Old 06-20-2011, 06:23 PM   #55
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
I got the 90#'s in today, did the swap...click the pic for the video.
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWNX%3AIT
-Type 07 FFL-
My odometer 03/11
Old 06-21-2011, 02:59 AM   #56
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
Those look much more normal!
Old 06-22-2011, 12:08 AM   #57
auxmike
auxmike's Avatar
[QUOTE=mazilla;588410]I got the 90#'s in today, did the swap...click the pic for the video.
Is that a Yaris? Almost looks like a Scion Xd or something else?
Old 06-22-2011, 12:46 AM   #58
mazilla
advocatus diaboli
mazilla's Avatar
[QUOTE=auxmike;588668]
It's the same 07' Yaris in my avatar.
-Type 07 FFL-
My odometer 03/11
Old 06-27-2011, 02:23 AM   #59
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
I installed my 94s yesterday. Took literally 60 seconds each, most of which was spent trying to pry the original clips off the stock shocks so I can remove them. These new ones just pop on, easiest thing ever!
Old 10-06-2011, 07:06 PM   #60
dzcab
Drives: 2011 3Dr Hatch
Can anyone give me the sellers that you uses from EBay cause i ordered a set from makarios RV and the shipment is still pending and I need to send to PR ASAP. Or if someone knows the part number that will help.
dzcab is offline   Reply With Quote
Old 10-06-2011, 07:16 PM   #61
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
I can't actually find it anymore
Old 10-06-2011, 09:46 PM   #62
I have had the eBay ones on my car for a while now and they still are a bit more than ideal. I would stick with ones that are rated as direct replacements, like these ($52 for a set from Amazon):
http://www.amazon.com/Lift-Supports-.../dp/B0044EKBMK
Old 10-07-2011, 10:48 AM   #63
mazilla
advocatus diaboli
mazilla's Avatar
The 90lb Ebay shocks work perfectly. When I get to my computer I'll take a look and see if I can get the sellers info.
-Type 07 FFL-
My odometer 03/11
Old 10-12-2011, 08:29 AM   #64
dzcab
I ordered the makarios one from AP Products and they fit but don't close hatch. Anyone have the link to the eBay ones. I have searched all over eBay and can't find. I need to send some ASAP, or a part number from Toyota.
Old 10-12-2011, 09:11 AM   #65
What do you mean by "don't close hatch"?
The ebay listing is gone for the ones that I purchased.
The genuine Toyota ones are:
Without rear wiper:
Right: 68950-0W391
Left: 68960-0W391
With rear wiper:
Right: 68950-0D022
Left: 68960-0D012
Old 10-12-2011, 02:17 PM   #66
mazilla
advocatus diaboli
mazilla's Avatar
http://cgi.ebay.com/ebaymotors/2-CAM...m=320694785221
http://myworld.ebay.com/sheng2000/
-Type 07 FFL-
My odometer 03/11
Old 10-12-2011, 07:03 PM   #67
dzcab
[QUOTE=CTScott;609075]What do you mean by "don't close hatch"?
I ordered the ones that were thought to fit from makarios and they strut itself is about .5 inches longer than oem one and when u try to close the tailgate only goes down about 3/4 but wont fully close all way down.
Old 10-12-2011, 08:35 PM   #68
[QUOTE=dzcab;609161]
Got it. Which model number did you order from them?
Old 12-01-2012, 12:02 PM   #69
Redbat01
Yaris-My All Purpose Car!
Redbat01's Avatar
Drives: 2008 Toyota Yaris 3-Door
Success story: I own a 2008 Yaris 3-door hatchback. This morning, I replaced the hatch struts. It was a simple job and the new struts fit perfectly and work fine. It was about 40 degrees Fahrenheit outside when I installed them.
Brand Name: Columbia Struts
Columbia Part Number: CS1720-90
Rod & Tube Size: 8MM x 18MM
Extended Length: 17.20 inches
Minimum Stroke: 7 inches
Force in Pounds: 90 lb
Purchased from: "strut-your-stuff-here" on EBay
Price for two struts, including shipping: $35.88
My thanks to CTScott and everybody else who wrote about their experience with hatchback struts. Your advice saved me the cost of buying the struts from the dealer.
Redbat01 is offline   Reply With Quote
Old 12-12-2012, 05:10 PM   #70
watersoilair
Drives: 08-2DR-MT-LB-Red
This happens with my hatch too. I have to push the hatch up, otherwise I'll hit my head...done that a few times sadly.
watersoilair is offline   Reply With Quote
Old 12-15-2012, 02:22 AM   #71
mazilla
advocatus diaboli
mazilla's Avatar
My ebay struts are still perfect, and I use the hatch several times(possibly a dozen+) per day M-F...haven't hit my head since I posted about it.
-Type 07 FFL-
My odometer 03/11
Old 04-03-2014, 02:53 PM   #72
GrayYaris
Drives: Gray
Update
2014 update. I looked around a few places and I found these on Amazon:
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
If I remember correctly, they are cheaper on Amazon than on Lift Supports Depot's actual site. It is about 30-40 degrees Fahrenheit here and they are working fine. Hopefully they last a while. Before I got them, I had to hold my hatch up as it would slam shut otherwise.
GrayYaris is offline   Reply With Quote
Where can i get a Hatchback trunk cover for cheap? Syroyizhka Cosmetic Modifications (Exterior/Interior) 19 10-29-2013 01:59 PM
3 Door Hatchback Questions Dorkinheimer General Yaris / Vitz Discussion 12 01-16-2012 06:30 PM
Hatchback Trunk Cover KrazyDawg General Yaris / Vitz Discussion 24 11-08-2010 03:00 AM
is this trunk kit ok for our hatchback ?? vten DIY / Maintenance / Service 3 10-31-2009 03:49 AM
yaris sedan remote trunk relase question pls help soon fantabulousbaby New YARIS Purchase Forum 4 08-05-2006 02:26 AM
