Reply With Quote
Old 03-07-2007, 06:01 PM   #21
Nimble
Modification Condoner.
Drives: 2007 Black Sand Liftback
Expect it more with all the lame posts you've been making. Besides, haven't you read my avatar?
Tanabe DF, Debadged, stripped, Black emblems
Nimble is offline   Reply With Quote
Old 03-07-2007, 10:28 PM   #22
ChinoCharles
Drives: LB
Don't mind Nimble. He's a prick, but we tolerate him nonetheless.
Old 03-07-2007, 10:56 PM   #23
PetersRedYaris
Yeah, don't mind the exaggerated response, It's just the roids talking.
Old 03-07-2007, 11:08 PM   #24
ChinoCharles
Drives: LB
We still love you Nimble. Someone has to slap the rice out of the forums. Guess its you now.
Old 03-08-2007, 12:13 AM   #25
Poorboy
Poorboy's Avatar
Drives: 07 liftback
Where do you get that high performance washer fluid at? How many hp increase
Poorboy is offline   Reply With Quote
Old 03-08-2007, 12:14 AM   #26
Nimble
Old 03-08-2007, 12:15 AM   #27
Nimble
12 to the wheels on rwd, 14 on fwd, we're lucky.
Old 03-08-2007, 12:15 AM   #28
Nimble
Old 03-08-2007, 12:31 AM   #29
tekmoe
ex-yaris owner
Drives: 08 solstice gxp, 06 triumph s3
Send a message via AIM to tekmoe
dam, thats cold.
tekmoe is offline   Reply With Quote
Old 03-08-2007, 04:37 AM   #30
ToTo
ToTo's Avatar
Drives: Toyota Yaris T SPORT
Sure, you can throw a high flow cat in your custom midpipe. The only thing is you're still going to have to do your homework and figure out how to deal with the sensors. From what I understand, nobody has had much luck with this yet, hence why no aftermarket company is offering a midpipe. Therefore, in order to run a high-flow cat you'll probably end up having to trick the sensors, but if you're tricking the sensors you don't need a cat, so why have it? Even a high-flow cat will make you lose a little flow vs. not having one at all. I say trick the sensors, buy a muffler and bend some 2.25"... make/weld yourself a little flange and booya.
Regarding the high flow cat, why do you have to trick the sensors? I just dont really understand. On the Yaris there are 2 sensors, one in the manifold and one after the cat. So if you put all your sensors back in after installing the high flow cat, I just dont get why the engine light would come on? The high flow cat is changing and giving different results for the second sensor... Not like with a decat which is the same result between the two sensors, which makes the engine light come on...
ToTo is offline   Reply With Quote
Old 03-08-2007, 11:37 AM   #31
ROCKLANDTOYOTA
JOE GIRTH
Drives: YARIS 3DOOR
not a problem i deal with douche bags on a daily basis anyway........
Old 03-08-2007, 11:41 AM   #32
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Apparently since I'm a ZPI hater (not really) you might not want to try this little trick I learned from my SRT-4 days...
Toto- I believe I know why you're going to see a code if you just install on a straight pipe. Read on...
When I replaced my o2 pipe and my downpipe, we had two o2 sensors. One on the o2 pipe itself and one in the "cat" area. I decided to run a straight downpipe with a cutout. I understood that the computers would throw a code if the o2 sensors didn't detect a certain temperature difference between the two sensors. What I did was to buy a spark plug non-fouler, bore the inside out a little bit with a 1/2" drill bit. Why? Well, go ahead and try to screw in an o2 sensor to an 18mm non-fouler without boring the inside top out a little bit, you'll understand...the sensor just doesn't fit. When you take a bit of material out of it it will screw right on. After you bore that non-fouler out and fit it onto the o2 sensor, simply screw the non-fouler into the downstream sensor bung.
This backs the sensor off just enough to have it read a lower temperature like you'd have with a cat...like you're supposed to. It is my belief that when you look at a catalitic converter versus a straight pipe, you should notice that the o2 sensor dosn't go straight into the pipe's exaust stream as much as it would with a straight pipe. With my limited smarts on vehicle engines, I believe the temperature issue is why you'd see a code.
Now, I can find the how to for the SRT but it is really as simple as i've described it. I don't know the specific size of the stock o2 sensor on our Yaris. Sice I'm NOT going to be messing with the engine of mine...I leave this up to you guys.
On the old car, I NEVER threw a code with this little DIY mod in the year and a half I used it.
Thoughts?
― Thomas Paine
Old 03-08-2007, 12:02 PM   #33
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
I'm actually going for this mod in a couple of weeks:
Custom test pipe and the non-fouler trick.
Is a cheap mod (like $60 on a local shop) so if it goes wrong I'll just go back to the original set up.
I don't want to loose any low end power (this is a DD after all) so I don't want to go for a bigger pipe. I'm just curious to see how the car reacts to a better flowing exhaust. I think there is no gain on going for a larger diameter pipe, been this a N/A 1.5L but maybe we could get something out of an improved flow.
Let you know how it goes...
Old 03-08-2007, 12:15 PM   #34
ChinoCharles
Drives: LB
I'll see if Baskin can get a hold of his guy in Toyota... maybe we can grab their coursework on their O2 sensors and see whats going on.
CASTREX, thats what I'm talking about!!! Go 2.25" though, make it a tad larger.
Old 03-08-2007, 12:19 PM   #35
CASTREX
CASTREX's Avatar
Some thing else exhaust related that I've been thinking about lately...
I kind of like the Chinocharles filosofy of cheap mods for a cheap car
Looking at the pics of theTRD muffler, it just looks almost the same as the OEM muffler with a nice polished tip. I guess the difference must be on the inside.
So, any one thinks that could be possible to open the OEM muffler and take some guts out of it? I dunno how that muffler looks on the inside, but anyone thinks that this could be done? Improved flow and quite at the same time!
Old 03-08-2007, 01:26 PM   #36
Nimble
Right, guys like you...you know car salesman....typical douche bags.
I test drove a Yaris, Versa and FIT CanadaCraig New YARIS Purchase Forum 41 11-29-2008 10:18 PM
My Yaris IS SLOW David81 Performance Modifications 47 08-08-2006 03:34 PM
